Old 11-22-2004, 03:49 PM   #16
MySQL Error
MatrixPC's Avatar
The evolution of how we get the Earthmate USB to work with Routis.
http://www.mp3car.com/vbulletin/show...=USBEMATE1.exe
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 11-22-2004, 04:30 PM   #17
rgardjr's Avatar
Did you ever get the USB hibernation issued sorted out?
'03 Sierra Denali
rgardjr is offline   Reply With Quote
Old 11-22-2004, 04:42 PM   #18
MySQL Error
MatrixPC's Avatar
Hibernation work about 90-95% of the time that is when Routis is running and go to hibernation. Just click reconect "reconnect GPS" icon in Routis then it is fine.
If routis is not running or off before going to hibernation, it works 100% of the time. No other software/trick/method is needed.
Well, not exactly "no trick". The trick is that the GPS have to be on it own USB port. Meaning that if I have the USB WiFi plug in the same hub the GPS is, it only work 10% of the time if Routis is running and going to hibernation.
So I have 2 4-ports hub (1.1 and 2.0). 1.1 hub I just use for GPS and mouse/trackball. The 2.0 hub for all other USB stuff.
And my PSU/Sproggy completely cut power when off/hibernate.
Old 11-22-2004, 07:31 PM   #19
muldrick's Avatar
Quote: Originally Posted by masher
yes its listing as DeLorme Earthmate GPS COM so everything is right. And i have installed the 3rd party driver thats why i am clueless on why it wont work. Another ideas.
yes i stay up late. I am college student so actually that was quite early.
Get rid of that 3rd party driver. Why do you need that if you installed the delorme driver?
Then if that don't work, get rid of all drivers, and start over. But only install the delorme driver.
Did you read Matrix's post on the "evolution". Did that help?
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 11-22-2004, 07:46 PM   #20
MoFo's Avatar
Try this and don't forget step #4 :http://www.mp3car.com/vbulletin/show...8&postcount=14
MoFo is offline   Reply With Quote
Old 12-11-2004, 07:18 PM   #21
I have done everything that all of those threads have said to do and I still cant get it to work. Still works fine in Street Atlas. Would getting a USB to serial convertor help?
masher is offline   Reply With Quote
Old 12-11-2004, 07:28 PM   #22
muldrick's Avatar
The Delorme driver has the USB to serial converter with it.
Unless you are talking about a usb to serial convertr wire/plugs? No, shouldn't have to get that.
I did remove SA2005, but I don't think you have to do that either.
Old 12-11-2004, 07:47 PM   #23
I think that might have finally done it. Just had to remove SA its kinda of working now. Not picking up enough satelittes but i live in an apartment complex. Will try tomorrow and put it back into my car but its finding the gps on the com port so its working. thanks for all your help.
Old 12-12-2004, 08:30 PM   #24
muldrick's Avatar
Weird, don't see why removing SA fixed it. So long it wasn't running at the same time, iGuidance should've worked fine.
Let us know how well you've got it working.
I was thinking about re-installing my SA because the POI's are handy, I'll let you do it first ?
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Will Delorme USB GPS work with Copilot7? DLe GPS 12 09-06-2004 07:34 PM
CoPilot Software or USB GPS Receiver package Zip-Lock Classified Archive 5 05-13-2004 08:30 AM
FS: Delorme Earthmate USB + Two 802.11b NICs Kessler Classified Archive 3 08-14-2003 12:47 AM
GPS Receiver - USB -vs- Serial Daz GPS 6 06-24-2003 05:56 PM
