Closed Thread
Old 01-25-2005, 01:02 PM   #226
carpcnoobie's Avatar
Wow, that really set it off just right. A lot better with the color. Any chance of getting the bitmaps on the 'set destination' screen? Sorry I didn't ask the first time.
Thanks again.
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
carpcnoobie is offline
Old 01-25-2005, 02:18 PM   #227
fantomas's Avatar
can't post exe's. this was mentioned a few pages back if i remember correctly.
rebuilding carpc... kinda..
fantomas is offline
Old 01-25-2005, 02:22 PM   #228
dodgetimes2's Avatar
Thanks again.
Yep.
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
dodgetimes2 is offline
Old 01-25-2005, 04:14 PM   #229
Quote: Originally Posted by rando
Sorry I came late to this thread and just skimmed it. Instead of copying/creating the entire theme.ini mentioned in the thread, I just created a theme.ini with just the font line in it (STS=20 20 20 20 20 20 20 20 20 20 20). That seemed to expand the fonts nicely without tweeking anything else. Now if I can just get my hands on a nice patched EXE with bigger buttons -- I've got no problems using resource editor but drawing isn't my deal. Perhaps the updated buttons were posted/burried in this thread?
hey Rando,welcome to this thread check on this PAGE post 133-134, i posted my exe with all the big buttons i can do.....now the BIG problem is that we can add the "BIG" icons but the control area still stays the same, ex.look on the link i gave you above, post 135 - you see the menu & volume button on the left - they are big and nice on a 7" screen, but when you touch the icon the "touch area" is still only the default small icon size - follow me?
Also this happens with the keyboard, i think its hard coded - anyway you can get this working........PLEASE HELP US
Now the theme.ini file you created with just the font line in it - does this change the fonts though out the whole program(all menus, etc..) also does it change the fonts on the keyboard?
camsgs3 is offline
Old 01-26-2005, 03:25 PM   #230
clean customs's Avatar
Ive downloaded the rar files with the EXE files. I know they are suppose to work together, but all I am getting is file extraction from the rar extracting tool I am using. Im using WinRAR, and one time it asked me for the other file, but now, it just lets me extract an exe. And that exe won't work when I paste it in. I get errors and iNav won't start up. Any suggestions?
These are teh files I have
iGuidance[1].part1.rar
iGuidance[1].part2.rar
I put my scheme.ini file in, and that works, but I can't get the bigger icons which I really want.
help me please
Round VIII - [IIIIIIIIII] 30% Have some parts for 300zx Sema car I don't own yet. Will have 10.4" & 7" screen, and more then you can believe. Will add updates to cleancustoms.com, will be sweet. My car is still same, but might change.
clean customs is offline
Old 01-26-2005, 10:39 PM   #231
Quote: Originally Posted by dodgetimes2
Yep.
Thanks again. That really set off my project. Like the color icons so much better. Eventually I'll have to give up and go with iGuidance unless someone figures out a way to update Routis with iGuidance 2 <HINT HINT>.
Progress Meter:
Old 01-28-2005, 06:19 PM   #232
Wow, haven't been here in a while. Glad to see people are still working at it.
99 VW GTI VR6 SC
-The GTI-PC-
Nanozic is offline
Old 01-29-2005, 11:30 AM   #233
I've looked through the entire thread and atually tried to use those .exe's posted. Could someone just say where the Menu button in the bottom left is? Or what .bmp it is? As well as the speed in the bottom right? Also any idea on how to get the keys bigger like when you enter in a street name?
PDiddy is offline
Old 01-29-2005, 11:55 AM   #234
The Menu button is not worth changing because it doesn't change the "control area" when you make the bmp bigger, this goes for the keyboard keys as well. The speed is not an editable resource.
Old 01-29-2005, 12:23 PM   #235
Cool thanks. I had read that it doesn't enlarge the "clickable" space but also read somewhere through this thread that if you enlarge the transparency on the .bmp then it does. Maybe I misread that.
Also any files out there that'll increase the Menu items with the text? I changed my theme.ini as well as someone posted in this thread to change the font size to 10 to 14. That seemed to work for the streets and all but not menu options.
Thanks again guys.
PDiddy is offline
Old 02-03-2005, 04:17 PM   #236
wysocki's Avatar
iGuidance VS Routis
I've read this thread about ten times and I'm still very confused as to which of these hacks applies to Routis or iGuidance. I thought they were the same program. I have Routis and really want bigger fonts for the street names. I setup the theme.ini but it didn't do anything. Can someone explain the differences?
wysocki is offline
Old 02-03-2005, 04:21 PM   #237
Sorry man but I'm pretty sure the theme.ini stuff only relates to iguidance.
Someone please correct me if I'm wrong.
wizawuza is offline
Old 02-03-2005, 04:41 PM   #238
http://www.mp3car.com/vbulletin/show...5&postcount=26
Progress Meter:
Old 02-03-2005, 05:24 PM   #239
wysocki's Avatar
Quote: Originally Posted by WhiteRabbit
I forgot to mention I use routis. the bitmaps should work nicely, I dont know if the numbers will match up in the resource hack software.
So then guys like whiterabbit are using Routis and only changing the icons with ResHack but not changing the font sizes?
wysocki is offline
Old 02-03-2005, 06:50 PM   #240
yep! I havent touched theme.ini cause of that post. all Ive been doing is swapping bitmaps with resource hacker
WhiteRabbit is offline
Closed Thread
IGuidance 2.0... WOW unsavory GPS 217 04-20-2005 02:14 AM
[Dest3 skin] How to change font size velocity? _wd Map Monkey 1 11-17-2004 07:46 PM
Embedded iGuidance Window Size? All4Sky MediaCar 3 08-27-2004 09:00 AM
winamp and play list font size???????????? donalson Software & Software Development 12 02-28-2001 08:40 PM
changing font size of file names in Windows Explorer? Squeezer General Hardware Discussion 4 01-11-2001 05:49 PM
