Old 12-13-2004, 01:54 PM   #1
ThEScReW's Avatar
GPS not found problem
Hello,
I have this weird problem : I installed D3 on my laptop and on my carputer.
When i plug de gps receiver in my laptop and start D3 : it finds the satelites, no problem. When i put the gps receiver in my carputer : the software is installed, the same way like on my laptop but with D3 : GPS not found :-(
Anybopdy ?
ThE ScReW's CarPuter :-)
ThEScReW is offline   Reply With Quote
Old 12-13-2004, 05:43 PM   #2
Raw Wave
wizardPC's Avatar
make sure D3 on the carputer is set to look for the GPS on the right COM port
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
wizardPC is offline   Reply With Quote
Old 12-13-2004, 05:50 PM   #3
Harrie Coolen's Avatar
What kind of operating system are you using? I had the same problem with
windows 98SE, upgraded to XP PRO and had no problem any more!
Harrie Coolen is offline   Reply With Quote
Old 12-14-2004, 09:07 AM   #4
ThEScReW's Avatar
i have winxp pro installed and the comport is good, even if i hit search gps, then i have the same problem :-(
Old 12-14-2004, 09:27 AM   #5
HoSS's Avatar
I was getting something similar, working intially and then 'gps not found'
Something was going crazy with my COM ports (bluetooth)
All of a sudden after unplugging the BT dongle & replugging, i get 4 more COM ports, after a while the GPS is on COM12!
I've not solved this, but will prob try a clean install soon.
HoSS is offline   Reply With Quote
Old 12-20-2004, 06:39 PM   #6
naveedh's Avatar
if you have anyother gps software, delete it even beta or previous vice versa versions of destinator 3. Then reboot and it should work. I have the old 1.1.2 destinator installed and it worked fine but when i installed beta 1.1.3 it wouldnt detect so i deleted the Frontend folder in destinator apps and rebooted and it worked. The beta installs a frontend_prev folder . So delete any of one but not both.
naveedh is offline   Reply With Quote
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 02:24 PM
Gps Diagnostic 4u2n GPS 3 09-06-2007 03:01 PM
garmin mapsource and usb gps mouse thecrow GPS 9 09-26-2006 03:24 PM
GPS not found after hibernate/standby reda4 Map Monkey 5 11-06-2004 12:43 AM
Finished Building my GPS, now some ?s for the GPS gurus Dominik GPS 9 10-25-2004 02:34 AM
