Old 09-29-2004, 06:15 AM   #1
BOND007BE's Avatar
GPS Hibernation resume
first i run WINXP with SP , coming out of hibernation the GPS mouse spit outs NMEA data but cant LOCK.
so GPS is royaltek RGM-2000 , with the GPSDEMO.exe software (on the royaltek site) i can see GPS is working fine , several SATelites but i cant get no LOCK until i REBOOT the PC , on one occasion i DID get a lock after about 10 minutes of driving arround.
is this a known item ?
i do have a LONG USB cable connected to it (from back of car to front)
the sun always shine
BOND007BE is offline   Reply With Quote
Old 09-29-2004, 06:24 AM   #2
NiN^_^NiN's Avatar
Well to rule out the UBS cable if you can plug the GPS in to the pc then leave it on for 5misn n move around then put it into hibernation then wait a min or to then come back out see if it locks
If it does you need a USB data repeater cable i would gather.
If it doesn't then you need to see if unplugging the GPS then plugging it back in helps.
There has been problems with this on the forum i think if your running the GPS app then hibernationg it can have problems try shutting down the app then hibernationg then seeing if you get a lock
or you can try hot restart to see if the GPS resets if so you might be able to find some code for hot restart then run that code after hibernation if thats possible??
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
NiN^_^NiN is offline   Reply With Quote
Old 09-29-2004, 06:30 AM   #3
BOND007BE's Avatar
you mean like using DEVCON ?
Old 09-30-2004, 04:13 PM   #4
fantomas's Avatar
dont drive until theres a lock. just wait there for 5 minutes or until you do get a lock. and have the receiver outside of the car
rebuilding carpc... kinda..
fantomas is offline   Reply With Quote
Old 09-30-2004, 04:27 PM   #5
tbird2340's Avatar
I have a similar problem. I first had an Earthmate.. I would get a lock and drive around for a while... I would then hibernate / resume. When it came out from hibernation it did the EXACT same thing.. It would show data but not lock on ANY sats... It would eventually after a LONG time... If I reboot then it would a lot faster.. I took that GPS back just because I was testing it and I didn't feel like paying $125 for a GPS. I got the Rikaline GPS-6010. It gets locks almost instantly.. When I come out from hibernation Routis says it can't find the GPS. I have to go and tell it com 4 and then it's immediately locked again...
Weird..
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Problem with interrupted resume from hibernation with XP Mastiff General MP3Car Discussion 1 01-25-2005 05:46 PM
a new way of GPS brownpage GPS 8 08-24-2004 03:51 PM
Should GPS stay locked thru hibernation? technopsych GPS 10 08-04-2004 01:30 PM
Window Tint's effect on GPS signal MoFo GPS 3 07-19-2004 06:08 PM
ME stops playing music after resume from hibernation nicgalla ME Archive 2 11-25-2003 11:50 PM
