Old 10-24-2004, 01:08 PM   #1
Destinator 3 UK maps
Did anyone else notice that the UK and Ireland maps downloaded from Miomaps are missing all the town names in Scotland
Steve
RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
Webmaster for the European Ford Scorpio Site
SteveC is offline   Reply With Quote
Old 10-24-2004, 04:05 PM   #2
Proplus's Avatar
Fine by me, don't ever venture that far north!!!
Proplus is offline   Reply With Quote
Old 10-24-2004, 04:35 PM   #3
See me in my wet t-shirt.
stevieg's Avatar
Steve
Yeah they have the wrong names for loads of roads too, and a useless POI database. Only thing they're useful for is proving it works before shelling out for the PPC Destinator (75 quid!)
Ford Focus MP3 : www.stevieg.org/carpc
Car PC Status: COMPLETE
stevieg is offline   Reply With Quote
Old 10-24-2004, 05:32 PM   #4
Are the miomaps as good or worse/better than the UK full destinator 3's ones that you get when you buy the original ppc software?
matty_g is offline   Reply With Quote
Old 10-25-2004, 02:58 AM   #5
Raw Wave
Confused's Avatar
Worse. By a LONG shot.
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 10-25-2004, 07:43 AM   #6
Thanks mate you are a wealth of knowledge, I better be buying it then!!!!
Old 10-28-2004, 01:50 PM   #7
Question
Hi
I was using the UK map from Miomaps and I was also really frustrated about the Scottish place names, but after reading this thread switched to the original ones.
However, now when I approach a roundabout instead of getting the usual "continue driving around the circle" directions I get - "Turn Right followed by Turn Left" or other variations, as if it wasn't actually a roundabout. Even though looking at the map it clearly is.
Any ideas? Have I done something wrong? Is this happening with anyone else? Or do you think my maps are corrupt..?
BTW I'm testing in and around Fife and Edinburgh, no roundabouts worked...
David
djrichardson is offline   Reply With Quote
Old 10-28-2004, 02:47 PM   #8
Rub One Out
Motoko's Avatar
I get the same thing too. Really annoying
CarPC status: iPod, 3,456,217 songs so **** you
Motoko is offline   Reply With Quote
Old 10-28-2004, 02:51 PM   #9
FreeDrive Creator
CdRsKuLL's Avatar
I'm running the proper D3 maps and also the D3 uk voice pack that comes with D3 for the pocket pc, I dont have any problems with roundabouts at all. I would suggest also moving the voice pack over from the PDA version to see if the helps.
cheers
CdR
www.extremeoc.co.uk me building a murcielago kitcar ! - check it out !
www.cellsecurity.co.uk are my new employer ! - yeah I got a job !
CdRsKuLL is offline   Reply With Quote
Old 10-29-2004, 02:44 AM   #10
stevieg's Avatar
cheers
CdR
Same here
Old 10-29-2004, 10:25 AM   #11
cheers
CdR
Hi
I gave that a try but it's still doing the same thing. What's the version number of the map you're using? Mine is 2003.Q2.2071, maybe I'm using a bad map...
Old 10-29-2004, 11:51 AM   #12
Raw Wave
Laidback's Avatar
Don't forget that DestinatorVoiceManeuvers.inf, or whatever it's called, also tells it which wav file to use!
Edit: Although, that should come with the voice pack....Did you swap to the new voice pack in settings?
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 10-29-2004, 07:30 PM   #13
I dont think it's anything to do with the voice files...
This is the manoeuvre list from my house to the local ASDA using the Miomap one:
And here's what happens with the one's from the destinator CD (exact same route - including roundabouts)
The 2D and 3D maps on screen are identical - both include roundabouts
Any ideas?
David
Old 11-03-2004, 06:46 PM   #14
Question
Bump!
Hi Again,
So is anyone else having this problem or is it just me? The Miomap ones are crap for placenames and POIs but at least roundabouts work. The original Destinator 3 ones have accurate placenames and road names but wont navigate roundabouts correctly.
I have tried completely reinstalling everyting (and have used all the original files from the CD - including voice files)
Is there anyone out there using the Destinator UK maps with success? If so what is their version number?
Any help appreciated..
David
Old 11-04-2004, 01:28 AM   #15
Map Monkey Creator
Ninja Monkey's Avatar
Quote: Originally Posted by djrichardson
Bump!
Hi Again,
David
This is a known problem... http://www.pocketgps.co.uk/modules.p...1d743dd4728b67
Unfortunately it's been fixed in the pocket pc version (doubtful the SDK will see any changes any time soon)
Seeing as the MIO maps work...I'm thinking you can make a decent map from both...
Try making a new folder and copying the following files from the MIO uk map
WCE_A.POI
WCE_A.MAP
WCE_A.TAB
then copy the following from the PPC UK map
WCE_A.DAT
WCE_b1.DAT
WCE_b2.DAT
Let me know how you get on
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Victoria (Australia) Maps with Oziexplorer? NiN^_^NiN GPS 12 08-26-2008 06:37 AM
Found a UK LCD supplier who has no minimum order Skraggy_uk LCD/Display 20 03-08-2007 11:21 AM
desperate for desinator 2 uk maps chris-uk MediaCar 5 04-17-2004 12:23 PM
Destinator uk maps chris-uk MediaCar 6 01-16-2004 08:47 AM
HELP!! I need prices of parts in the UK to buy from the UK percys General Hardware Discussion 4 10-05-1999 03:51 PM
