The MP3car.com Store
Thread Tools Display Modes
Old 02-20-2005, 01:49 AM   #16
Chairboy's CarPC Specs
Chairboy's Avatar
My Photos: (0)
Quote: Originally Posted by 0l33l
Yeh, just like caller ID data
Quick question about parsing data: can you get a smooth update of a digital speedometer using GPS speed?
Sure, you just apply a kalman filter, I think, to average the rate of change out and apply it each second. Depending on how accurate you want the speed to be, though, it would always be a second or two behind reality. Might not be a problem unless you're on a motorcycle and you constantly wheelie right up to the speed limit.
Chrysler 300 - Fabricating
http://hallert.net/
Chairboy is offline   Reply With Quote
Sponsored Links
Old 02-20-2005, 01:55 AM   #17
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
Vehicle: 1995 Lexus SC300 1997 Mazda Miata
My Photos: (0)
Hmm... but that would still make the needle jump around. Say at one moment I'm going 30, and the next time it checks I'm going 40, it would tell me 35, but it would also have jummped 5mph.
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 02-20-2005, 02:09 AM   #18
Chairboy's Avatar
My Photos: (0)
Right, so you figure the rate of change and divide it into 10-20 increments and spend the time between each update moving the needle in the direction it was going.
At the update, you make the needle start moving at the speed needed to reach the speed you read in one second. The next second, you get a new speed and make the needle start moving to that, with the target of reaching it in exactly one second. You do this over and over again, and you have a pretty smooth indicator that's one second behind GPS. It would be pretty smooth, especially at slower accelerations.
http://hallert.net/
Old 02-20-2005, 02:10 AM   #19
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (22)
Web definition of Kalman filter:
"A computational algorithm that processes measurements to deduce an optimum estimate of the past, present, or future state of a linear system by using a time sequence of measurements of the system behavior, plus a statistical model that characterizes the system and measurement errors, plus initial condition information. "
I know jack about this but if the definition is right, it appears that the filter allows you to predict your speed based on the rate of change between GPS speed estimations.
So in your example, when the program read 30, it would know, based on observations of speed made before the 30 reading (say 22, 25, 28 were previous readings) what the rate of change on the speedo should be NO MATTER WHAT THE TIME DELAY.
So if your program did some processing and then came back 50 milliseconds later and was ready to update the speedo, but didn't have a GPS reading, it could predict what the speed OUGHT to be by using this filtering technique.
Because the definition says it is for a linear system and acceleration/deceleration can be non-linear, it probably would have a bit of lead and lag in it but it shouldn't jump around.
Chairboy - please correct me now!
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 02-20-2005, 02:37 AM   #20
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
My Photos: (0)
Starting to make sense now
What is the speed update in NMEA anyways? Its like 1 second IIRC
GammaControl v2.4
SKINbedder v3
Sponsored Links
Old 02-23-2005, 05:14 PM   #21
Prindle19's Avatar
Vehicle: 1996/Ford/Explorer/Eddie Bauer
My Photos: (0)
Exclamation
FRODO!!!!!!!!!!!!!!!!!!!!!!!
Do you realize there's a critical flaw in your GRMC parsing???
The lat and long in the NMEA format is DDMM.MMMM and DDDMM.MMMM
Your code simply parses this as
DDMM.MMMM / 100
This is incorrect, because the first MM are decimal degrees, the next set after the "." are decimal minutes. It should be this formula
DD + (MM.MMMM / 60). for lattitude.
DDD+ (MM.MMMM / 60) for longitutde.
If you had a NMEA input Latitude of 2752.26564, your code would convert this to the latitude of 27.5226564. That is incorrect.
What you need to do, is grab the degrees first (first 2 for lat, first 3 for long)
which in this case would be 27, and then calculate the minutes seperately.
which means you take 52.26564, and devide it by 60, and then add it to the 27 degrees.
so instead of
27.5226564, you SHOULD get 27.871094
This may look small, but thats nearly 30 miles! and the exagerating was even greater with the longitude.
Just a heads up if anyone is using Frodo's sample code.
Prindle19 is offline   Reply With Quote
Old 02-23-2005, 05:28 PM   #22
9 Fingered Administrator
Lesbian
frodobaggins's Avatar
Vehicle: 1998 Ranger/1991 Sunbird
My Photos: (0)
Bah, so sue me. It was a 5 minute example. I don't see FrodoGPS coming out any time soon. But I will fix it
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 02-23-2005, 06:02 PM   #23
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
It should also be negative if S or E.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 02-23-2005, 10:03 PM   #24
Prindle19's Avatar
My Photos: (0)
Frodo: haha, no worries, just had my sailboat gps software sailing in mainland florida for a couple days!
Curiosity: Depends on what you need it for, i'm plugging it into MapObjects so i just handle that operation before i feed my tracking layer a x,y and before i transform it to my mercator projection.
Sponsored Links
vB code is On
Trackbacks are Off
SRC Release frodoxm ActiveX control 0.1 alpha frodobaggins Software & Software Development 14 10-08-2005 07:20 PM
XM ActiveX control, would you pay ? frodobaggins Software & Software Development 17 01-09-2005 04:35 PM
ActiveX control for USB Radio Sammyboy Software & Software Development 0 10-28-2004 05:52 AM
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 12:25 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
