Closed Thread
Old 06-03-2005, 12:19 PM   #331
Zebelkhan's Avatar
Can anyone list the complete color codes, i.e.
0,255,0 = yellow
0,0,255 = blue
etc.
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
Zebelkhan is offline
Old 06-03-2005, 12:32 PM   #332
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Quote: Originally Posted by RPM_VR4
I just got a copy of 2.1 (I don't think it is 2.1.1 as the File|About just has V2.1NA) and I can't get it to work. My 2.0 theme.ini does nothing, and if I rename it to ctheme.ini, I get:
"iGuidance has encountered a problem and needs to close. We are sorry for the inconvenience."
As soon as I double click the exe.
Can someone PM me the contents of a theme2.ini/ctheme.ini that works with 2.1?
I believe your only choice for theme files is theme.ini and ctheme.ini. Does your software start normally if you remove the theme file. If I remember correctly, there might be other theme files in the directory WHICH YOU SHOULD NOT TOUCH. Only create either theme.ini or ctheme.ini, and add them to the directory.
If the program won't launch after removing the theme or ctheme.ini, I would reinstall the software, adn try again.
Michael
Wiredwrx is offline
Old 06-03-2005, 12:32 PM   #333
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Just so people are aware.
The DVD version 2.1.1 of Iguidance uses "theme.ini" and not "ctheme.ini"
Michael
Wiredwrx is offline
Old 06-03-2005, 01:36 PM   #334
Banned
RPM_VR4's Avatar
0,255,0 = yellow
0,0,255 = blue
etc.
You do realize there are 14 million of them right?
It's R, G, B so 255,0,0 is 100% red with no green or blue. 255,255,255 is white, 0,0,0 is black, 255,0,255 is red+blue=purple.
You should use some paint program or a web-page editor to choose the color you want and then read the code (you may have to convert from hex [#FFFFFF] to decimal [255,255,255] using calculator).
RPM_VR4 is offline
Old 06-03-2005, 05:01 PM   #335
Marvin Hlavac's Avatar
There are several web sites that will provide at least the basic color palette. Here is one: http://www.visibone.com/colorlab/ Just click on the color of your choice inside the image on top left side of the page and you will be presented the RGB value.
Many people have Microsoft Word on their computers. You can easily achieve the same, and have access to the whole spectrum of colors, just by starting your MS Word, and on the Formatting toolbar click the little arrow beside the Font Color button (The button with letter A icon). There click "More Colors", and then again click "Custom". Make sure RGB is selected as Color Model. When you click on any color of the spectrum you will see corresponding RGB value below.
Marvin Hlavac is offline
Old 06-06-2005, 02:46 PM   #336
Zebelkhan's Avatar
Thank you! I did not know what those codes meant. Thanks for the sugestions.
Old 06-13-2005, 09:56 AM   #337
Raw Wave
lostreception's Avatar
Someone had asked about enlarging the ETA /Dest/speed dialog i was wondering if the answer was the same for enlarging the distance to the next turn in the upper left hand corner
has anyone been able to do this?
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline
Old 06-13-2005, 03:28 PM   #338
My Village Called
0l33l's Avatar
Not that I know off
In future versions of iGSkinner, I'll try to magnify that area.
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline
Old 06-18-2005, 03:44 PM   #339
SMKFree
liquid_smoke's Avatar
wow, this thread is out of control well not out of control but really long and over 17k views, holy crap.
Anway, i think i get 2-3 PM's a week asking for the IG font fix, although all the info (including the file) is right here in this thread.
So, to try to cut down or get rid of all the PM's ill post the info again.
Maybe someone can make a new thread with all the usefull info and projects that spawned from this thread so people dont have to search through this thread to get all the info.
Here it is, again.
Quote: Originally Posted by liquid_smoke
Copy the text below into a new text file and name it "Theme.ini" and place this file in the same dir as iGuidance.exe is located. Edit the text size at teh bottom of the file, other options can also be changed in this file, take a look here on how to properly edit the file.
