Closed Thread
Old 04-08-2005, 07:39 PM   #256
can someone pm me the theme2.ini file? come one guys... I know some of you have it. Please share the wealth.
badandy is offline
Old 04-09-2005, 10:32 AM   #257
BMVEE's Avatar
Your specific answer is right here.... this is on a silver platter... I tried it myself.
http://www.mp3car.com/vbulletin/show...50&postcount=9
Okay guys... it's time to try a bit harder. I am not normally one to wave the flag, but in this case... everthing you need is in this thread. I had not done the update myself yet as I had not had a chance and I am here to tell you that it worked for me first attempt. I simply did a cut/paste/save as theme.ini with notepad in the same directory as iguidance.exe and it worked first time. You will just have to try a bit harder, it's no more complicated than that. If it still does not work, your will have to call INav for tech support or try a re-install as there must be something wrong with your installation. This thread is already big enough without more begging.
Sorry... I feel for you guys, but this does work and it is not rocket science...
I suggest using this thread to get your troubles sorted out. Shrillw started it...
http://www.mp3car.com/vbulletin/gps/47183-iguidance-theme-ini.html
Good Luck campers
BMVEE is offline
Old 04-09-2005, 11:09 AM   #258
SnyperBob's Avatar
ok, so what about theme2.ini???
www.mobile-effects.com
Free file hosting, picture gallery hosting for installs, PM me.
Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
SnyperBob is offline
Old 04-22-2005, 05:21 PM   #259
where exactly do i go to edit the theme.ini to increase the fonts that were posted?
DK888 is offline
Old 04-23-2005, 12:59 PM   #260
just open it with notepad and get to the part at the bottom of the file that says
STS=20 20 20 20 20 20 20 20 20 20 20
the 20's are the font sizes. Just so you know this line is all that is in my theme ini file cuz I just wanted the fontsize changed and nothing else.
1997 VW Jetta GLX VR6
old HP MP
PIII 600 or so 256 MB
7" Xenarc
and some plywood holding it all together
My Project
Iatrogenic2 is offline
Old 04-27-2005, 08:25 PM   #261
wysocki's Avatar
I just got my V2.1 installed. Which of these mods mentioned in this thread apply to 2.1 and which to 2.0?
Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
wysocki is offline
Old 04-28-2005, 12:06 AM   #262
My Village Called
0l33l's Avatar
Email them I guess
Does v2.1 work with NaviVoice?
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline
Old 04-28-2005, 12:37 AM   #263
I see dead kittens
Quattro's Avatar
I think the only differenc between v2.1 and 2.0 is that 2.1 has some updated maps. With both versions you should have the theme.ini already included. You can change the settings in the file to get the desired results you want, such as increased street font size. You should also have the theme2 settings in your file which allow you to change geo-features such as body of water, airport, land, etc.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline
Old 04-28-2005, 11:22 PM   #264
wysocki's Avatar
I just installed the 2.1 on a new XP install and there's NO theme.anything file anywhere. Does this file have to be manually created or does 2.1 deliberately prevent anyone from doing any customizations?
wysocki is offline
Old 04-28-2005, 11:38 PM   #265
MoFo's Avatar
If i'm not mistaken there wasnt a theme.ini in v2.0 either. You have to add it yourself and iguidance finds it
MoFo is offline
Old 04-29-2005, 05:28 PM   #266
wysocki's Avatar
Quote:
v2.1 definitely has more features and capability than v2.0. The theme.ini file was created separately specifically for v2.0 users because we only had one map color choice. For v2.1, we added multiple map color themes, and thus there was no need to create a separate theme.ini file. And v2.1/v2.0 customers purchase the product the way is and shouldn't be based on any add'l files/patches fcreated or previous versions of product. In addition, The font size isn't changed from v1.1 to v2.1. Nonetheless, due to some requests from our customers, our programmers are currently looking into the possibility of creating a theme.ini file for v2.1. However, at this point, decision hasn't been made as of today. If there's any updates on this, it'll be posted on our website.
Thank you.
Support Team
The note above was a reply from iNav support. I asked them why the new 2.1 I just bought wouldn't support theme.ini or other customizations. I wonder if you could use the 2.0 for theme.ini support and parts of 2.1 for the map/poi updates?
wysocki is offline
Old 04-30-2005, 11:33 PM   #267
fallnangel's Avatar
i have belkin bluetooth gps software and reciever. i know these are al lthe same program jus different names. the font size fix doesnt seem to work, ne one else experience this?
..and dont back out just because u think its too crazi , i hate pussies
-outdidya
epia m1000,256mb ddr,7"lilli,120gb hdd, Ati remote wonder,400watt inverter,350psu all under xp pro-installed
fallnangel is offline
Old 05-02-2005, 11:31 AM   #268
Now does someone have a solution to make the keyboard and menus bigger like when you click on the "Menu" button. Thats the really tough part as far as entering in an address or finding a Points of Interest. If that screen can somehow be made bigger along with a bigger keyboard, this software would be absolutely perfect!!
PDiddy is offline
Old 05-03-2005, 08:03 PM   #269
Are you f&*(^(ing serious? theme.ini doesn't work with the latest version of iguidance??? WTF is that??? Did they intentionally change it just to **** off people who use the program like us?
Is there any way to make the font bigger in v2.1?
Dont want to disappoint those who only read this far. ctheme.ini does it. Check out the latter pages for more.
A car without turbo is a car with perpetual lag.
My Ride
My New Page
maxxell is offline
Old 05-04-2005, 02:06 PM   #270
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Has anyone tried using the EXE hacker to make changes to Routis?
Damn, Perhaps I should have baught IG 2.0 instead of Routis.
Michael
Wiredwrx is offline
Closed Thread
IGuidance 2.0... WOW unsavory GPS 217 04-20-2005 02:14 AM
[Dest3 skin] How to change font size velocity? _wd Map Monkey 1 11-17-2004 07:46 PM
Embedded iGuidance Window Size? All4Sky MediaCar 3 08-27-2004 09:00 AM
winamp and play list font size???????????? donalson Software & Software Development 12 02-28-2001 08:40 PM
changing font size of file names in Windows Explorer? Squeezer General Hardware Discussion 4 01-11-2001 05:49 PM
