BU-303 problem (software related)
Ive been using my GPS for several months now without a problem. Recently, I was using Routis and all of a sudden I lost signal.. the receiver was still blinking and had a lock, but there was no data coming thru to the software.
Before I go on, I have a Epia M mobo and use the external USB ports that have the firewire ports in the same plug. One USB port is for my XMPCR, the other is for GPS. I always use the same port for XM and the same one for GPS...and i accidently plugged the GPS into the XM port. This is when I think might have triggered the problem.
I went into the Device Manager, and found a 'USB Device' with the exclamation point next to it...so I figured just reinstall the driver and it will be fine...
So I got the disk, tried to reinstall several times and had two outcomes:
1. When I select the GPS driver CD - it scans that folder, finds nothing - then says a better device driver is found - c:\winnt\usb.inf - When I proceed with the install I get a message saying something to the extent of the device could not be installed because a function driver could not be found
2. It accepts the GPS disk as a source of the driver, and installs the Prolific USB Serial...which is correct...it assigns a com port..which is good....and when I open Routis it works!...but only for a short time...then it craps out again like it did when I initally had this problem. If I unplug the GPS receiver and plug it back it, it thinks its a new device and tries to install it again...which usually ends up with outcome #1.
BTW, im using Win2k pro. Ive done google searches and try some of the suggested fixes, including a M$ update..but no luck. Im pretty sure that its not a hardware problem, but something screwy with Win2k.
Epia MII12000 | 512MB RAM | ATI TV Card | 60GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | WinALDL hookup | 10.4 Datalux LMV10R | Opus 150W PSU.
