Old 12-31-2004, 04:17 AM   #1
Skipjacks's Avatar
Earthmate GPS don't work...help please
I installed the whole computer tonight and the only thing that doesn't work is the GPS. I don't know enough about GPS to diagnose the problem.
I have an Earthmate receiver. The little yellow one. I know the unit works because it worked on my deck the other night when I had it hooked up in my living room.
Anyway tonight I put it in the car and it seems like Routis and CoPilot don't even know the Earthmate is connected to the computer.
When I plug it in to the USB port it blicks red for about 30 seconds then goes dark until I unplug it and plug it back in. Then the cycle repeats.
I took it out of the car, put it on the roof, in the rear window, everywhere the cable would reach, and I keep getting teh same result. Routis tells me there is no GPS unit connected. Does that mean the Earthmate isn't connecting to the computer properly? Or is that the messaeg you get when the Earthmate isn't locking onto a satalite?
Also it's really overcast here tonight. Could that have anything to do with it? I don't know if the satalites penetrate thick clouds (I assume they would, but who knows)
Any thoughts or suggestions?
Skipjacks is offline   Reply With Quote
Old 12-31-2004, 04:35 AM   #2
i know if you're using the earthmate, you'll need the USB to Serial drivers so that Routis/iGuidance, CoPilot will recognize it...
Search for that driver and you'll be good to go...
Lexus SC400
ACleanSC4 is offline   Reply With Quote
Old 12-31-2004, 11:53 AM   #3
Well, I think ACleanSC4 got it on the nail.
From the time you had it running on your desk to the time you installed it into the carputer, you may have changed the USB port in which you inserted the USB plug. This would cause the Earthmate to revert to its "dinky" driver and require you to reconfigure it to use the 3rd Party USB to Serial driver.
DaRacerz is offline   Reply With Quote
Old 12-31-2004, 12:05 PM   #4
Raw Wave
rando's Avatar
..or forget the drivers and never have a problem again ... just modify the cable to convert it to a serial GPS. Search the forums for instructions.
2004 4runner
rando is offline   Reply With Quote
Old 12-31-2004, 01:29 PM   #5
Skipjacks's Avatar
I did exactly that! I had it in the front USB port in the house and in the back ones in the car. I thought about that and tried to switch it back to the front on in the car but it didn't work. I'll do the driving thing this afternoon and see if that helps. Thanks, guys!
Old 12-31-2004, 02:35 PM   #6
Skipjacks's Avatar
Well that didn't work.
What else could be wrong?
I ran the Earthmate USB-Serial thing and it did absolutely nothing. Still get the same exact problem. The little red light blinks for about 30 seconds, then goes out and stays out and the computer still can't get a signal.
Old 12-31-2004, 03:20 PM   #7
Skipjacks's Avatar
Allright....here's what I found out...
I went to the system setting and looked at the hardware and despite Windows telling me that the USB device Earthmate was recognized and installed at startup, the Earthmate does not appear in any catagory in the hardware settings.
I ran the Earthmate USB to Serial program once and it convinced Windows that the GPS was a human interface device. I rant it again and it now I can't find it anywhere.
What the bloody hell is going on?
Does the Earthmate just suck? Should I go get a new GPS reciever that doesn't blow?
Old 12-31-2004, 03:57 PM   #8
MoFo's Avatar
I think the Earthmate is quite the badass..
try this one: http://www.mp3car.com/vbulletin/show...8&postcount=14
MoFo is offline   Reply With Quote
Old 12-31-2004, 04:34 PM   #9
muldrick's Avatar
When you ran the driver program again, it should've uninstalled it first. Did it?
The driver should be listed under "Ports (COM & LPT)" as the Delorme...blah blah blah, not as a Human int. device.
Try this driver installation 2 or 3 times.
I run iGuidance and this is what I have to do everytime I move the usb port.
Don't worry or pay attention to the blinking light. Reinstall the drivers, then check your device manager to make sure it's listed right. It'll even tell you what Com port.
Once you've got that done go into Routis and tell it the correct com port.
Also read this thread: http://www.mp3car.com/vbulletin/gps/36837-iguidance-delorme-usb-receiver.html
especially post 3 and 4.
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 12-31-2004, 07:03 PM   #10
MoFo's Avatar
Quote: Originally Posted by muldrick
The driver should be listed under "Ports (COM & LPT)" as the Delorme...blah blah blah, not as a Human int. device....
It should be under the COM ports, but for some reason it never was for me. It would be under Human Interface Device and I would have to goto 'properties' then reinstall drivers and manually select the driver file...
edit: there was some confusion...yes I did get everything to work perfectly after doing the steps that i posted earlier
Old 12-31-2004, 07:14 PM   #11
muldrick's Avatar
You're speaking in past tense. Does this mean you fixed it?
Old 12-31-2004, 10:10 PM   #12
Raw Wave
BoyNextDoor's Avatar
This should fix it. I only used the front ports, so never installed the driver on the back ports. thats why it's screwing you a bit. just don't give up, and you'll be fine.
BTW how dod the dvd-rw drive migration to your desctop go?
A Lot of things for sale. Please help me start my own business.
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
BoyNextDoor is offline   Reply With Quote
Old 12-31-2004, 11:20 PM   #13
My Village Called
0l33l's Avatar
What I found out: the COM port changes if I plug it into a different USB port on my laptop
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 01-01-2005, 12:34 AM   #14
Skipjacks's Avatar
That's what I ended up figuring out tonight. I ended up unistalling the drivers and reinstalling everything and it all worked perfectly. Now I'm happy!
Thanks for the tips, guys. The USB-Serial thing really helped.
Old 01-01-2005, 12:42 AM   #15
My Village Called
0l33l's Avatar
No problem
GammaControl v2.4
SKINbedder v3
Will this GPS work belezeebub GPS 4 02-04-2004 10:37 PM
FS: Earthmate GPS, SB Live MP3+, 20gb laptop HD, RAM, duron+matx mobo + more aoLhaTer Classified Archive 10 01-30-2004 07:47 PM
any gps handhelds work with copilot? aoLhaTer GPS 5 07-27-2003 04:08 AM
getting mappoint to work with earthmate & a cool gps program i found aoLhaTer GPS 2 06-12-2003 08:13 AM
is the earthmate gps reciver NMEA 0183-compatible ? darkwingduck General Hardware Discussion 21 02-04-2001 07:40 PM
