I have a BU-303 and when I use it in conjunction with Mappoint 2004, perfomance is really horrible. Map refreshes are way too long, my position cursor disappears for a good 5 seconds sometimes, and Mappoint itself seems slow to use (ie, searching for POIs). Running AGPS with Mappoint results in waaaay lagged turn directions and very choppy voices. It's plain unusable.
But I plug in my Garmin Rino 110 with a serial cable, and Mappoint runs as smooth as butter.
I suspect that maybe the USB to Serial driver is bogging down the system when the BU-303 is in use. My system is a AMD K6-2 400mhz laptop with 128mb of ram running Win2k.
Any ideas besides chuckin the antique laptop and spending money on something faster?
edit: My title is mistyped. The Garmin is plugged in with a serial cable into a 9pin serial port on the laptop, NOT USB. The BU-303 is plugged into a USB port.
Edit: The port settings for the bu-303 are at 4800,8,N,1. I even tried updating the Prolific drivers to 2.0.0.26 (was at 1.4 before) with no improvement. I only have one USB port on my laptop so I can't try another port. I can't think of anything else to try
-patchy
