Old 09-26-2004, 12:38 AM   #1
NiN^_^NiN's Avatar
NiN^_^NiN is on a distinguished road
Lightbulb Destinator 2 SDK tips for composite screens and audio tips
Ok i have a 7" LCD that uses composite and of course mp3 and videos are great but when the GPS comes into ply its just way to small to use basiclly.
So what i did was do alot of testing in the car to make the LCD read Destinator on the LCD easily
So what i did was go to C:\PowerLOC\Destinator\Common\Interface\Destinator .Inf and open up the file in notepad
Now move down to neer the end of the file and u will see
::F,Tahoma,24,0
I changed it to ::F,Arial,35,0
Now this the text size of the text in the GPS setting windows so u can see what comport etc you are selecting. It also changed the text in the settings window and the text on the bottom right showing how many sattelites there are.
now right at the start of the file u will see
SIZE=24
change it to 35 or the setting you best want.
This changed the size of most items mostly the button sizes
Now under that you will see these
::T,ABOUT,200,LF,,,24,About
::T,ADDRESS_BOOK,200,LF,,,24,Favourites
thats the size of the text for the buttons like about favourites etc
change the 24 to 35 or a size that suits you
Also note that cause im in australia this was annoying to me:
::T,CITY_STREET,200,LF,,,24,City->Street
Now in australia we dont call it City so i changed it to
::T,CITY_STREET,200,LF,,,24,Suburb->Street
same with
::T,STREET_ZIP_CODE,200,LF,,,24,St.->Zip
We call the Zip code postcode in australia so i changed it to:
::T,STREET_ZIP_CODE,200,LF,,,24,St.->P. Code
makes sense
Now scroll down till u see something like this:
//:,240,320,639
:,640,420,640
now i changed the last line to 640 instead of 639
This means at 640 the onscreen keyboard will showup when u search for a street.
Now onto the Sound for destinator
Some people say they can't hear the voice directions over the mp3's play sometimes.
Well what i do is open up the Sound recorder in Start > Programs > Accessories > Entertainment
and i open up the wave files from destinator then i just click the effects button then click increase volume by 25% till you think your happy with it then save it.
Now you can view and hear destinator perfectly
Only problem is the map you cant change the text size of the citys/suburbs but you dont need to bother about it cause i use 3d mode a bit but i also use normal mode and if u wanna know what street your on click the info button for it to tell u as he text is now readable for u
I hope this helps some people till the D3 sdk gets sorted out
Also you could do what iv done and actually changed the button bmp files to match the media car skin
Im also working on a nice media car skin that looks good on a composite LCD as i dont want to pay $500 for a lilput
Hope this helps some of you guys who are stuck with destinator till we get a new version and i hope it helps make life easier for guys without a VGA screen like me
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
NiN^_^NiN is offline   Reply With Quote
Advertisement Sponsored links
Old 09-26-2004, 04:51 AM   #2
Dominik is on a distinguished road
Thanks! I thought i was the only one who couldnt afford a VGA touch screen! And either way, the bigger the text the better anyway - you dont want to have to concentrate to read the text while driving!!!
Can't wait to try this out
Dominik is offline   Reply With Quote
Old 09-26-2004, 04:59 AM   #3
NiN^_^NiN's Avatar
You can make it all look great the only problem on a composite LCD after your edit it to how u like it the only problem y have on the LCD is not readin what street you are in and clicking the info button will tell you thats the only problem the text on the maps is actually on the map so u can't change the size i dont think.
Im just glad i help atleast 1 person
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 09-26-2004, 05:31 AM   #4
mauri's Avatar
mauri is on a distinguished road
You try to use the buttons that I have done me for D2 SDK .
I had drawn ago them a few months to use with the skin of Mediacar " Brusheed metal" and they are liked a lot.
You replace the original file in C:\Powerloc\Destinator\Common\Interface with my file.
You make to know if you like
Mauri
mauri is offline   Reply With Quote
Old 09-26-2004, 05:51 AM   #5
NiN^_^NiN's Avatar
I might as well post mine 2
Iv changed to a newer type its a kind of aqua look but im still working on it
these look nice but they match the skin i orignal made so you prob wont want it
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 09-26-2004, 06:49 AM   #6
mauri's Avatar
Its OK also your buttons, however' as they are mine they have a lot of effect 3D inthe Dest2 menu.
Your buttons seem proper for the new alpha version of Dest3 SDK.
We hope that there am also soon an update with the active buttons in the menu of Dest3
Mauri
Old 09-26-2004, 07:19 AM   #7
TX5
TX5 is on a distinguished road
i "should" have my screen on monday (not a vga) so ill be give this a try
thanks
TX5 is offline   Reply With Quote
Old 09-26-2004, 09:21 PM   #8
NiN^_^NiN's Avatar
Mauri
Nah im sure someone else can make better buttons for the new D3 SDK i just waiting for a respone i want it so bad hehe
Thoese buttons are from when i was making my own frontend as i dont need the DVD player and also i was addin a special button so if a cop ask me to play divx from the main menu it will say you are not allowed to watch video files while the engine is on just to be safe
but i ran into a snag with winamp playlist and directorys so im just using media car now.
Im also gonna add SCANLINES to the orignal media car skin to see if it helps it look better on the LCD it should
thanks
What Type of screen? 7" or 5" ?
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 09-26-2004, 11:19 PM   #9
TX5
just got it
its a 7"
Old 09-27-2004, 12:49 AM   #10
NiN^_^NiN's Avatar
Post pics post pics
My 7" LCD is a unipac its OEM so i need to make a case and everything for it as its just a LCD and controller board no case
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 09-27-2004, 01:54 AM   #11
TX5
Quote: Originally Posted by NiN^_^NiN
Post pics post pics
will do
having some issues, i got a new video card so that i can use the composite out and it dosnt apear to work.
when i put it in my carputer it dosnt boot up
when i tryed it in my desktop it boots up fine but windows refuses to agnolage its presence
Old 09-27-2004, 02:36 AM   #12
NiN^_^NiN's Avatar
Whats the card your trying to use?
Also i'll take some pics tonight of destinator on the 7" on normal settings then when iv added the new text size etc
give u all a good idea hopefully i'll have the scanline done on the skin so i can take a pic of that 2
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 09-27-2004, 07:41 AM   #13
TX5
Much more readable than i though it would be.
Old 09-27-2004, 08:00 AM   #14
NiN^_^NiN's Avatar
cool looks great
did u edit the destinator file to make the text better?
the text size really helped me when i setup the gps and also when i used the POI list its where it became a REAL big help
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 09-27-2004, 08:08 AM   #15
TX5
i edited it on the carputer, but that dosnt have composite out until i get this video card replaced.
the photos are of it running on my desktop which i havnt bothered to change.
VGA Lilliput screens - Extreme Audio Electronics (ebay) autopia LCD/Display 6 11-04-2003 03:36 PM
