Old 02-19-2005, 08:59 AM   #1
Unhappy The BU303 dim led blues...
I've got a BU303 and it's a fantastic bit of kit - or was.
Now the LED is dim and it's not sending data - it sometimes works for 5 mins or so then packs up again. I searched the back posts and people say it might have water inside (it's been on the roof of the car for about 4 months through winter). How do I open it up to try to dry it out? Anybody had any luck doing this?
Cheers,
John
Turbocharger is offline   Reply With Quote
Advertisement Sponsored links
Old 02-19-2005, 09:08 AM   #2
Cheers,
John
remove rubber pad on backsid of unit. then you will find set screws remove them (2) gentle pry apart.... make sure you watch for the little led clear insert not to pop out it is held in by the 2 parts of the shell being together (wedge fit).
mdrt4me is offline   Reply With Quote
Old 02-19-2005, 09:43 AM   #3
Naah, tried that. I peeled the rubber pad off the bottom and pulled the magnet out, it's just a blind recess
JB
Old 02-19-2005, 10:03 AM   #4
I feel stupid now. I'd peeled the rubber off but not seen the two screws you mentioned.
It's in front of the hairdryer now, let's hope it recovers! Thanks for the advice
Cheers,
John
Fabrication Source Websites (LED, Plastic, Plexiglass, Fiberglass) nFiniteTuning Fabrication 21 05-03-2006 11:28 AM
3mm LED into 5mm LED holder? Coeus Hardware Development 9 01-28-2005 12:18 PM
My BU303 vs. Rikaline 6010 Review Nico3k The Review Palace 32 01-05-2005 11:42 AM
D3 in C# application jadz Map Monkey 4 11-18-2004 09:29 AM
Telematics.net IntellaWorks Software & Software Development 40 11-05-2004 08:20 PM
