Old 10-13-2004, 06:19 AM   #1
G-Han is on a distinguished road
Unhappy Futher probs with my BU-303 install
I had a prob earlier with gettin a lock, and thats resolved (sorta)
but now im trying to use some software (destinator 3 actually)
and i always seem to get 'GPS not found'. Yet, I can see the red light on (no lock). its set to the right com port, being com port 3
O and when i use the GPS info utility to select Waas, it never stays checked after i reopen the program
How do i fix?
Im using XP, no SPs.... (also tried on windows 2000)
Thanks for the help guys
G-Han is offline   Reply With Quote
Advertisement Sponsored links
Old 10-13-2004, 10:34 AM   #2
NiN^_^NiN's Avatar
NiN^_^NiN is on a distinguished road
Try putting it ontop of a metal object etc. i dont know how u can improve it besides tin foil???
Try changing the com port in device properties as u could have a conflicting port being used.
Have u tryed doing the auto search in destinator should still be in d3.1 SDK
It's not ment to stay ticked after you click it WASS is used if the GPS supports it so destinator will use WASS if the gps supports that feature u dont turn it on or off.
Hope this has helped you some bit
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
NiN^_^NiN is offline   Reply With Quote
Old 10-13-2004, 03:18 PM   #3
l0gic's Avatar
l0gic is on a distinguished road
I received my BU-303 today and it worked out of the box
You probably didn't need to hear that though.
have you installed and used the GPS software that came on the install CD?
When I ran mine it found the receiver on com3 and it showed all the data coming in and a graphical display of the strength & number of the satellites.
I then installed D3 - see other thread in the gps section, and ran the GPS wizard fine.
My BU-303 will lock on when i sit it on the window cill. ....Just.
I assume the receiver has installed OK? I did remove and replace it and at one point XP installed it as a ball point mouse You can check it in Device Manager, it should appear as another com port - not as a GPS receiver, strangely
Best of luck
Kevin
Build status {..........|} 99%
All installed - now into the fiddling about stage
Car:MR2
MB: EPIA C800
Display:Xenarc 700TS
Power:PW-70A & ITPS
Mem:384MB
HDD:40Gb Maxtor Diamond max
Radio:Dlink DRU-100
GPS:BU-303
OS:XP SP2
l0gic is offline   Reply With Quote
Old 10-13-2004, 07:14 PM   #4
chenko
I had this unit moan with destinator, because I was trying to manually select the port, even though I was using the correct one (as all other programs do) it wanted to have another port.
Try seeing if you can get a connection with GPS Info or something small like that
chenko is offline   Reply With Quote
Old 10-13-2004, 07:24 PM   #5
Banned
Nico3k is on a distinguished road
When I was using destinator, I got problems sometimes with it not finding the GPS. You just have to go to settings and tell it to find the GPS, and it will say GPS found and work again like normal. Not a long-term fix, but it works and only takes like 10 seconds.
Nico3k is offline   Reply With Quote
Old 10-13-2004, 10:40 PM   #6
Hey guys thanks for the replies
What i have found is that if i uninstall and reinstall the device (ie. the usb to comp port). The device is found on both the info application and on destinator.
But if i leave it for say 10minutes
i start gettin "no device" and "gps not found"
though ive got a lock, coz my light is flashing away even though the 'gps is not found'
Old 10-17-2004, 03:48 AM   #7
*bump
any other suggestions guys? this is ****in me off
could this be a driver issue?
and just to check, wen windows finds a device, it asks for the driver, so i point it to the usb-comport driver. it takes it and is quite happy.
now is this meant to be the only thing installed? meaning, there is no actual 'usb device' installed?
**** **** ****, im just hoping its not the actual gps mouse which is faulty, and that i can find a solution to this problem
tis the only thing stopping me from purchasing the rest of the stuff for the carpc and puttin it in!
Old 10-17-2004, 04:01 AM   #8
GruvThang's Avatar
GruvThang is on a distinguished road
Did you happen change the USB port? I did that and my GPS did not show up no matter what I did.
Is the GPS showing up in the hardware manager?
[COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
GruvThang is offline   Reply With Quote
Old 10-17-2004, 04:34 AM   #9
l0gic's Avatar
Mine appears as a USB to Com Port only, in the Ports area of device manager.
Couple of quick points,
Is the 303 pluged directly into the mobo USB port or is it on a long extension cable?
If it is, try it direct to the mobo.
You may not get sat lock but you will get destinator reporting that no sats available. See if it survives the '10 minute' test.
Also do you have anything else pluged into the USB ports? If so remove them for a while and test it solo. May be a maximum current issue...
When it disappears after 10 mins, does the GPS application that came with the 303 see it or is that unable to find it also?
Kevin
Car:MR2
MB: EPIA C800
Power:PW-70A & ITPS
Mem:384MB
Radio:Dlink DRU-100
GPS:BU-303
OS:XP SP2
Old 10-17-2004, 07:58 AM   #10
Yep ive switched the ports around to test them aaall
uhm, nope its connected directly to the mobo
there are no other usb devices in at the moment, except for a usb keyboard and mouse that have a usb-ps2 adapter on them. so nothing else directly plugged into the usb ports
'Prolific USB to COM' shows up in device manager
in regards to the device being lost in destinator, it is usually also lost in the 303 GPS info application. Sometimes it says 'no gps receivor', but most of the time its a 'no device'.
thanks guys, tis appreciated!
im wondering if its something to do with the fact that my driver gets installed as 'prolific'
Old 10-17-2004, 12:13 PM   #11
l0gic's Avatar
Mine is installed as prolific and it works fine......
Perhaps it is time to consider the GPS receiver is faulty?
Fails once it gets warm?
Kevin
Car:MR2
MB: EPIA C800
Power:PW-70A & ITPS
Mem:384MB
Radio:Dlink DRU-100
GPS:BU-303
OS:XP SP2
Old 10-17-2004, 12:25 PM   #12
Mesuge's Avatar
Mesuge is on a distinguished road
Yes, that might be the case.
I've read on the web somewhere that there is a whole batch of these faulty units floating around.. But the page was describing a trick how to go around it.. google it.. I was considering buying mine from the net/ebay as well but this scared me away..
Mesuge is offline   Reply With Quote
Old 10-17-2004, 08:15 PM   #13
fishy's Avatar
fishy is on a distinguished road
hibernate
one of the aussie guys has this same model, and he has a problem with the GPS not comming back to life or working correctly after hibernation of the PC...
just a thought.
fishy is offline   Reply With Quote
Old 10-23-2004, 08:11 PM   #14
julz is on a distinguished road
ive got the same issue, loses signal fairly frequently and occassionally destinator says "GPS not found".
I wonder if the people who are playing around with the Destinator SDK can get it to auto re-enable/reconnect the GPS if it detects it as 'GPS not found'. I have to manually click through (in destinator) and enable it at the moment which is hard to do while driving
HP 9110nx P4 2.8ghz Laptop
BU-303 USB GPS Receiver
julz is offline   Reply With Quote
Old 10-24-2004, 02:09 PM   #15
chenko
I acctually find using this in the Destinator SDK pc program that is avalible atm,. I cannot manually setup the GPS unit, I have to use the "Find GPS" button instead...
Yet another BU 303 issue G-Han GPS 7 10-05-2004 05:59 AM
How should i install this? jnusaira General MP3Car Discussion 8 08-13-2004 04:03 PM
