Quote: Originally Posted by Sonicxtacy02
I upgraded from routis 2004 to iguidance 2.0 assuming it would do the following this for me that i've seen people talk about on this board
* Mute the music when giving voice directions
*provide easier to understand voice directions
I'm not sure if Iguidance actually mutes the music. I think I remember reading that people were adjusting the winamp preamp down and the wave volume up so that the voice could be heard over the music. The Destinator 3 Frontend will actually mute music playback-I'm not sure that Iguidance does. Sounds like the voice directions aren't working like they should-maybe a problem with Iguidance and your soundcard. I'd contact Iguidance to see what they say:
http://www.inavcorp.com/ Have they sent you the theme.ini file to tweak colors and font sizes? I've seen some of the changes that other users have made to make the maps a little more readable-definately work looking into when you get the file. Another place to ask where I've seen them respond is over at gpspassion.com in the Iguidance subforum:
http://www.gpspassion.com/forumsen/d....asp?CAT_ID=12
Good Luck-I hope you get this sorted out.
