Old 02-17-2005, 11:00 AM   #1
Vchat20's Avatar
Streets & Trips GPS Functionality?
Just wondering if anyone has tried out Streets & Trip's GPS/Navigation Functionality at all and can give an idea on the performance of it. reason i ask is because thanks to my mom's job (she's a bus driver and needs to do her own routes) she uses streets and trips and usually gets the newest version every year. right now weve got 2005 and i noticed its got navigation functionality built in, but with no gps hardware, its hard to test.
edit: lol. nvm. guess i didnt search hard enough (hypocrit ). apparently its not a very good peice of navigation software. oh well.
Your everyday carpc geek and tech guru at your service. *bow*
Vchat20 is offline   Reply With Quote
Old 02-17-2005, 01:52 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
It's okay but you have to start the GPS manually every time and the map colors are difficult to see in bright sunlight and they can't be adjusted.
As you noted, there are better products out there.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 02-27-2005, 08:22 PM   #3
will1384's Avatar
I use it - I got the 2004 ver - it sucks for incar use - but its got to
be the best I have found at finding street level places - a few of my
truck driver friends use it because of that - but using it for GPS is
a pain - its just a good map only software
will1384 is offline   Reply With Quote
Old 02-27-2005, 09:42 PM   #4
That's a pretty accurate description, I ran it over the weekend, drove about 400 miles. If you set it up proper when you start it's ok for giving you accurate information about your surroundings, it gives you speed and direction. But if you want anything more its a hassle to get through the menus and whatnot with a touchscreen while you're driving.
-w
waltwalt is offline   Reply With Quote
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 05:54 AM
Streets & Trips 2004 Autostart GPS Jailer GPS 1 10-22-2004 02:22 PM
MS Streets and trips with MS GPS module out tomorrow. deer killer GPS 2 08-15-2004 04:49 PM
Streets & Trips GPS Update Interval Seanster GPS 3 11-25-2002 09:39 PM
M$ streets & trips? GPS? ppgt94 Software & Software Development 3 04-12-2002 09:14 AM
