Old 01-27-2005, 03:53 PM   #31
HummDinger's Avatar
Ive used the same BU-303 for about 2 years, no problems here in wisconsin. I use iguidance with it. I have had it mounted on my roof of the car, in the rear windows and on the front dash. I even got reception in my garage. I would make sure you are getting a fix with it. Make sure your not using a USB extension cable, if you need one, make sure it is a high quality cable. I had problem with this when I just used cheap cables. I switched to quality belkin cable and walla, it was fixed. The BU-303 is pretty good, accurate and should work fine.
TOns of people on this board use it and to here you have problems with it, makes me think it is in your install, cables or possibly your computer not putting out enough voltage through the USB port. ALso check how many USB devices you have hooked up. Dont run this through a hub either. It simply wont work.
Sorry to hear the problem but hope this will help.
You can still have something if you have nothing
HummDinger is offline   Reply With Quote
Old 01-27-2005, 10:53 PM   #32
Altimat's Avatar
Mines always been on the hub works fine. Maybe the hub needs to be a powered hub?
2002 Nissan Altima 3.5 5 Speed Bose FM/6CD ED E12A P4 2.26 512 Ram Ti4600 CDRW DVD Lilliput 200mW 802.11b Trackman AutoTap GPS Opus 150 Carnetix 1260
2005 Nissan Titan SE Dell GX-150 P3 1.0 512 Ram 20G GF4 MX4000 USB 2.0 DVD/RW Xenarc GPS Trackman
Altimat is offline   Reply With Quote
Old 01-28-2005, 08:39 AM   #33
Got 5 meters of usb-extension, placed the sucker on the parcel shelf i the alfa, and all of a sudden it works like a charm! Thansk a lot for all your mental support, hadn't done it without you guys, especially not you, Enforcer :P
lusen is offline   Reply With Quote
Old 01-28-2005, 09:04 AM   #34
Thumbs up
My gps unit(BU-303) works great for me, hasn't let me down as of yet... I had it for about nine months now.
ERIKbx is offline   Reply With Quote
Old 01-28-2005, 09:06 AM   #35
See me in my wet t-shirt.
stevieg's Avatar
I've had occasional problems with mine.
I have trouble getting a lock when there's lots of high buildings, Birmingham city centre UK is one... I lose signal as I go into a certain part by the new Bull Ring and regain again after a few minutes.
I've also had issues if I haven't used the Car PC for a week or so (last time was fater I came back from holiday) and it took a day or so to 'get back to normal'.
Mounting in the Car I've had many problems.. in the corner of the dashboard (I have a heated windscreen but there is a 'gap' where there is no metal) it often has issues however my Road Angel GPS camera detector works fine there.. Always.
I've taken to mounting it on the roof at the back of the car which seems to be the best bet but I think before long I've be scrapping the BU303 and going for something a bit more upmarket.
The road angel GPS reciever unit inside the unit is made by Holux, I might get one of those.
Ford Focus MP3 : www.stevieg.org/carpc
Car PC Status: COMPLETE
stevieg is offline   Reply With Quote
Old 01-28-2005, 10:40 AM   #36
Confusion Master
Enforcer's Avatar
Enforcer is offline   Reply With Quote
Old 01-30-2005, 05:21 PM   #37
captain_jim1's Avatar
I've had the BU-303 sitting on my rooftop since May .. I've driven across the country without removing it -- through rain, snow, extreme heat -- you name it -- and it's never skipped a beat. It's been in a block of ice, under snow, in the freezing temps and it's been great -- and no I haven't weather proofed it. Of course, after saying all this, I bet it'll break lol...
always locks too..
-Brad
83 mp320i
99 mp323i
_________
7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
captain_jim1 is offline   Reply With Quote
Old 01-30-2005, 11:23 PM   #38
VanMan69's Avatar
I've got mine on a powered 1.1 hub with my ATI RF remote and my USB 2.5" drive, and haven't had any problems. It's got an extension cable on it as well.
95 Chevy G20 Vroom Boom Room
...with a whole bunch of nifty ****... go check it out: VanDomain Page
VanMan69 is offline   Reply With Quote
Old 04-09-2005, 06:14 AM   #39
Ok, I finally managed to find a good spot for it. I've glued it to the rear, openable windscreen in the back, just over the windscreen wiper. Works fairly good, get lock on between 7 and 12 sats.
BU 303 Driver oekundar GPS 7 10-04-2005 11:08 AM
Need Driver For GlobalSat BU 303 Skuzzle GPS 1 12-28-2004 12:09 PM
BU 303 GPS reciever died... oekundar GPS 4 12-07-2004 03:37 PM
Yet another BU 303 issue G-Han GPS 7 10-05-2004 05:59 AM
GPS 303 software does nothing sygad GPS 4 09-21-2004 08:49 AM
