Old 12-28-2004, 05:10 PM   #1
vintageb3's Avatar
vintageb3 is on a distinguished road
Unhappy Now getting problems with my BU-303
Hi Guys...
OK just about finished my VanPC install...
Now I'm getting problems with my BU-303...
BLOODY TYPICAL!...GPS is the main reason for building this VanPC
OK I’m not looking for “OH ditch it and buy a decent GPS” answers…I’m looking for a bit of advice from BU-303 users…
My system is:
EMIA M10000
256 Ram
3.5” drive
Lilliput 7” touchscreen
BU-303 USB GPS Mouse
PW-120-M
Today I installed the BU-303…which took a while…it seems to have installed in as a USB to serial port adapter…gonna have to check and see what it loaded as to my laptop….as this does not ring a bell…
Today I finally got the system to the test stage…and on the road…
I placed the BU-303 where I usually put it when I was working with my laptop…and it took time to acquire satellites….quite a while actually…then when on the road..it was dropping satellites even in clear skies with no buildings near by.
I checked it with InfoMap Navigator 4…and Destinator 3 through Frodoplayer…also with GPS info…and although most of the time the LED wasn’t flashing…at one point…the LED was flashing…and GPS info told me that there was no lock.
I have noticed that the BU-303 is powered all the time from the PSU (PW-120-M).
I’m just wondering if maybe…the BU-303…just needs rebooting….and all will be well…maybe it’s as simple as that?...After all…it hasn’t been powered down since I installed the drivers...and all the problems I was having today…but I'm now only thinking about this...will try this in the morining...
Anyone got a similar system…and can give me any advice…on how I should be going about trying to resolve these problems…or how they use there system?
Also…was the BU-303 is powered…how long will it take to drain my battery?
Thanks in Advance to you all!
vintageb3
vintageb3 is offline   Reply With Quote
Advertisement Sponsored links
Old 12-29-2004, 07:11 PM   #2
vintageb3's Avatar
OK So I got to my VanPc again today...
The GPS is working since I rebooted the GPS...silly me!...I should have done that initially...but to be honest...I did not realize the USB ports are powered all the time.
I’m going to fit a master switch to cut power to the PC anyway….so this will mean that USB devices will be powered down…and will give my battery a rest.
Sometimes I’m away on business for a month at a time…so knowing that everything is off…gives peace of mind…
Thanks to all who read this…and I hope it helps someone.
vintageb3
Old 12-30-2004, 09:26 PM   #3
fishy's Avatar
fishy is on a distinguished road
interferance
if you place the BU303 near the lilliput, it might drop out because of the interferance caused by the lilli (and in my case, a xenarc).
just a thought if it continues too drop out.
fishy is offline   Reply With Quote
Old 01-01-2005, 07:01 PM   #4
vintageb3's Avatar
AH!...Well that may tie in Fishy...I was trying the BU-303 right next to the lilliput on that ocaasion....the next day...I did move it away.
What would you recomend as a safe distance?...it's now about 18" away...and seems to be OK..
Thanks so much for your input!
vintageb3
Old 02-08-2005, 09:37 PM   #5
danilom is on a distinguished road
Look at my post on the bottom to solve this
http://www.mp3car.com/vbulletin/show...light=lilliput
danilom is offline   Reply With Quote
BU 303 Driver oekundar GPS 7 10-04-2005 11:08 AM
Need Driver For GlobalSat BU 303 Skuzzle GPS 1 12-28-2004 12:09 PM
BU 303 GPS reciever died... oekundar GPS 4 12-07-2004 03:37 PM
Yet another BU 303 issue G-Han GPS 7 10-05-2004 05:59 AM
Dell Inspiron 8200 & Lilliput TS problems? bkpsu LCD/Display 1 08-15-2004 02:55 PM
