Closed Thread
Old 02-04-2005, 11:57 AM   #241
carpcnoobie's Avatar
Quote: Originally Posted by wysocki
So then guys like whiterabbit are using Routis and only changing the icons with ResHack but not changing the font sizes?
Correct. Same thing I'm doing. Trust me, if theme.ini worked, I would have said it a long time ago.
Like I was saying before. I would love to see if someone can get Routis and iGuidance married.
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
carpcnoobie is offline
Old 02-17-2005, 09:41 AM   #242
MySQL Error
Sonicxtacy02's Avatar
hate to wake this thread up from the dead but i just read all 17 pages and actually spent some time workin thru the resourse hacker and theme.ini . I have two questions. First.. is there any way to change the color for water? Its a little too close to the background color for my taste. I'd like to make it a sky blue or so. Second question. I havent used iguidance in awhile but i seem to remember that highways had a different color than regular roads. When editing the theme.ini file i really didnt know which NMPRC represented which type of road so i made them all the same color. Which NMPRC is the highway? I'd like to change it back. Thanks!
Sonicxtacy02 is offline
Old 03-22-2005, 09:34 PM   #243
ysutarko's Avatar
can ne1 make the skin for the iguidance?? bigger fonts, bigger icons
thank you kindly
ysutarko is offline
Old 03-29-2005, 02:23 AM   #244
archimense's Avatar
So after not being able to get access to the theme2.ini, I decided to use a hex editor to see what hard coded strings were in the exe. So here is the total list of codes that the iGuidance v.2 exe appears to be reading from the theme.ini file. Some of them have been talked about before, others it will probably take some testing to figure them out.
MZL - ?
FZL -?
NMRC - guessing - night map road color
DMRC - guessing - day map road color
NFC - ?
DFC - ?
NPT - ?
STS - known- street name font size
NPW - ?
STW - ?
MSR - ?
AZLC - ?
NGRDC - known - night guidance road color
DGRDC - known - day guidance road color
GRDPW - ?
RTPW - known - route pen width
STC - ?
BNCA - ?
SBC - ?
RTC - known - route color
NMRBPC - known - night map road border pen color
DMRBPC - known - day map road border pen color
NMRPC - known - night map road pen color 0 -10
DMRPC - known - day map road pen color 0 -10
MBC - known - map background color
GRPW - known - guidance screen road pen width
MDFC - ?
RPW - known - road pen width 0 - 10
Jetta Install Photos
Audi S4 Worklog
01' Audi S4 Twin Turbo / 00' VW Jetta VR6.
archimense is offline
Old 04-03-2005, 11:03 PM   #245
ysutarko's Avatar
how do you change iguidance background color using theme.ini???
like this
ysutarko is offline
Old 04-05-2005, 09:15 AM   #246
I see dead kittens
Quattro's Avatar
Hey guys check out the thread I started about the SDK for iguidance. With the SDK we can solve all the problems that are stated in the thread that the theme.ini file does not cover.
http://www.mp3car.com/vbulletin/gps/46838-iguidance-sdk.html
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline
Old 04-07-2005, 01:55 AM   #247
SnyperBob's Avatar
Can someone PM me liquid smoke's ini file please? Thanks in advance.
www.mobile-effects.com
Free file hosting, picture gallery hosting for installs, PM me.
Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
SnyperBob is offline
Old 04-07-2005, 07:58 AM   #248
SnyperBob's Avatar
please?
Old 04-08-2005, 09:44 AM   #249
schillrw's Avatar
same here please
2004 F150 Lariat SuperCrew 4X4
Lilliput 7" Mounted In Dash
Via M10000
256MB PC3200 DDR
60gb Maxtor 7200RPM
Sony 16X DVD Drive
schillrw is offline
Old 04-08-2005, 10:03 AM   #250
MySQL Error
ok guys seriously.. its on like 10 pages in this thread. its very simple
read til ya see gibberish
copy the gibberish
paste the gibberish into notepad
save gibberish as theme.ini (NOT theme.ini.txt)
Old 04-08-2005, 10:38 AM   #251
schillrw's Avatar
I have done this and seen no changes. I have the newest version of iGuidance, is that why?
Via M10000
256MB PC3200 DDR
60gb Maxtor 7200RPM
Sony 16X DVD Drive
schillrw is offline
Old 04-08-2005, 11:10 AM   #252
takissd's Avatar
i have done it too on the new iguidance and at the beggining i saw nothing. then i restarted the pc and it all worked out. make sure the file is theme.ini cause sometimes when you edit it it is called and seen as theme.ini but is actually theme.ini.txt
remember to restart and it has to work..
-VIA EPIA M10000/512MB/40GB HD
-DWW motorized 7'
-BU 303 GPS w/iGuidance/ CF
-Opus90w
-Belkin Bluetooth
-Pioneer HU
[||||||||||] 95% done
takissd is offline
Old 04-08-2005, 11:45 AM   #253
ysutarko's Avatar
this is what i got so far
just need to figure out how to change the background to White(Day) and Black(night)
ysutarko is offline
Old 04-08-2005, 11:57 AM   #254
schillrw's Avatar
I restarted once I know but I will try that again. I am very aware that it has to be theme.ini and not theme.ini.txt
Via M10000
256MB PC3200 DDR
60gb Maxtor 7200RPM
Sony 16X DVD Drive
schillrw is offline
Old 04-08-2005, 03:12 PM   #255
takissd's Avatar
sometimes windows hides the extension and it still looks as a .ini file..
but if you are sure about it i guess there is something else wrong. I did the same thing to both mine and my friend's carpc and it worked.
try making a new file and add only
; street name font size in points @ zoom level
STS=20 20 20 20 20 20 20 20 20 20 20
save it as theme.ini and try again... this only makes street font size a lil bigger change the 20 to a bigger number for larger font..
Else i guess i would install Igudance again copy file and try it..
-DWW motorized 7'
-Opus90w
-Belkin Bluetooth
-Pioneer HU
takissd is offline
Closed Thread
IGuidance 2.0... WOW unsavory GPS 217 04-20-2005 01:14 AM
[Dest3 skin] How to change font size velocity? _wd Map Monkey 1 11-17-2004 06:46 PM
Embedded iGuidance Window Size? All4Sky MediaCar 3 08-27-2004 08:00 AM
winamp and play list font size???????????? donalson Software & Software Development 12 02-28-2001 07:40 PM
changing font size of file names in Windows Explorer? Squeezer General Hardware Discussion 4 01-11-2001 04:49 PM
