Old 10-02-2004, 01:46 AM   #1
G-Han is on a distinguished road
Yet another BU 303 issue
hey guys i just bought the 303 off ebay and i cant seem to get a lock.
ive got the gps info software open, ive selected the right com port
When i start the gps, i get a whole bunch of writing, but when i go to look at the satelites they are all either aligned in a nice straight line or they are all sittin in the same spot. Plus, the led light is always on, not flashing
im in sydney, and it is fairly cloudy
could this be the reason im gettin no lock?
cheers fellahs
G-Han is offline   Reply With Quote
Old 10-02-2004, 02:26 AM   #2
Super Moderator
xBrady's Avatar
xBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to behold
cheers fellahs
My light never blinks, don't think it is supposed to. The writing that comes up is supposed to be there and that program that comes with it sucks so the best thing to do is try it with some GPS software.
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Old 10-02-2004, 03:10 AM   #3
carpcnoobie's Avatar
carpcnoobie is on a distinguished road
Dumb question, but the mouse has a clear view of the sky, I'm assuming? Try attaching it to the outside of a car, pointing up. That should really help you get a lock. I remember the first time I started mine it didn't get a lock for a long time. Now it's very quick and gets four sats sitting in the window of my apartment.
BTW, the BU-303 is supposed to blink when it has a lock.
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
carpcnoobie is offline   Reply With Quote
Old 10-02-2004, 04:06 AM   #4
SAScooby's Avatar
SAScooby is on a distinguished road
If i watch my unit, the light flashes when acquiring a signal, steady when on, if in a garage or so, the light flashes all the time, i think you need to put in a place with an unobscured view of the sky and go have a beer while it acquires its bearings, mine took about five minutes to sort itself out, use the gps info software to force a cold start and leave it for a while
Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
FS = MTSVO motorised in dash screen pm me for details
SAScooby is offline   Reply With Quote
Old 10-02-2004, 08:26 AM   #5
faichiu's Avatar
faichiu is on a distinguished road
What OS are u using? Have u updated to lastest serivce pack?
98 Honda civic
In-Dash LCD Monitor K-301
cappuccino EZ3
PIII-1.2GHZ
256MB PC133
40GB HD
Holux GR 213 Sirf Star III GPS
IguidanceV2
CNX-P1900 power supply
Sound Blaster Live USB
faichiu is offline   Reply With Quote
Old 10-02-2004, 01:58 PM   #6
See me in my wet t-shirt.
stevieg's Avatar
stevieg is on a distinguished road
I'm assuming you installed the drivers OK hence the bunch of writing, and you're using a supplied utlity to check the operation of the GPS.
To check it works, use it without anything on top of it - not even a windscreen, if you have a car PC handy sit the BU303 on top of the roof and see how many satellite you get. You should in clouds get at least 5
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
stevieg is offline   Reply With Quote
Old 10-04-2004, 01:15 PM   #7
Raw Wave
ShawJohn's Avatar
ShawJohn is on a distinguished road
Well I have finally found a good location for my BU-303... On top of the luvred blind for the sunroof. Even though my sunroof has like a metal mesh liner on the inside to make it a 50% tint I still get between 5 & 7 sats with a decent lock. Through my windscreeen it will only pick up 3 or 4 and even then loses lock regularly and takes an age to re-aquire. Looking through the sunroof though seems perfect. Only catch is I can't let the sunroof open all the way without slinging the 303 out onto the roof, its not really a hardship, but it will prove costly if I forget and my roof swallows the 303 and rips the cable out of it ;-) Still I don't have to worry about it getting damp any more and I can see the lock LED easily too.
One thing to ensure with the 303 is that the Baud rate is only set at 4800 both in the port setup and in the GPS software. Also check that nothing else is using the com port you've picked.
'Leadtek's Winfast Navigator' is one of the nicest programs I've seen for varifying GPS data reception.
ShawJohn is offline   Reply With Quote
Old 10-05-2004, 05:59 AM   #8
Thanks for the replies guys
i took some of your advice and hung it out the window the other day with clear skies. and i got a lock!
so everything seems to be working fine, its just a matter of moving it around to find the best spot now
thanks again!
Please Help, Opus issue (I think) jermkesler Power Supplies 26 09-05-2004 08:39 PM
Power Issue? mercury Power Supplies 9 08-22-2004 11:23 AM
More of a PSU/Inverter issue slasherx Power Supplies 0 08-11-2004 07:14 PM
Crank issue w/ reboot breimann Power Supplies 3 03-09-2004 09:45 AM
Opus power supply issue dmazyn Power Supplies 2 10-15-2003 07:32 PM
