Old 11-25-2004, 03:49 PM   #1
techy101's Avatar
Earthmate just started sucking at nights
Hey, I was just wondering if anybody else has had this problem. Over the past three weeks or so my earthmate has seemed to become possessed. During the day i get great signal, 6-8 sats avg. But once the sun goes down, i loose most all of my signal, and it only tracks for about 40% of the time, the rest of the time i get a bunch of grey, yellow, and red sat. status icons. Any idea's???
techy101 is offline   Reply With Quote
Old 11-25-2004, 03:52 PM   #2
Yuriy's Avatar
No, but you could try changing your GPS receiver or relocating it.
00 Saturn SL2, boosted @ 8 psi - CarDomain
Newest install - my quickest ever
My 2nd carputer - b4 I broke the touchscreen
My very first carputer - voted the most ghetto
Yuriy is offline   Reply With Quote
Old 11-26-2004, 11:13 AM   #3
MySQL Error
MatrixPC's Avatar
When it cool out side, it take forever to lock at the sat, and if it does, only 3 or 4.
During the day, when it warm and sunny, it was able to lock into 9+ sat.
The problem I think is too much overcast (if that the word)
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 11-26-2004, 06:54 PM   #4
doo you have window tint or a factory tinted glass ? - if so, it may interfere more in the dark .
finnman925 is offline   Reply With Quote
Old 11-26-2004, 06:59 PM   #5
NRGZ28's Avatar
Mmm we're talking about radio waves here, not light transmission Really doubt the GPS receiver cares too much about how much light can go through your windshield
K301 7" Motorized Screen
Mini SLIMPRO SP625 Cappucino PC
RoadRunner / IGuidance 3.0
Pioneer 7700MP HU
MTX 1500D 1500 Watt Sub Amp
2 x 12" MTX 8000 subs
1998 Olds Aurora 4.0 V8
NRGZ28 is offline   Reply With Quote
Old 11-26-2004, 07:00 PM   #6
MySQL Error
jcdillin's Avatar
not if the tint is reflective. I have had it reduce gps signal many times.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 11-26-2004, 07:01 PM   #7
My Village Called
0l33l's Avatar
Ok..... GPS uses radio signals... if these signals pass through the glass during the day, what makes you think they won't pass the same window at night?
Maybe the problem is clouds, different area, heading in a different direction?
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 11-26-2004, 07:10 PM   #8
carpcnoobie's Avatar
Where is the GPS located??? Is it in the back window or under glass? I agree.. it's a radio wave.. it doesn't care if it's light or dark out. Just wondering if anything else is interfering. Dash lights, window defroster, some EMF field? Etc.
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
carpcnoobie is offline   Reply With Quote
Old 11-26-2004, 08:02 PM   #9
Change's Avatar
Some window tint is made from metallic particles, so that can attenuate the signals passing through it. That wouldn't cause the unit to fail at night though, unless there's heavy cloud cover attenuating the signal further...even then, I think they would have to be some pretty heavy clouds...just for kicks, try holding the Earthmate outside of the vehicle at night and compare it to when it's inside the vehicle.
Change is offline   Reply With Quote
Old 11-26-2004, 11:25 PM   #10
Clover
Grayscale's Avatar
what about humidity? does it get more humid at night maybe, causing it to refract the signals?
CarPC install is starting to come along again...
Grayscale is offline   Reply With Quote
Old 11-27-2004, 03:31 AM   #11
techy101's Avatar
As for as the weather, it's crystal clear at nights. and I haven't had this problem until about a few weeks ago as i said. Before that it has been working perfectly at nights. The only difference is that the overall temp has dropped. I have never had any problems with it in bad weather. It is located right up under my dash, almost up against the windsheild, and most of the way to the passenger side door. If that makes any sense.
Old 11-27-2004, 04:09 AM   #12
GruvThang's Avatar
wasn't there a similar thread about this? But I think that guy lived in CA
[color=Navy][size=1][font=Comic Sans MS]Tektility
GruvThang is offline   Reply With Quote
Old 11-27-2004, 04:12 AM   #13
GruvThang's Avatar
http://www.mp3car.com/vbulletin/general-hardware-discussion/36994-paint-gps-locator.html this is the one
Old 11-27-2004, 06:14 AM   #14
I'm sorry, and you are....?
frodobaggins's Avatar
It's not that far fetched an idea. The metal in the window tint will have
different properties when it's warm, than when it's cold. Could be enough
to **** with it. I doubt it, but you never know. Try heating up the window
while stopped with your defroster on heat. See if it makes any difference.
Frodo
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 11-27-2004, 03:47 PM   #15
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
I've seen a similar issue with mine (not Earthmate) at night. It locks great in the mornings but takes longer and seems to track fewer satellites at night. I just thought it had something to do with the position of the satellites in the evening vs. the morning.
Moving the GPS to a more prominent location gave me reliable results but still fewer satellites lock in the evening.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Earthmate not weatherproof need help veetid GPS 41 11-01-2005 10:40 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 10:44 AM
Possible help for USB Earthmate and Routis/IGuidance rgardjr GPS 21 06-30-2004 01:17 AM
Warning... crazies ahead. ddt Off Topic 57 05-11-2004 11:06 PM
Earthmate only locks when GPS Software is running nodeel GPS 5 01-04-2004 09:43 PM
