Old 09-26-2004, 05:02 PM   #1
hsuca's Avatar
Question Alpine NVE-N077PS's RGB output to VGA input on 7" lilliput TS monitor?
Hi all, I have been on for all the VGA and RGB connection on mp3car.com but still can't solve my problem.
From Alpine NVE-N077PS it uses RGB output (RGB + Composite TTL SYNC) and Lilliput use VGA input. So my setup would be from RGB to VGA.
Is it the same as how you would connect from VGA to RGB? Where do I connect the Composite TTL SYNC to which pin on lilliput's VGA connector?
The reason why I didn't use composite video out put from NVE-N077PS is because it won't show up on my new Lilliput 7" TS monitor, all I get is constant showing up "NO VIDEO 1" on the monitor 7" TS monitor-NEW
I don't know why, it is fine with the older Lilliput 7" TV monitor7" TV monitor-OLD but not with this new TS monitor.
I am thinking maybe they are not compatible but I still hope I can use this TS monitor with alpine GPS Please help me!!!
Thanks in advance.
hsuca is offline   Reply With Quote
Advertisement Sponsored links
Old 09-30-2004, 09:10 PM   #2
youll probably need something like this (and a 12v power supply for it)
http://www.pcwcomponentcentre.co.uk/...ricecomparison
robr is offline   Reply With Quote
Old 10-01-2004, 03:26 AM   #3
hsuca's Avatar
Thumbs up
Thanks for reply.
Will try that
Old 10-04-2004, 05:13 PM   #4
thedude_five's Avatar
http://www.mp3car.com/vbulletin/show...vigation+input
thedude_five is offline   Reply With Quote
Lilliput 7" VGA and EPIA M9000 issues... heat LCD/Display 9 01-15-2004 03:57 PM
Taking apart 7" TFT VGA monitor for custom install? afr0puff LCD/Display 14 12-18-2003 01:50 PM
anyone has an old lilliput 7in vga monitor for sale? Dluvr22 LCD/Display 0 11-10-2003 02:56 PM
Indash monitor housing help... 7" in dash VGA conversion vwaddict LCD/Display 14 10-14-2003 08:25 PM
Lilliput 7" TFT Car Monitor w/audio and Touch Screen foneman LCD/Display 3 09-23-2003 09:46 AM
