Old 10-05-2004, 08:54 PM   #1
e_z_street's Avatar
Gps Module + External Antenna + Waas + Usb
Just to piggy back off of this post:
http://www.mp3car.com/vbulletin/gps/27046-just-purchased-deluo-w-external-antenna.html
This post mentions the Deluo gps unit that has a connector for an external antenna. The only problem with this unit is that it is not WAAS enabled. I would like to use an "all in one" antenna as mentioned in this post:
http://www.mp3car.com/vbulletin/gps/32990-all-one-gsm-fm-gps-antenna.html
If anybody else is looking, I did find a module that is WAAS enabled, has a connector for an external antenna, and would allow for a serial connection to a pc:
http://www.fortuna.com.tw/star_2-s.htm
Can anyone comment on this module or have any recommendations for other modules with similar features?
(There are many CF and Bluetooth modules that are WAAS enabled and have a connector for an external antenna - I would like to specifically use serial or usb input)
e_z_street is offline   Reply With Quote
Old 10-05-2004, 09:10 PM   #2
Raw Wave
By the look of it you will need to build a TTL<>RS232 converter, typically based on MAX232 chips. The datasheet says that the GPS output is TTL.
And of course you will need a +5V regulator, based on 7805 perhaps.
Ricky327 is offline   Reply With Quote
Old 10-05-2004, 09:11 PM   #3
Raw Wave
Also check the garmin GPS modules, they are WAAS enabled.
Old 10-06-2004, 03:57 PM   #4
e_z_street's Avatar
Ok, found the Garmin one:
http://www.garmin.com/products/gps15h/spec.html
It already has serial output. Anybody use this? I'll check on price.
Lowest price on Froogle - $93.99 (w/o the external antenna)
garmin mapsource and usb gps mouse thecrow GPS 9 09-26-2006 02:24 PM
MS Streets and trips with MS GPS module out tomorrow. deer killer GPS 2 08-15-2004 04:49 PM
FS: Xenarc 700TS 7"TFT w. Touch USB + GPS Mouse USB Malgates Classified Archive 6 06-08-2004 02:10 PM
CoPilot Software or USB GPS Receiver package Zip-Lock Classified Archive 5 05-13-2004 07:30 AM
USB DVD + Radio Tuner + OEM GPS gguy General Hardware Discussion 4 02-13-2001 11:43 AM
