Old 10-13-2004, 10:58 PM   #1
GT65coupe's Avatar
GT65coupe is on a distinguished road
Dual GPS receiver ?
Hi guys,
Is it possible to use 2 GPS receivers at the same time?
for more accuracy?
Stephane
1965 Ford Mustang coupe
Ford Muscle & My 1965 Coupe
V8 Powered
GT65coupe is offline   Reply With Quote
Old 10-13-2004, 11:03 PM   #2
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
I haven't seen it done before. But I can't see it making a difference. Wouldn't both the receivers be locked to the same sats? So what would be the point of haveing two.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 10-13-2004, 11:05 PM   #3
GT65coupe's Avatar
well i don't know, that's why i am asking
maybe to boost reception? I don't know
V8 Powered
Old 10-13-2004, 11:10 PM   #4
HybridFox's Avatar
HybridFox is on a distinguished road
basicaly from what i here the triangulate your position to within about 5 meters of acuracy.
so it would be my guess that even if you did get it to work the best it would do is give you two positions 1-5 meters apart from each other so you could jus imagine yourself inbetween them
best i can do
HybridFox is offline   Reply With Quote
Old 10-13-2004, 11:10 PM   #5
Nav_Attack is on a distinguished road
that seems unlikely to help too much.. maybe if you wrote a program to average the position of the two, you'd get a slightly more accurate reading on where you are.. but i've found it to be fairly accurate for the most part.
for boosted reception, theres a thread floating around somewhere about putting a refridgerator magnet under the receiver for increased reception (aka faster locking)
VIA EPIA 533 MHz
256 MB RAM
7" Lilliput VGA Touchscreen
20 gig HD
Media Engine 2.1.4
GPS - Earthmate/SA2004
802.11b Connectivity
Nav_Attack is offline   Reply With Quote
Old 10-13-2004, 11:12 PM   #6
blackpacu's Avatar
blackpacu is on a distinguished road
I dont think it would make a difference if you had 2 or not
I think quattro is right, they would just look on to the same sats
I also havent seen any gps software that would be able to utilize 2 gps recievers either
If you want to get better reception, i think getting a good reciever would be a better solution
amd 1700, biostar m7ncg 400, hitachi deskstar 120 8mb , 512 pc2700, liliput 7"
now to put it all together
blackpacu is offline   Reply With Quote
Old 10-13-2004, 11:13 PM   #7
Naamanf's Avatar
Naamanf is on a distinguished road
Actually more receivers will give you a more acurate position, but you would have to have software the takes into account the location of each receiver. There are multi-receivers systems that can give position within an inch or so.
2007 Tahoe
Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
My Install
Naamanf is offline   Reply With Quote
Old 10-14-2004, 12:31 AM   #8
Big Zack's Avatar
Big Zack is on a distinguished road
I have two GPS receivers; one built into my laptop and the other is a USB puck.
I have compared reading from two in two different applications, but I am not aware of any standard software (iGuidance, Copilot, SAT, Street Atlas) that will let you use more than one GPS receiver at a time.
-Z
Big Zack is offline   Reply With Quote
Old 10-14-2004, 04:15 AM   #9
Dominik is on a distinguished road
D3 SDK lets you take data from a Buffer which you could fill by reading the GPS data stream yourself. It wouldnt be too hard to read the COM port data from each of the GPS and do some calculations before pushing it into the buffer.
The thing i thought of was to have the GPS doing the readings half a second off synch. thatway you would get GPS signals every 0.5seconds instead of once per second...
Dominik is offline   Reply With Quote
Old 10-14-2004, 04:39 AM   #10
GT65coupe's Avatar
interesting, can you code that?
V8 Powered
Old 10-14-2004, 05:09 AM   #11
See me in my wet t-shirt.
stevieg's Avatar
stevieg is on a distinguished road
the only thing I think would be worth doing would be, if you are writing your own GPS application (or D3 interface, or a 'third GPS com port device') would be to monitor both, and output the reading of the one with the best lock - and if the other one goes tit's up, sending the required reset commands.
Otherwise it's a lot of work for not much improvement
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
stevieg is offline   Reply With Quote
Old 10-14-2004, 05:30 AM   #12
cheap custom title
JC-S60's Avatar
JC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really nice
What would make a difference is putting one at the windshield and another at the back window. That way, the complete sky would be "visible" and locks would be to different sats.
Joa
JC-S60 is offline   Reply With Quote
Old 10-14-2004, 06:07 AM   #13
Raw Wave
Confused's Avatar
Confused is on a distinguished road
Good thinking, batman!
I'm going to grab my GPS receiver, and along with Danceheaven's, i'll see if i can figure anything out
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 10-14-2004, 08:07 AM   #14
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Garry
Sounds kinky
Enforcer is offline   Reply With Quote
Old 10-14-2004, 08:49 AM   #15
Raw Wave
Ricky327
You are better off buying an external antenna (if your GPS have the connector for it) :
http://www.maplin.co.uk/Module.aspx?...dID=&doy=14m10
Placing 2 GPS one at the back and at the front will only give you like the average position in the middle. If the signal are weak in the area both GPS wont be accurate anyway.
Its probably worth a try if you got access to 2 GPS and the program to average out the position.
Ricky327 is offline   Reply With Quote
Question on Garmin 16 GPS receiver cproaudio GPS 19 05-23-2008 02:32 AM
what to look for in a GPS receiver? doublestack GPS 7 10-01-2004 04:05 PM
Dual GPS Rcvr's. Unusual thought... d_sellers1 GPS 13 06-21-2004 08:26 PM
CoPilot Software or USB GPS Receiver package Zip-Lock Classified Archive 5 05-13-2004 08:30 AM
$69 12 channel GPS receiver - anyone tried this one? LCDcrazy General Hardware Discussion 0 09-05-2001 01:50 PM
