The MP3car.com Store
Thread Tools Display Modes
Old 12-30-2004, 11:55 PM   #1
Vehicle: 2002 pontiac sunfire
My Photos: (0)
MS S&T 2005 GPS receiver driver install problem...
Greetings,
I'm having problems getting the GPS receiver to install that came with the Microsoft Streets & Trips 2005. [Yes, I know it is a sub-standard program for running in a car, but I got it cheap after rebate, and thought it would be cool]. Everything was working fine for a while, but it seems that something has gone wrong with the GPS driver. I can't locate it when I go to configure the receiver. It doesn't show up on any com port, and the driver seems to be messed up some how. I tried to reinstall the driver, ie. telling the computer where it is located on the Setup CD, but it says that isn't the correct driver. I've tried everything I can think of to get it to work, but I'm just running around in circles.
I've tried looking on the MS website for help, reinstalling Streets & Trips, rolling back my windows XP to a date where it worked, uninstalling and then reinstalling Streets and Trips, disabling things that would use the com ports, and I can't come up with any solutions. If anyone has any ideas, please help. Thanks.
rdc_3200 is offline   Reply With Quote
Sponsored Links
Old 12-31-2004, 07:10 PM   #2
muldrick's CarPC Specs
muldrick's Avatar
Vehicle: 2004 Hyundai Accent
My Photos: (2)
Well...you've done everything I would've tried.
At this point, if it's a usb receiver, I'd download this driver here:http://delorme.com/support/gps/uemat...=&P=17111&C=19
I know u shouldn't need it, as that's what's on the cd, but it's worth a try.
Also check this, if you haven't already:http://www.delorme.com/support/earth...rdpartytrb.asp
I know it's about 3rd party, but it's the same driver, I believe.
Keep us posted.
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 01-01-2005, 12:25 AM   #3
desiz's Avatar
Vehicle: 2004/Nissan/350Z
My Photos: (0)
you may have run into a problem that i had with mine. This is what happened to me:-
my gps unit worked fine initially, then suddenly stopped... when i tried to reinstall the driver, it would say "USB device is malfunctioning". When i tried to reinstall the driver, it would say "specified location does not have information for the device you are installing". If you're getting the same error then maybe i have a solution ...
desiz is offline   Reply With Quote
Old 01-01-2005, 03:30 PM   #4
My Photos: (0)
desiz - that's exactly the error message I get when I try to reinstall the driver "specified location does not have information for the device you are installing"
muldrick - I'll try out those driver and let you guys know.
thanks for the help
Old 01-01-2005, 04:19 PM   #5
desiz's Avatar
My Photos: (0)
rdc-- here's the bad news.. u may have fried the gps ... thats what happened to mine. Mine worked fine until i pulledout a pci card from my computer while it was on which made my computer shut down abnormally. since then, whenever i would plug my gps in, it would say "usb device found" but when i gave it the driver location it would say "specified folder does not contain information for your hardware".
I got a replacement for free and when i tried it, it worked fine. so i guess your only solution is to get a replacement under warranty.
Sponsored Links
vB code is On
Trackbacks are Off
Question on Garmin 16 GPS receiver cproaudio GPS 19 05-23-2008 01:32 AM
Touchscreen driver install problem, HELP! (Lilliput 7") davem LCD/Display 4 07-04-2007 06:07 PM
xp install to laptop hdd problem thecrow Newbie 8 06-15-2005 03:37 PM
Beginning to go INSANE!!! *aaaaah* GPS problem t0ffluss GPS 8 12-31-2002 11:37 AM
How to install GPS??? Cue General Hardware Discussion 10 07-13-2000 01:39 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
