The MP3car.com Store
Thread Tools Display Modes
Old 03-16-2005, 05:50 PM   #16
Vehicle: 04/VW/Golf
My Photos: (0)
Quote: Originally Posted by JC-S60
The poor radio-reception could be due to the fact that it might be an active antenna... If the factory HU sends out power over the coax (as with the GPS-receiver), an aftermarket HU probably won't do that.
JC-S60 ,
Seems you where right on the money with this. It is in fact an active FM antenna. I did some searching and found an adapter ... here
$25.00 , one more thing to buy. Damn this is getting expensive . Anyway thanks for the help.
VWmike is offline   Reply With Quote
Sponsored Links
Old 03-16-2005, 07:32 PM   #17
Raw Wave
My Photos: (0)
Is the reception much better with an external antenna than the typical GPS mouse type when also placed on the roof?
Chris31 is offline   Reply With Quote
Old 03-16-2005, 07:34 PM   #18
MySQL Error
jcdillin's CarPC Specs
jcdillin's Avatar
Vehicle: 2002 Dodge Ram 1500 Quad Cab
My Photos: (3)
well I had a serial GPS unit sitting on the deck above my trunk and I would only get about 5 to 7 sats, with the external antenna and the Garmin, I never have less than 9 most the time it's 10 to 12
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 03-16-2005, 08:10 PM   #19
Raw Wave
My Photos: (0)
Cool,
Since this OEM + antenna solution is brough up my interest has sparked up again. I have a garmin GPS16 with a built in antenna. I get 3 to no lock in a dense area, about 6-9 in open space. I have been thinking year ago if its worth the money and hassel to upgrade to OEM + antenna.
Can we conclude that the build in antenna is not as good as the external one?
Old 03-17-2005, 02:27 PM   #20
wagonerd's Avatar
Vehicle: 2003 VW Jetta GLI
My Photos: (0)
possible tv antenna?
not to turn this into another tv antenna thread but, what are the odds that this antenna would give better reception for a tv tuner? (sorry...had to ask )
wagonerd is offline   Reply With Quote
Sponsored Links
Old 03-20-2005, 10:35 PM   #21
Vehicle: 2004 Jetta GLS TDI (biodiesel)
My Photos: (0)
Quote: Originally Posted by VWmike
The shark fin is a factory VW part, P/N 1K0-035-507-C .
So this antenna supports FM and GPS? I wish it supported XM too. I wonder where the antenna is as a factory option on the 2005 models. I would be really nice to consolidate all the antennas into a single factory antenna.
Zip-Lock is offline   Reply With Quote
Old 03-21-2005, 08:42 AM   #22
cheap custom title
JC-S60's CarPC Specs
JC-S60's Avatar
Vehicle: 01 Renault Espace BiFuel | Mitsubishi Canter | BMW R1200GS Adventure | Yamaha YZF600R | Honda CB650
My Photos: (0)
As TV-frequency is nowhere near Radio/GPS frequencies, it won't improve tv-reception at all.
JC-S60 is offline   Reply With Quote
Old 05-22-2005, 01:57 PM   #23
Stonewall78's Avatar
Vehicle: '99.5 VW Golf TDI
My Photos: (0)
P/N FA1-NCRJ-C01-0 / GPS
P/N FA1-NDRJ-C01-0/ am/fm
Thanks for all the info Mike. I don't have to worry about crimper and cable etc as I have them all at work and I make RF cables all the time. Thanks alot of the part number on those connectors though. I would order an antenna from impex but they are don't like to ship to canada and their prices seem to be getting higher and higher
Stonewall78 is offline   Reply With Quote
Old 07-04-2006, 10:11 PM   #24
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
Man - I wish you still posted here VWmike!
Unfortunately the link to the first cable is bad (it was an ebay auction... )
Anyone have any more info on this cable?
edit
ok - I've done a bit more reading and searching, since I'm not using a case, I don't need to worry with the BNC connectors. So this leads me to my next question. What kind of connection is made to the card its self? Is it a MCX connection on the card and at the antenna? If I'm seeing it right, it appears that the reciever has a female connection built onto it, so that end of the cable needs to be male? What about the antenna end? Male or female? I'm thinking that this cable would be what I would need but I'm a little unclear. Anyone? Link to cable
Also, regarding the mention of the connectors:
Is this because the antenna only comes with ONE end and you need to buy the other?
I'm not worried about the FM part of this just yet. If I can find a decent FM card, I would be happy to utilize that part of the antenna as well.
Stonewall78, I have put together the following information about the shark fin in hopes that if you do decide to take on the mod it will go as smooth as possible.
Gps shark fin/ 1K0-035-507-C
The antenna is part of VW's navigation system and cost $110 US. Should be able to get it at any VW dealer . I purchased it online here... Antenna
Cable 1
The first cable you will need is available on ebay. This cable is the one connected to the GPS module and runs to the back of the case. $12.50 US
Link
Cable 2
This is probably the hardest to aquire and runs from the back of the case to the antenna. The cable you will need is RG174 or RG316 and terminated with a male BNC connector. I acquired this at work and didn't need to buy it but have done some searching and you can buy cable assemblies with BNC connectors on both ends fairly cheap.
