Old 01-19-2005, 02:38 PM   #1
westscape is on a distinguished road
Bu-303 Strange Fault
My BU-303 has started playing up. After about 15 mins perfect operation the LED stops flashing and just gives out a constant dim light, then no data is tranmitted (the USB device is still there, just no data). I've tried in on 2 PCs now with the same result many times.
Any ideas anyone?
Thanks,
Dave.
westscape is offline   Reply With Quote
Old 01-19-2005, 03:23 PM   #2
carpcnoobie's Avatar
carpcnoobie is on a distinguished road
It got wet. Open it up, dry it out good. Let it sit for a few days. Might start working again.
Check out threads about waterproofing BU-303s.
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
carpcnoobie is offline   Reply With Quote
Old 01-22-2005, 08:34 AM   #3
Thanks,
I never used it outside the car and there was no visible water inside. I thought it might be an over-heating problem. I powered it up out of the case and it worked ok. I left it powered up for about 24 hours and put it back in the case and now it's ok. Maybe it had got some condensation it it?
Old 01-22-2005, 12:11 PM   #4
Interesting. Where were you using it, if I may ask. Did you leave it outside overnight? I'm looking to waterproof mine and I'm hoping I don't have probs with condensations.
The reason I jumped so quick is that's been the prob with many BU-303s. Same symptoms.
Good luck.
Progress Meter:
Old 01-22-2005, 04:35 PM   #5
Hi carpcnoobie,
I would just have it on the top of the passenger door, just under the window; the magnet sticks quite well there. I never left it in the car overnight, it would be stored indoors but in a room that doesn't have much heating.
Also I can remember that it first failed when I took it out of that environment and put it in the car on a cold morning.
Anyhow I hope it was a condensation problem and that's the end of it. If it happens again I might look at sealing the case which doesn't look that difficult.
Inverter - PSU fault (diagnose = how?) Samirnoff! Power Supplies 12 06-08-2006 07:20 PM
BU 303 Driver oekundar GPS 7 10-04-2005 11:08 AM
Need Driver For GlobalSat BU 303 Skuzzle GPS 1 12-28-2004 12:09 PM
BU 303 GPS reciever died... oekundar GPS 4 12-07-2004 03:37 PM
Yet another BU 303 issue G-Han GPS 7 10-05-2004 05:59 AM
