Closed Thread
Old 12-08-2004, 09:53 AM   #76
Quote: Originally Posted by musicthebee
; road pen width in pixels @ 100ft FC1-2-3-4-5
RPW0=6 8 7 6 5
; road pen width in pixels @ 200ft FC1-2-3-4-5
RPW1=5 7 6 5 4
; road pen width in pixels @ 500ft FC1-2-3-4-5
RPW2=4 6 5 4 3
; road pen width in pixels @ 1000ft FC1-2-3-4-5
RPW3=3 3 2 2 1
; road pen width in pixels @ 2500ft FC1-2-3-4-5
RPW4=3 3 2 2 1
; road pen width in pixels @ 1mi FC1-2-3-4-5
RPW5=3 3 2 1 1
; road pen width in pixels @ 2mi FC1-2-3-4-5
RPW6=2 2 1 1 1
; road pen width in pixels @ 5mi FC1-2-3-4-5
RPW7=2 2 1 1 1
; road pen width in pixels @ 10mi FC1-2-3-4-5
RPW8=1 1 1 1 1
; road pen width in pixels @ 25mi FC1-2-3-4-5 (DISABLED)
RPW9=1 1 1 1 1
; road pen width in pixels @ 50mi FC1-2-3-4-5 (DISABLED)
RPW10=1 1 1 1 1
; day map road pen color FC1-2-3-4-5
; to use same colors for all zoom levels only specify DMRPC(max)
DMRPC0=255,29,34 255,29,34 230,143,38 179,179,179 179,179,179
DMRPC1=255,29,34 255,29,34 230,143,38 179,179,179 179,179,179
DMRPC2=255,29,34 255,29,34 230,143,38 179,179,179 179,179,179
DMRPC3=255,29,34 255,29,34 230,143,38 157,119,102 157,119,102
DMRPC4=255,29,34 255,29,34 230,143,38 167,131,116 187,160,149
DMRPC5=255,29,34 255,29,34 230,143,38 179,179,179 175,147,133
DMRPC6=242,0,8 242,0,8 230,143,38 175,147,133 175,147,133
DMRPC7=242,0,8 242,0,8 230,143,38 179,179,179 145,107,91
DMRPC8=242,0,8 242,0,8 230,143,38 179,179,179 145,107,91
DMRPC9=242,0,8 242,0,8 230,143,38 102,102,204 145,107,91
DMRPC10=242,0,8 242,0,8 230,143,38 179,179,179 145,107,91
; nite map road pen color FC1-2-3-4-5
; to use same colors for all zoom levels only specify NMRPC(max)
NMRPC0=192,64,64 192,64,64 203,126,33 102,102,204 102,102,204
NMRPC1=192,64,64 192,64,64 203,126,33 102,102,204 102,102,204
NMRPC2=192,64,64 192,64,64 203,126,33 102,102,204 102,102,204
NMRPC3=192,64,64 192,64,64 203,126,33 102,102,204 102,102,204
NMRPC4=192,64,64 192,64,64 203,126,33 102,102,204 102,102,204
NMRPC5=192,64,64 192,64,64 203,126,33 102,102,204 102,102,204
NMRPC6=192,64,64 192,64,64 203,126,33 102,102,204 102,102,204
NMRPC7=192,64,64 192,64,64 203,126,33 102,102,204 102,102,204
NMRPC8=192,64,64 192,64,64 203,126,33 102,102,204 102,102,204
NMRPC9=192,64,64 192,64,64 203,126,33 102,102,204 102,102,204
NMRPC10=192,64,64 192,64,64 203,126,33 102,102,204 102,102,204
; route pen width @ zoom level
RTPW=5 5 5 5 5 5 5 5 5 5 5
; guidance screen route pen width
GRPW=6
; guidance road pen width
GRDPW=6 6 5 4 3
; day guidance road color
DGRDC=192,0,0 192,0,0 128,192,192 192,192,192 192,192,192
; night guidance road color
NGRDC=192,0,0 192,0,0 32,96,96 102,102,204 102,102,204
; street name font size in points @ zoom level
STS=20 20 20 20 20 20 20 20 20 20 20
i got all the above text but in my iguidance folder, i don't have theme.ini file at all. how do i use this?
