Old 10-31-2004, 09:38 PM   #1
Splitting Serial
I need to provide GPS data to a laptop and an APRS tracker simultanously. I don't really want to have to buy a second GPS. Can serial be split into two serial connectors in parallel? Is there an interface on the market that can do this?
August is offline   Reply With Quote
Old 10-31-2004, 11:26 PM   #2
blurp's Avatar
http://www.mp3car.com/vbulletin/show...t=serial+split
Come on, guys, for 2 seconds before you post a question like this.
www.bradleyjacobs.com
There is more stupidity than hydrogen in the universe, and it has a longer shelf life. -- Frank Zappa
blurp is offline   Reply With Quote
Old 11-01-2004, 01:56 AM   #3
danon's Avatar
wow, thx for the link!
[....99.9%]
[HW] 566eMHz/128mb/6gb, FlyVideo3k, RandMgps, M1-ATX, 7" Lilliput, VGA2AVadptrFor2ndVideo, 4CH/100rms, 10"Sub, 40AhDeepCycleTank
[....99.8%]
[SW] XP/MMC/FP:D3,FlyTV/AxifeFM,CarMM?
[Working on] puttingBackEvrythg.
danon is offline   Reply With Quote
Old 11-01-2004, 02:05 AM   #4
Virtual com ports have nothing to do with my question. I don't need two software applications to access the GPS; I have two devices that need to access the GPS.
Old 11-01-2004, 02:22 AM   #5
you can't, you would risk blowing the 2 devices since each puts out current. Even if you would work around the current issue, one device would confuse the other since one might send a specific request to the GPS that the other did not expect. Serial is a protocol between 2 devices, that is the short answer.
kingtut is offline   Reply With Quote
Old 11-01-2004, 02:24 AM   #6
zPilott's Avatar
does the gps receive data from the PC, or is it only one way? If the gps is expecting config data from the PC, I think you might have trouble if both are trying to send something out.
If the gps is sending only you might be able to try something like this:
http://www.airborn.com.au/rs232.html#monitor
|V1 Virtual Display|
Hard work often pays off over time, laziness always pays off right now.
zPilott is offline   Reply With Quote
Old 11-01-2004, 02:29 AM   #7
zPilott's Avatar
another option might be to run a null modem cable from the first pc to the second, and somehow propagate the data across, so that the second device would think it is connected to the gps, not to a pc.
|V1 Virtual Display|
Old 11-01-2004, 04:14 AM   #8
I found this in a PDF manual for a Ratheon GPS.
Quote:
When using the NMEA 0183 format, the Raystar 112 can provide data
for at 2 or more navigation equipments when connected in parallel. Be
sure that all devices connected to the data output ( plotters, video
sounders, radars) are programmed to use the NMEA 0183 data format.
WARNING: Do NOT GROUND the Data, Data return lines, or the
Shield of the interface cable at any of the external navigation
equipments.
The ability to do this must be part of the NMEA standard. Any thoughts?
Old 11-01-2004, 04:19 AM   #9
Raw Wave
Laidback's Avatar
If you're just reading there's no problem.
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 11-01-2004, 12:12 PM   #10
Raw Wave
I though as much but relax man.
Heres your solution :
GPS <---> PC ( Normal 2 way using RX/TX, can read and write to GPS )
: -------> Another device (1 way using the TX line of the GPS, device can only read)
Dont forget the GND for both PC and other device.
Ricky327 is offline   Reply With Quote
Old 11-01-2004, 12:19 PM   #11
Raw Wave
Dont think so, but you can try to solder 2 wires that connect to the TX and GND of the serial connection of the GPS...and connect this to the "READ ONLY" device.
If this doesnt work properly due to the TX line being loaded with 2 devices then you may need to add a MAX232 chip to boost the signals and split them to 2.
Old 11-01-2004, 05:58 PM   #12
blurp's Avatar
Read post 14 on the thread I linked to above. And I stand by my original comment. !!!!
Old 11-01-2004, 07:31 PM   #13
zPilott's Avatar
The max232 is for converting 5V TTL (1 is +5V, 0 is 0V) to the voltages for rs232 (1 is -15V, 0 is +15V), its not gonna help with this problem
|V1 Virtual Display|
Old 11-01-2004, 07:38 PM   #14
Raw Wave
No I meant...
GPS ----> RS232 > TTL > RS232 > PC
:--------> RS232 > TTL > RS232 > Other device
The MAX232 contains 4 converters, and can be wired up to buffer the signal from the GPS before feeding them directly to the 2 devices.
It converts the RS232 down to TTL and then to RS232 again
If that can help I dont know, but its just a mean of buffering the signals before sharing ONE signal by the 2 devices.
Old 11-01-2004, 07:43 PM   #15
Raw Wave
No...the MAX232 have more than that.
It contains 2 x RS232 > TTL converter
and 2 x TTL > RS232 converter
97 Toyota Tacoma You gotta See This. NEW UPDATE with 100+ pics on 7-4-03 cproaudio Show off your project 97 09-18-2006 02:56 PM
USB Serial Port Adapter Troubles bLindmOnkey General MP3Car Discussion 0 10-14-2004 12:29 AM
Bad Serial Ports on EPIA M9000 wi77iam General Hardware Discussion 6 05-06-2004 12:49 PM
USB to serial Sleeka General Hardware Discussion 2 12-24-2002 04:55 PM
Via Mini-ITX Epia 5000 serial port not working vash General Hardware Discussion 2 08-13-2002 09:48 PM
