02-17-2005, 10:32 AM
#1
NMEA ACTIVEX control ---free if possible
anyoen know of a good, free, NMEA string reading ActiveX control that i could access with visual basic 6?
02-17-2005, 10:55 AM
#2
See me in my wet t-shirt.
Yes
02-17-2005, 10:56 AM
#3
Raw Wave
You generally only need to interpret a few of the different NMEA strings to do navigation and parsing them is fairly trivial once you know what they mean. I would recommend you take a look at http://pcptpp030.psychologie.uni-reg...arch/NMEA0183/ and the link to sam blackburn's NMEA library in C++ on there.
02-17-2005, 02:29 PM
#5
thanks, i'll try it, looks limited in what it parses, i need to be able to parse strings that an aneomometer may put out.
02-19-2005, 02:54 PM
#6
how do i specify the com port???
02-19-2005, 03:42 PM
#7
GPS.Connect (COMPORTNUMBER)
02-19-2005, 03:43 PM
#8
02-19-2005, 03:49 PM
#9
thank ya stevie, just what i needed
02-19-2005, 04:04 PM
#10
Any idea why i'm getting useless data from my GPS, it is working fine in other applications, and i double checked my gps unit to make sure its set to NMEA 4800 bps
02-19-2005, 04:23 PM
#11
it's got to be that active x control...
I dont know why you need an active x control to parse the string... write the code yourself it'll take a few minutes that way you know what your dealing with...
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
02-20-2005, 02:30 AM
#12
I'm sorry, and you are....?
Here is a simple example of getting gps data from a serial port.
[H]4 Life
I'm a lesbian too.
I am for hire!
02-20-2005, 02:37 AM
#13
NMEA data is so easy to parse, it's almost easier to write your own algorithm then it is to try and use someone elses control.
02-20-2005, 02:43 AM
#14
My Village Called
Yeh, just like caller ID data
Quick question about parsing data: can you get a smooth update of a digital speedometer using GPS speed?
02-20-2005, 02:47 AM
#15
thankd frodo, little too tipsy to mess with it now, but i'll check it out in the morning
| Thread Tools |
| Display Modes |
Linear Mode