thanks
icet is offline
Old 12-08-2004, 10:09 AM   #77
thanks
You wont have a theme.ini in the default directory....just place the one you made in the default directory and start Iguidance- make sure you have the "hide file extentions" unchecked before you rename the file because you will have a theme.ini.txt file instead - that wont work
music - whats different in your ini file
does anyone know if we can edit the zoom buttoms to make them bigger using this theme.ini file
camsgs3 is offline
Old 12-08-2004, 10:56 AM   #78
i do had file extension uncheck...i saw the one .ini file but it is not theme.ini file at all...
thanks....
icet is offline
Old 12-08-2004, 11:27 AM   #79
Stank Cheese
n8scstm's Avatar
Does anybody have theme2.ini? If so, please PM. Thank you
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
n8scstm is offline
Old 12-08-2004, 02:29 PM   #80
muldrick's Avatar
theme2? What ya' talkin' 'bout Willis????
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline
Old 12-08-2004, 04:08 PM   #81
I'm sorry, and you are....?
frodobaggins's Avatar
thanks....
You have to make it and put the info in.
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline
Old 12-08-2004, 04:16 PM   #82
Stank Cheese
n8scstm's Avatar
theme2.ini is an advanced settings file. As I understand you rename it theme.ini and use it instead of the other theme.ini. It changes other appearances on the map. Can anyone back me up with more info?
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
n8scstm is offline
Old 12-08-2004, 04:44 PM   #83
MoFo's Avatar
yeah thats what I thought...
MoFo is offline
Old 12-08-2004, 05:53 PM   #84
MySQL Error
veetid's Avatar
I just wish there was a way to change the size of the menu buttons... I have to use a stylus in my car because of how small the iguidance buttons and menus are... I saw someone who was able to make them any size he wanted at the last meet I went to. The just used a resource editor to open up the exe, extract the bitmaps from it... then chagned there size and put them back in... They had tripled the size of the zoom buttons and it looked awesome, but I haven't had time to try it yet...
EDIT: Just went and downloaded Resource Hacker from
http://www.users.on.net/johnson/resourcehacker/
Use that program to open up the iGuidance.exe and under Bitmap you will see all the buttons.. Now someone just needs to make a larger button, import them all into the iGuidance.exe, and re-save it out...
You can change just about everything through this program... Street and Highway icons, Whats displayed in the file menu, what the hotkeys are, all the icons, you name it... I haven't actually changed and saved anything back out yet, but I know it should work because I saw it running modified in someones car...
david
veetid is offline
Old 12-08-2004, 06:07 PM   #85
MoFo's Avatar
good info veetid. I'm going to try and work on this.
MoFo is offline
Old 12-08-2004, 06:29 PM   #86
I see dead kittens
Quattro's Avatar
Quote: Originally Posted by Quattro-A4
If you have registered you copy of IGuidance then you can download the file from here.
http://www.inavcorp.com/support/downloads.html
Anyone downloaded from the INAV link?
Does this file include the additional information for the appearances on the map?
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline
Old 12-08-2004, 06:47 PM   #87
SMKFree
liquid_smoke's Avatar
david
good job
i know what ill be doing when i get home from work
liquid_smoke is offline
Old 12-08-2004, 07:29 PM   #88
MoFo's Avatar
i was messing a little with the resource hacker. here it is with 300 % bigger zoom buttons:
Someone figure out a way on how to move the positions around.
MoFo is offline
Old 12-08-2004, 07:35 PM   #89
MoFo's Avatar
heres a before shot so you can see how small the buttons were:
MoFo is offline
Old 12-08-2004, 09:30 PM   #90
MySQL Error
veetid's Avatar
It appears that it is centering the image. So make another image that is twice as tall as the one you are using now... Make it transparent and then place your new button at the top of your new tall image... This way it will visually raise the button on the screen because of the empty space below the button... It might work...
david
veetid is offline
Closed Thread
IGuidance 2.0... WOW unsavory GPS 217 04-20-2005 02:14 AM
[Dest3 skin] How to change font size velocity? _wd Map Monkey 1 11-17-2004 07:46 PM
Embedded iGuidance Window Size? All4Sky MediaCar 3 08-27-2004 09:00 AM
winamp and play list font size???????????? donalson Software & Software Development 12 02-28-2001 08:40 PM
changing font size of file names in Windows Explorer? Squeezer General Hardware Discussion 4 01-11-2001 05:49 PM
