Old 02-09-2005, 03:14 PM   #1
John_Duh's Avatar
Haicom HI-202E
i got this USB GPS receiver for the one and only reason that it's cheap. I'm currently using it with my laptop (running Route 66) and i find the signal comming in really slow. Anybody know whether this has something to do with the GPS receiver or is it just me using crappy software ?
'02 Toyota Celica TS
Carputer progress : [####------]
Currently working on : finding spare time
Parts : pico-ITX, 160Gb SATA, 1.0Gb Ram
Parts needed: USB wifi dongle, USB BT dongle, external storage
John_Duh is offline   Reply With Quote
Old 02-09-2005, 03:32 PM   #2
maybe because it was dirt cheap:P?
try Map monkey my BU303 works great
my destinator map resource down permanently
GReeToZ is offline   Reply With Quote
Old 02-09-2005, 03:36 PM   #3
MySQL Error
jcdillin's Avatar
where do you have it located in your car? is it just taking a long time to get a fix?
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 02-10-2005, 05:55 AM   #4
John_Duh's Avatar
it's located under the windshield on the dash, attached with a suction cup.
it's slow both in acquiring the signal and in updating the information to the laptop. My 'you are here arrow' is always lagging a while behind.
Old 02-10-2005, 05:56 AM   #5
See me in my wet t-shirt.
stevieg's Avatar
How far behind.. It is usually a second-ish behind and only updates once a second.
Ford Focus MP3 : www.stevieg.org/carpc
Car PC Status: COMPLETE
stevieg is offline   Reply With Quote
Old 02-10-2005, 06:28 AM   #6
MySQL Error
jcdillin's Avatar
I would just hold it outside the window and see if your getting a better lock. because if your not getting a good signal it will cause a pretty big lag. but stevieg is right there always will be a small amount of lag. It might be something in your windshield that is causing low signal.
肚子笑痛了
S60 Install
Old 02-11-2005, 06:04 AM   #7
John_Duh's Avatar
i'll try the holding outside the car when it's not raining (winter in belgium = rain)
In general it lags enough to cause confusion between one exit and the next on the highway. Keep in mind that this is belgium and that there are exits every couple of miles here.
Old 02-11-2005, 06:09 AM   #8
MySQL Error
jcdillin's Avatar
Yeah but it should do a little better than that. Where I live we have exit's that are sometimes less than a mile apart and my gps has no problems with them.
肚子笑痛了
S60 Install
Old 02-11-2005, 10:31 AM   #9
stevieg's Avatar
Mine is lagged on a motorway by less than 100 yards...
On a street with two junctions 30 feet away you can't miss them let alone a couple of miles..
That is way too laggy
Old 02-11-2005, 12:17 PM   #10
John_Duh's Avatar
mhhh ... what brand of GPS do you guys have ?
might look for a different one.
Old 02-11-2005, 12:20 PM   #11
Raw Wave
Laidback's Avatar
I use that GPS with no problems. Chuck out route 66! What speed is the laptop?
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 02-11-2005, 12:21 PM   #12
F4kk3r0's Avatar
It can also be a symptom of software. Some software can take an advance according to speed.
F4kk3r0 is offline   Reply With Quote
Old 02-11-2005, 12:26 PM   #13
Confusion Master
Enforcer's Avatar
I was running the Haicom with route 66, it was fine on my PIII 1Ghz PC, but had trouble on my original laptop a PI 166MMX. used to work Ok on my PII 366 laptop but didn't do extensive testing on it htough. I have since moved to a BU-303 as the Haicom stopped detecting Satelites after about 18-20months. Also I am now using Destinator variations and have found the BU-303 to perform slightly better than then HAICOM did. Although saying that the BU-303 seems to be playing up at the moment as it loses signal more often than it used to.
Enforcer is offline   Reply With Quote
Old 02-18-2005, 03:49 AM   #14
John_Duh's Avatar
the laptop is 1.0Ghz with 384Mb ram, so the laptop shouldn't be causing the problem.
Guess i'll have to change the navigation software.
Old 02-21-2005, 02:27 PM   #15
Check that your windscreen is not the newer type with the heat resistant glazing as this impairs signal reception greatly.
davewuk is offline   Reply With Quote
haicom HI-202E BOND007BE GPS 32 03-19-2005 04:51 PM
Haicom 203E Serial & Infomap Navigator - No Signal spaced_chris GPS 3 01-02-2004 11:41 PM
Directions Infomap & USB Haicom 203E, XP Vittel GPS 4 09-12-2003 05:15 PM
Haicom USB and XP! Daz GPS 3 08-29-2003 10:33 AM
Haicom 202E t0ffluss GPS 8 09-06-2002 04:42 AM
