The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 10-27-2004, 09:41 PM   #16
Vehicle: 2004 / BMW / 318i
My Photos: (0)
hmm but my prob extends to even the GPS info utility
im wondering...
could it be coz im running it off USB 1.1
and it possibly needs USB 2 ports?
G-Han is offline   Reply With Quote
Sponsored Links
Old 10-28-2004, 12:02 AM   #17
fishy's Avatar
Vehicle: 1994 toyota hilux-surf
My Photos: (0)
usb speed
usb 1.1 should be fine, im running a bu-303 on an old laptop P2, and it only has usb 1.1, and it is fine. most usb 2.0 peripherals are backwards compatible anyways (unless they require the faster transfer rate).
if you're running it thru a usb hub, power can be a problem, it may not be supplying enough voltage/current to power the unit, which needs a slot, with full 3.3 or 5v and all available current too itself (i think usb uses around 500ma current, not 100% on that tho).
perhaps the unit or youir usb port is faulty?
fishy is offline   Reply With Quote
Old 10-28-2004, 12:24 AM   #18
akw
My Photos: (0)
Quote: Originally Posted by G-Han
Hey guys thanks for the replies
What i have found is that if i uninstall and reinstall the device (ie. the usb to comp port). The device is found on both the info application and on destinator.
But if i leave it for say 10minutes
i start gettin "no device" and "gps not found"
though ive got a lock, coz my light is flashing away even though the 'gps is not found'
I believe the flashing light means that there is NO lock. Solid light indicates a satellite lock. Am I wrong on that?
akw is offline   Reply With Quote
Old 10-28-2004, 01:45 AM   #19
fishy's Avatar
My Photos: (0)
sorry, wrong
yep, you're wrong, sorry.
a blinking/flashing light means the unit has booted, and is locked to satellites. a solid red light means the unit is either booting, or not locked.
Old 10-28-2004, 02:47 AM   #20
l0gic's Avatar
Vehicle: MR2 & Accord Type-R
My Photos: (0)
I beleive the usb spec is 500mA maximum per port supplied.
So you can run 1 500mA device or upto 5 100mA devices via a passive hub for example.
If you have a powered hub then the 500mA rating applies to each port again.
Out of interest, anyone know the power requirements for the BU-303?
Kevin
Build status {..........|} 99%
All installed - now into the fiddling about stage
Car:MR2
MB: EPIA C800
Display:Xenarc 700TS
Power:PW-70A & ITPS
Mem:384MB
HDD:40Gb Maxtor Diamond max
Radio:Dlink DRU-100
GPS:BU-303
OS:XP SP2
l0gic is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Yet another BU 303 issue G-Han GPS 7 10-05-2004 04:59 AM
How should i install this? jnusaira General MP3Car Discussion 8 08-13-2004 03:03 PM
Sponsored Links
Ad Management by RedTyger
