Old 11-10-2004, 08:14 PM   #1
how do i know if waas is working
I have had the rikaline 6010 for about a month now and it seems to do a great job. It is supposed to have waas but i cannot tell whether or not it is working. Is there a way to find out with iguidance or the sirf demo software, i would really like to know if i'm actually getting a waas signal.
Brett
EPIA MII-1200, 512 MB Ram, Seagate 7200 RPM 160GB hard drive, Orinoco Gold with 5.5 dB external antenna, Lilliput 7" TS, DVD-ROM, M2-ATX, Rikaline 6010 GPS, Running Frodo Player
My Truckputer
bbrother is offline   Reply With Quote
Old 11-10-2004, 08:42 PM   #2
hd54321's Avatar
Not sure if it would work with your receiver but do a google search for the program called crux_view.exe (or some derivative of this name). The program allows you to control the settings of your GPS receiver. I use this program to monitor data activity on my bluetooth gps unit. It monitors your COM port for the receiver so I'm not 100% sure it would work with USB receivers.
I would strongly warn against changing any of your receiver's settings as it may kill your unit. I changed some WAAS setting a while ago on my bluetooth unit and i had to crack it open, disconnect the battery and wait a few days before being able to reuse it.
Also, I have heard that WAAS isn't such a great thing. Do a quick read-up at gpspassion.com on the pros/cons of WAAS.
-HD
hd54321 is offline   Reply With Quote
Old 11-11-2004, 09:33 PM   #3
Raw Wave
If your GPS program shows you the signal strength of the received satellite normally they would also have the satellite number labeled on each bar.
WAAS satellite are numbered 33-51 if I remember it well. SO if you can see anything 33 and above then you are getting a WAAS. Anything below 33 are the normal ones.
Try this software :
http://www.visualgps.net/VisualGPS/default.htm
On the top left of the screenshot you can see the satellite number below the blue signal bar :
http://www.visualgps.net/VisualGPS/screenshot.jpg
Ricky327 is offline   Reply With Quote
Gps Module + External Antenna + Waas + Usb e_z_street GPS 3 10-06-2004 04:57 PM
A little explaination of GPS, WAAS and using Routis carpcnoobie GPS 1 06-28-2004 08:34 PM
Lilliput Touchscreen not working jjc319 LCD/Display 5 02-01-2004 05:37 PM
motorized screen stopped working :( corsamel LCD/Display 0 11-26-2002 11:52 AM
Got GPS 16 working tekknikal General Hardware Discussion 9 06-16-2002 07:55 PM
