Old 02-17-2005, 04:09 PM   #1
GPS position
So I have MapMonkey's thing doing it's stuff with GPS running. I see my position around 200 feet from actual and assume building reflections must be causing the error. If so, how is this compensated for when driving around built up city areas?
davewuk is offline   Reply With Quote
Old 02-17-2005, 04:14 PM   #2
Raw Wave
Laidback's Avatar
It's not! Search for 'dead reckoning'. I don't think it will be the reflections, more likely that you don't see enough sats.
Edit: Ah, just read your other post, 4 sats is only just enough, the clearer the gps' view of the sky the better.
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 02-17-2005, 04:34 PM   #3
yeah I consistently have at LEAST 7, usually 9 sats.. it's been within 10 ft, if not less.
Before I found the "optimal" location for the gps receiver in my car, i had times when it was 3 or 4 satellites...
man, 3 was sometimes off by 200 or so feet... 4 wasn't nearly that bad, but still, you may be barely holding onto that fourth one so it may as well be 3 sats.
Get a better position and more sats, and you should be fine.
Good luck
wizawuza is offline   Reply With Quote
Old 02-17-2005, 04:37 PM   #4
Raw Wave
Laidback's Avatar
Good luck
See here for better positions - http://users.forthnet.gr/ath/nektar/kma/main.htm
Laidback
Laidback Carputer
Old 02-17-2005, 05:30 PM   #5
Laidback...
Thanks for replies, will have to hit a bit of open ground and see what happens. Surely cities like London & New York for example where most buildings are high rise, sat signals will be greatly reduced, won't this affect operation or is there still enough blue sky to gather sufficient info?
Old 02-17-2005, 05:34 PM   #6
Raw Wave
Laidback's Avatar
Laidback...
No, it does affect it, greatly! So do tunnels & underground carparks! OEM sat/nav is linked to the odometer and probably a giroscope. So if there is no GPS signal but your odometer says your moving, then....
Laidback
Laidback Carputer
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
OEM GPS mod. Writeup + Pics IntellaWorks Hardware Development 67 07-04-2006 03:59 AM
4Runner GPS Position Teknoledgi GPS 19 05-31-2005 07:12 PM
GPS position davewuk MM Bugs 1 02-17-2005 04:00 PM
gps tripmate position time? schrodos General Hardware Discussion 7 11-29-2000 02:21 AM