Link
This leads me to the connectors that are on the antenna. They are made by Amphenol and detailed information on them can be found here
The blue one is GPS and purple is AM/FM radio. I bought them online from digi-key and where about $4.00ea. Digi-key
The connectors do require a special crimper inorder to crimp a ferrule around the outer shield of the coax. Although if you have above average soldering skills it is possible to solder the outer shield to the connector. After assembling the cable I would recommend checking that the center conductor and the shield are not shorted together. This can be checked with any ohmmeter and you are looking for infinite resistance. If it is shorted then the 3vdc being supplied by the gps module will be going straight to ground and will it will fry.....
I think that covers just about everything. I have tested the gps operation with mapmonkey and I have locked on to 7 satillites with the antenna strung out my back porch about 7ft away from my house . I can only guess that this would only improve the farther I get from the house. I have not installed this in my car yet as my install is still months away but cannot find any reason why it won't work.
Just a note about the Radio portion of the antenna. I have yet to do any testing in regards to reception quality with a aftermaket head unit. I have read some posts on other forums about poor radio reception when they remove the factory VW radio and replace it with a aftermaket one. This is something I can live with becuase I can't remember when the last time I listened to FM radio. Excellent FM radio reception is something you absolutely must have then you might want to wait unitll I get my new head unit and can verify the reception quality....
Good luck
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 07-04-2006, 11:06 PM   #25
_
My Photos: (73)
Quote: Originally Posted by jcdillin
And here it is installed in the computer
I know that you said you made one of these cables. I'm trying to figure out exactly which one.
Is it the one that goes to the serial port?
Also, I'm trying to understand why you went to a serial port on the back of the machine that leads to nothing instead of going to a serial port actually on the mobo. Or did you just tap into the serial port back there instead of going to the mobo directly?
Thanks in advance!
Jan Bennett
Old 07-04-2006, 11:43 PM   #26
_
My Photos: (73)
PS: if anyone is interested, I've found the antenna listed for right at $100 on this site:
https://www.1stvwparts.com/part_number.html
Just search under the OEM part number: 1K0035507C
Jan Bennett
Old 07-24-2006, 01:41 AM   #27
Change's CarPC Specs
Change's Avatar
Vehicle: 03 Honda Civic sedan
My Photos: (0)
Spiffy SiRF III module: http://www.sparkfun.com/commerce/pro...roducts_id=652
I'd buy one if I hadn't already bought a Garmin GPS 15H. Ah well, when the time comes to replace it there will be GPS/GLONASS/Galileo combo units on the market
System status: in progress
Change is offline   Reply With Quote
Old 07-24-2006, 10:38 AM   #28
_
My Photos: (73)
so what's different between that module and the Garmin?
I notice that it only has a 110v power supply....wonder if the wall wart is just converting it to 12v? or if the unit takes 110V to begin with?
and I'm gathering that since it's an eval version, it's still in beta mode?
can you go into a bit more detail about the GPS/GLONASS/Galileo units?
What is special about those? I'm gathering it's more sensitive? more accurate?
Jan Bennett
Old 07-24-2006, 03:30 PM   #29
Change's Avatar
My Photos: (0)
The SiRF III chipset is what's being used in some of the newest Garmin GPS receivers (like the GPS60Cx), it's a 20-channel WAAS-enabled receiver with better sensitivity than the Garmin GPS15H/L (-159dBm for the SiRF III, -135dBm for the Garmin) and ever so slightly less power consumption (.23 watts vs .33 watts...not enough to make any kind of difference in a vehicle).
Most likely takes a range of something like 9 to 15 volts. Take a look at the board, all it has is a linear voltage regulator , TTL->RS232 level shifter, and the GPS module.
No, it's in production. The eval board is just that...for people to evaluate the unit and decide if they want to use it in their products/projects. My previous GPS, a Motorla M12 module, came on an eval board. Usually all the eval board does is provide power regulation, TTL/RS232 level shifters, and an antenna connector so it's easier to experiment with. Difficult to play around with something when it wants 3.3v and spits out TTL on a tiny pin header.
Galileo and GLONASS are other satellite-based positioning systems. GLANOSS is Russia's system, Galileo is the European Space Agency's system. See:
http://en.wikipedia.org/wiki/Galileo_positioning_system
http://en.wikipedia.org/wiki/GLONASS
A receiver that's able to make use of more than one positioning network will be a bit more robust and accurate.
Old 07-24-2006, 04:18 PM   #30
My Photos: (0)
That antenna is actually only about $80. I got mine directly from Germany for only $80
TDIGPS is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Pics of OEM LCD installs here: Scouse Monkey Fabrication 44 01-20-2008 12:16 PM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 05:54 AM
OEM GPS mod. Writeup + Pics IntellaWorks Hardware Development 67 07-04-2006 02:59 AM
OEM GPS Modules. IntellaWorks Hardware Development 91 03-08-2005 06:29 AM
OEM GPS Boards - Sensitivity Level Comparisons edikp GPS 13 02-22-2005 11:14 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
