Closed Thread
Old 05-06-2005, 04:47 PM   #271
Raw Wave
justintime's Avatar
justintime is on a distinguished road
If you guys want to make all the windows look more authentic (more 'car pc navigator' like) you can use reshacker, and then do the following to remove the menu bars. (The window's menu bar used to drag windows... who needs that?)
1) Select the dialog
2) Right click dialog window, and select EDIT DIALOG from the contextual menu.
3) On the bottom left, there is a list. Some items will be highlited in yellow. Find WS_DLGFRAME and hilite it.
4) Save compile etc.
You can do this for every dialog. They look much more authentic WITHOUT the windows menu bar!
Screenshot:
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline
Old 05-06-2005, 05:27 PM   #272
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
Great idea, thanks for the info.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline
Old 05-06-2005, 05:54 PM   #273
MGD
MGD's Avatar
MGD is on a distinguished road
You can even make all buttons bigger. Just resize them in res hack.
MGD is offline
Old 05-06-2005, 06:11 PM   #274
I see dead kittens
Quattro's Avatar
but does the control area for the buttons increase as well??
I think thats what been the problem.
Installed
Quattro is offline
Old 05-06-2005, 08:52 PM   #275
Raw Wave
justintime's Avatar
YES, it does increase accordingly. For BUTTONS, it does.
2002 Honda CR-V
Old 05-06-2005, 09:01 PM   #276
Marvin Hlavac's Avatar
Marvin Hlavac will become famous soon enough
Hi guys,
I like the modifications above. I never heard of ResHacker before. I think I should check it out. Is it possible to use ResHacker to enlarge the little rectangle which displays ETA, REM, DEST, and SPEED?
Marvin Hlavac is offline
Old 05-06-2005, 09:15 PM   #277
Raw Wave
justintime's Avatar
I looked, and could not find it. I looked all over!
Quote: Originally Posted by Marvin Hlavac
Hi guys,
2002 Honda CR-V
Old 05-07-2005, 03:07 PM   #278
Zebelkhan's Avatar
Zebelkhan is on a distinguished road
Screenshot:
I followed the above steps to do this for routis, which has basically the same exe file as iguidance but did not work. What am I doing wrong?
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
Zebelkhan is offline
Old 05-07-2005, 03:13 PM   #279
Raw Wave
justintime's Avatar
When you hilite the option, it should be yellow. Also, the 'preview' of the window itself will suddenly show only one window bar (instead of two). Its confusing, I know.... there is one window bar for the 'ResHacker window', and another menu bar showing within, which is the 'Routis/iGuidance' window. All of this shows while working within the ResHacker interface...
OK, so you hilite the option as per instructions, you compile, and save. The 'preview' should now show only one menu bar, and you know you've done it correctly.
2002 Honda CR-V
Old 05-07-2005, 03:28 PM   #280
Zebelkhan's Avatar
I just tried it on all of the dialogs and it works on all of them exept the main one which shows the map. Just thought of something though. I am opening routis as an stand alone application. Maybe what I am seeing is the "windows" frame and I should be opening it within FP or RR? I don't have them on my desktop (that is where I am testing this) I will download FP and open routis from within to see if it works.
Old 05-07-2005, 03:30 PM   #281
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
If you want to be rid of the iGuidance menu bars, I suggest you check out ol33l's iGLaunch app
http://www.mp3car.com/vbulletin/skinbedder/49296-release-iglaunch-v3.html
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline
Old 05-07-2005, 03:40 PM   #282
Zebelkhan's Avatar
It works! Thanks. Now if I could get rid of the file menue bar (the one that has the text menue) and even the one right below it that has the icons. Any ideas on those?
Old 05-07-2005, 03:58 PM   #283
Raw Wave
justintime's Avatar
Yeah, iGlaunch does not get rid of those for me either
It is SUPPOSED to though!
2002 Honda CR-V
Old 05-07-2005, 04:03 PM   #284
Raw Wave
tj!2k4's Avatar
it does for me.
tj!2k4 is offline
Old 05-07-2005, 04:30 PM   #285
Zebelkhan's Avatar
Quote: Originally Posted by tj!2k4
it does for me.
I used the resource hacker on routis and it works except does not get rid of the text menue and icon bar below it. I then tried iglaunch (after changing the ini file for routis) but something is not right as the nag bar does not go away and when routis embeds into iglaunch it sits there and flickers for what it seems at least 100 times. But it looks like it does get rid of all the menue bars. Assuming I can get it to work, how do I launch iglaunch automatically when I launch routis?
Closed Thread
IGuidance 2.0... WOW unsavory GPS 217 04-20-2005 02:14 AM
[Dest3 skin] How to change font size velocity? _wd Map Monkey 1 11-17-2004 07:46 PM
Embedded iGuidance Window Size? All4Sky MediaCar 3 08-27-2004 09:00 AM
winamp and play list font size???????????? donalson Software & Software Development 12 02-28-2001 08:40 PM
changing font size of file names in Windows Explorer? Squeezer General Hardware Discussion 4 01-11-2001 05:49 PM