Code:
; road pen width in pixels @ 100ft FC1-2-3-4-5 RPW0=6 6 6 6 6 ; road pen width in pixels @ 200ft FC1-2-3-4-5 RPW1=6 6 6 4 4 ; road pen width in pixels @ 500ft FC1-2-3-4-5 RPW2=6 6 6 4 4 ; road pen width in pixels @ 1000ft FC1-2-3-4-5 RPW3=3 3 2 2 2 ; road pen width in pixels @ 2500ft FC1-2-3-4-5 RPW4=3 3 2 1 1 ; road pen width in pixels @ 1mi FC1-2-3-4-5 RPW5=3 3 2 2 1 ; road pen width in pixels @ 2mi FC1-2-3-4-5 RPW6=2 2 1 1 1 ; road pen width in pixels @ 5mi FC1-2-3-4-5 RPW7=2 2 1 1 1 ; road pen width in pixels @ 10mi FC1-2-3-4-5 RPW8=1 1 1 1 1 ; road pen width in pixels @ 25mi FC1-2-3-4-5 (DISABLED) RPW9=1 1 1 1 1 ; road pen width in pixels @ 50mi FC1-2-3-4-5 (DISABLED) RPW10=1 1 1 1 1 ; day map road pen color FC1-2-3-4-5 ; to use same colors for all zoom levels only specify DMRPC(max) DMRPC0=255,29,34 255,29,34 230,143,38 153,115,98 153,115,98 DMRPC1=255,29,34 255,29,34 230,143,38 153,115,98 153,115,98 DMRPC2=255,29,34 255,29,34 230,143,38 153,115,98 153,115,98 DMRPC3=255,29,34 255,29,34 230,143,38 157,119,102 157,119,102 DMRPC4=255,29,34 255,29,34 230,143,38 167,131,116 187,160,149 DMRPC5=255,29,34 255,29,34 230,143,38 153,115,98 175,147,133 DMRPC6=242,0,8 242,0,8 230,143,38 175,147,133 175,147,133 DMRPC7=242,0,8 242,0,8 230,143,38 153,115,98 145,107,91 DMRPC8=242,0,8 242,0,8 230,143,38 153,115,98 145,107,91 DMRPC9=242,0,8 242,0,8 230,143,38 153,115,98 145,107,91 DMRPC10=242,0,8 242,0,8 230,143,38 153,115,98 145,107,91 ; nite map road pen color FC1-2-3-4-5 ; to use same colors for all zoom levels only specify NMRPC(max) NMRPC0=255,0,0 255,0,0 255,133,136 255,255,255 140,140,140 NMRPC1=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190 NMRPC2=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190 NMRPC3=255,0,0 255,0,0 255,133,136 255,255,255 150,150,150 NMRPC4=255,0,0 255,0,0 255,133,136 255,255,255 120,120,120 NMRPC5=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190 NMRPC6=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190 NMRPC7=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190 NMRPC8=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190 NMRPC9=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190 NMRPC10=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190 ; route pen width @ zoom level RTPW=6 6 6 6 6 6 6 6 6 6 6 ; guidance screen route pen width GRPW=6 ; guidance road pen width GRDPW=6 6 6 6 6 ; day guidance road color DGRDC=192,0,0 192,0,0 128,192,192 192,192,192 192,192,192 ; night guidance road color NGRDC=192,0,0 192,0,0 32,96,96 96,96,96 96,96,96 ; street name font size in points @ zoom level STS=10 20 20 20 20 20 20 20 20 20 20 ; route colors RTC=0,0,255 0,0,255 0,255,0 0,255,0
[/quote]
liquid_smoke is offline
Old 06-18-2005, 06:28 PM   #340
Raw Wave
justintime's Avatar
For everything related to iGuidance customization, bookmark this thread (http://www.gpspassion.com/forumsen/t...TOPIC_ID=28166)
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline
Old 06-19-2005, 06:03 AM   #341
Just a word of warning about the above link. The website server cannot keep up lately. Especially Mondays are very bad. Sometimes I click and wait, and wait, and wait. And then I stop waiting and go do something else. LOL
It should improve shortly because the site is going to be moved to a faster server. Currently gpspassion.com has over 15,000 unique daily visitors, and over 3,500,000 pages viewed each month.
Old 06-19-2005, 10:04 AM   #342
UM_Fan's Avatar
ALOT OF INFORMATION...anyone figured out how to make the keyboard bigger? I hate to ask...I'm no good on photoshop..if there anyone that can a me a Mitsubishi icon or my car...
UM_Fan is offline
Old 06-19-2005, 10:13 AM   #343
Raw Wave
justintime's Avatar
... and a big thanks to Marvin for sharing so many iG tips!
2002 Honda CR-V
Old 06-19-2005, 11:15 AM   #344
Quote: Originally Posted by UM_Fan
...if there anyone that can a me a Mitsubishi icon or my car...
Download Red/Yellow/Green: >> click here <<
I haven't had much time to test it... see if it works well for you in different zoom levels and in both 2D and 3D view mode.
Have fun ;-)
Old 06-19-2005, 01:58 PM   #345
UM_Fan's Avatar
Have fun ;-)
Thanks man...I'll try it out as soon as I get this bondo stuff off my hands
UM_Fan is offline
Closed Thread
IGuidance 2.0... WOW unsavory GPS 217 04-20-2005 02:14 AM
[Dest3 skin] How to change font size velocity? _wd Map Monkey 1 11-17-2004 07:46 PM
Embedded iGuidance Window Size? All4Sky MediaCar 3 08-27-2004 09:00 AM
winamp and play list font size???????????? donalson Software & Software Development 12 02-28-2001 08:40 PM
changing font size of file names in Windows Explorer? Squeezer General Hardware Discussion 4 01-11-2001 05:49 PM
