Old 02-15-2005, 05:39 PM   #1
Super Moderator
xBrady's Avatar
xBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to behold
Possible? Run two gps applications at once
Is it possible to run two GPS applications at once? I was about to start on a small application that uses the com port your GPS is on to grab info every once in awhile and I don't want it to interfere with the already running navigation system.
Is it not possible to read from a com port from two seperate applications?
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Old 02-15-2005, 05:41 PM   #2
nottastocker's Avatar
nottastocker is on a distinguished road
I don't see why not, it seems that NMEA protocol is a passive one... but then again, I have never personally used a gps system myself.
Mozilla Search Plugin
nottastocker is offline   Reply With Quote
Old 02-15-2005, 05:46 PM   #3
edikp is on a distinguished road
Give this site a browse: http://curioustech.home.insightbb.com/xport.html.
I use an OEM GPS receiver (Garmin GPS25LV) which has two com ports. Probably you want to invest on one of those.
EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
edikp is offline   Reply With Quote
Old 02-15-2005, 05:47 PM   #4
ppgt94's Avatar
ppgt94
You'll need a software (or hardware) com port replicator. Do a search for one on the forum. I have a freeware version that works but I forget what it's called.
*edit* edik beat me to it. That's the one I use.
ppgt94 is offline   Reply With Quote
Old 02-15-2005, 05:48 PM   #5
dodgetimes2's Avatar
dodgetimes2 is on a distinguished road
GPSGate maybe?
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
dodgetimes2 is offline   Reply With Quote
Old 02-15-2005, 05:53 PM   #6
Vacheron's Avatar
Vacheron is on a distinguished road
Quote: Originally Posted by dodgetimes2
GPSGate maybe?
I'm using GPSGate to run 3 GPS applications simultaneously. (Netstumbler + 2 Navigation packages) and it has worked perfectly on XP ever since I intalled it. Two thumbs up from me.
Project F.T.P.C.
Vacheron is offline   Reply With Quote
Old 02-15-2005, 06:12 PM   #7
hihidamon is on a distinguished road
Maybe you should consider this bluetooth receiver from Emtac. I know its bt and runs on batteries and costs more, but it is capable of connecting to 4 devices simultaneously via the bt virtual com ports straight out of box.
http://www.gps4fun.com/trc_bluetooth_trine.php
I have one of the earlier ones (without multilink support) and it works like a charm always!
hihidamon is offline   Reply With Quote
Old 02-15-2005, 07:00 PM   #8
Super Moderator
xBrady's Avatar
Thanks for all of the information guys! I probably wouldn't go for getting a new GPS device as the application I am making will be released to forum members and I don't want everyone that uses it to have to get a new GPS module If all it requires is an external application then that will work for me. I'll try one of those two apps and get started right away on the programming.
Installed.
Old 02-16-2005, 01:49 PM   #9
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Just use this one http://curioustech.home.insightbb.com/xport.html post earlier.
Work wonder and it free from our own memeber Curiosity
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-16-2005, 02:28 PM   #10
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Yes?
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 07-22-2005, 04:55 AM   #11
Frankino's Avatar
Frankino is on a distinguished road
I have a USB GPS which creates a virtual com port, which I'd like to share.. Xport does not work with virtual ports, any ideas?
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Frankino is offline   Reply With Quote
Old 07-22-2005, 08:38 AM   #12
Vacheron's Avatar
See my post above.
My USB GPS is also on a virtual com port and GPS Gate works perfectly.
I've been happily sharing to 3 apps on 3 different com ports simultaneously for the last 6 months without a problem.
Project F.T.P.C.
Old 07-22-2005, 09:25 AM   #13
Curiosity's Avatar
or just look for the little dot next to COM64. If you don't see it, compass ain't working. Open the compass config and close it again. Might work.
Old 07-22-2005, 09:34 AM   #14
MySQL Error
MatrixPC's Avatar
I think the problem is that you only install Xport2. No it won't work by itself. You have to install Compass as well. Together, these 2 work wonder.
Old 07-22-2005, 10:54 AM   #15
Frankino's Avatar
I'll give it a try tomorrow, in the meantime I solved with GpsGate
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
Gps Diagnostic 4u2n GPS 3 09-06-2007 03:01 PM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
Newbie's guide EBFoxbat Newbie 6 02-08-2005 11:06 AM
why does my taskbar show when i run gps??? TheKurbster FrodoPlayer 4 11-10-2004 09:36 AM
Triggering events based on GPS location electron GPS 5 09-16-2004 12:57 PM
