Old 12-19-2004, 05:25 PM   #1
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
IGUIDANCE_ nag screen solution here
Ok, so now that im on vacation and have a little more time to work on things.
Ive been trying to figure out a way to kill the nag screen on IGuidance.
I know others have a fix for this, but i cant seem to get ahold of the files (broken links) that were posted long ago.
So, i figured some scripting should be able to handle something simple like this.
I downloaded AutoHotKey which is open source scripting engine, key mapper etc, etc, etc. http://www.autohotkey.com/ very cool program!!
anyway, i have a working script that kills the nag window.
this script will kill the nag window if you run the script standalone ie; not embedded in front end.
script will work with CentraFuse embeded, just point it to the script file instead of iguidance.exe. Seems to take a while but it embeds it correctly.
Frodoplayer dosent seem to like loading the script and you have to hit the gps button twice for it to embed properly. I think this is just a timeing issue that will be fixed in the new release which will make this script not needed anyway, but for the time being for everyone else.
download the program from the link above and install it.
copy this into a new text file
Code:
Run, F:\Program Files\iNav\iGuidance\iGuidance.exe WinWaitActive ahk_class #32770 IfWinExist, ahk_class #32770 WinActivate Send,{enter} Send,{enter}
edit the path to iguidance to point to where you have it installed on your machine, and save it as nagscreen.ahk or whatever you like.ahk
make sure the script is saved in the same dir as iguidance.exe or you will get errors
You can also compile the script as an .exe file, but since the path may be different on different computers you have to compile it as a .exe yourself, but this step is not needed.
enjoy and let me know if you have any problems, and ill try to help.
liquid_smoke is offline   Reply With Quote
Old 12-19-2004, 05:28 PM   #2
SMKFree
also, with a little editing, this should work for any program that pops up a window, not just IG. all you need is the window name
Old 12-21-2004, 12:48 AM   #3
SMKFree
anybody actually use this?
I tried it out in my car after testing it in the house and for some reason it didnt work, not sure why, but i rewrote it while in the car so if the above script didnt work for you, try this (more simple) one.
Code:
Run, F:\Program Files\iNav\iGuidance\iGuidance.exe WinWaitActive ahk_class #32770 Send,{enter}
Old 12-24-2004, 09:32 PM   #4
muldrick's Avatar
muldrick is on a distinguished road
I use iGuidance in FrodoPlayer...nag screen doesn't come up.
AtmosUSA.biz, E-Cig Mods
muldrick is offline   Reply With Quote
Old 12-25-2004, 01:02 AM   #5
SMKFree
cool,
at least some one found it usefull.
Old 12-25-2004, 01:37 AM   #6
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
NaviVoice has an integrated nagscreen remover
0l33l is offline   Reply With Quote
Old 01-05-2005, 06:58 PM   #7
Skipjacks's Avatar
Skipjacks is on a distinguished road
This is deffinately a good thing
Skipjacks is offline   Reply With Quote
Old 01-05-2005, 07:05 PM   #8
My Village Called
0l33l's Avatar
Yep You would be able to launch the nav from frodo unembedded, but frodoplayer seems to have problems with the command line parameters... I've told Frodo already.
Old 01-05-2005, 07:33 PM   #9
Skipjacks's Avatar
I don't use a front end anyway. I'm just happy that the nag screen is gone, and now with autohotkey creating the mini program my GPS iNav icon is a speed limit sign reading 85MPH.
Old 01-05-2005, 07:48 PM   #10
My Village Called
0l33l's Avatar
Autohotkey? Mini program?
Old 04-02-2005, 03:05 PM   #11
gizak's Avatar
gizak is on a distinguished road
got this working, much appreciated. I tried both scripts w/centrafuse and both work except the first one will start with the "menu" opened up and the 2nd without it. both are useful, thanks again!
-GiZak-
Carputer Project: 98% Complete!! *tweakin'*
Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
gizak is offline   Reply With Quote
Old 04-02-2005, 03:10 PM   #12
My Village Called
0l33l's Avatar
I've started making a "clone" of RoutisLauncher. One of the things its gonna do is stay open and relay all the events it receives to iG/Routis.
Old 04-03-2005, 03:29 AM   #13
My Village Called
0l33l's Avatar
Check This Out
Complete solution, COMPUTER, SCREEN +DVD player for your car! wrxmaster Classified Archive 6 07-09-2004 03:26 PM
Gamecube screen junior LCD/Display 7 11-24-2003 07:38 AM
Common theme in LCD screens.. spectrumzz LCD/Display 53 10-28-2003 04:37 PM
Problems with screen backlight and allen controller setup MikeHunt79 LCD/Display 13 07-02-2002 11:54 AM
Redant screen - widescreen, screen res, TV out??? Griffin_Dodd General Hardware Discussion 4 02-06-2002 07:09 PM
