Old 10-25-2004, 06:51 PM   #1
Adding POI's on the fly (speedcams)?
Is there a small utility out there that can store the current position and speed into a textfile (or something) for later use ?
Over here the speedcam databases are few and old and since I travel a lot
by car it would be nice to be able to add/refresh the info.
/M
Maximus is offline   Reply With Quote
Old 10-25-2004, 09:31 PM   #2
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
That's a great idea. Ninja monkey might be the best for doing this.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 10-26-2004, 12:36 AM   #3
aguila's Avatar
yes nice idea
MII 6000; 256 MB; lilliput touchscreen; 40GB; bluetooth SE 68i; software still experimenting switched from mediacar to frodopayer, phonecontrol, destinator 3 (NM), and others.
http://www.mp3car.com/vbulletin/show-off-your-project/31991-audi-tt.html
aguila is offline   Reply With Quote
Old 10-26-2004, 04:05 AM   #4
Raw Wave
Laidback's Avatar
D3, you just click the map and favourites!
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 10-26-2004, 04:41 AM   #5
Bravellir's Avatar
If only that menu could be a little larger!!
Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
Status -->
Lilliput Installed (not indash yet..)
BraveCar 2.5
Bravellir is offline   Reply With Quote
Old 10-26-2004, 12:30 PM   #6
Map Monkey Creator
Ninja Monkey's Avatar
Interesting...
So just a button on the menu that when pressed will import your current Lat and Long into a CSV?
Ninja Monkey is offline   Reply With Quote
Old 10-26-2004, 12:51 PM   #7
Raw Wave
Laidback's Avatar
True, maybe in an ini file?
Laidback
Laidback Carputer
Old 10-26-2004, 12:54 PM   #8
Raw Wave
Laidback's Avatar
Quote: Originally Posted by Ninja Monkey
Interesting...
Edit: Not a CSV but a DAT file! Or of course you could open a text file and write any format you want.
You could easily add a button to yours...
Code:
Dim dis As DESTDLLLib.DestPoint Set dis = New DESTDLLLib.DestPoint Set dis = d.GetCurrentCarPosition dis.Description = "Whatever" Dim fName As String fName = "Auto Alert 1" d.AddPointToFavoritFolder fName, dis
Laidback
Laidback Carputer
Old 10-26-2004, 02:54 PM   #9
Netstumber and destinator
Is there anyway of dynamically adding POI to destinator from an external script. Netstumbler now supports scripting, I wonder if it would be possible to add wifi hotspots to destinator as POI dynamically - cool.
deeja is offline   Reply With Quote
Old 10-26-2004, 02:59 PM   #10
darkhalo's Avatar
i like where this is going...
Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
S2000 Carputer
darkhalo is offline   Reply With Quote
Old 10-26-2004, 03:14 PM   #11
You really don't want to be fiddeling with menues driving 65mph.
I made a small app in VB today using Ninj's winsock interface so that when you press any key at all it saves the current position (long/lat) and location (streetname). The only thing missing is a possibility to read the current speed and perhaps heading (if possible) through the winsock interface.
Considering it was a 10min "hack" before I left work (so I could test it on my way home) it worked out pretty good.
Personally I'd prefer the CSV approach since it would be a lot easier to share POI's.
It would also be easier to edit the POI's before you import them to Destinator (or whatever program you'd like).
/M
Old 10-26-2004, 03:18 PM   #12
Raw Wave
Confused's Avatar
This is already implemented in the current dev. build of AIMEE
Really simple to use, even at speed
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 10-26-2004, 04:00 PM   #13
Raw Wave
Laidback's Avatar
I can't see a way of doing this.....yet!
Laidback
Laidback Carputer
Old 10-26-2004, 04:09 PM   #14
And where do I download it ?
/M
Old 10-27-2004, 08:40 AM   #15
Goose's Avatar
yes where?
Goose is offline   Reply With Quote
Texas Adding Wi-Fi To Highways Confused General MP3Car Discussion 4 06-11-2004 03:57 AM
