The MP3car.com Store
Thread Tools Display Modes
Old 08-03-2006, 02:10 PM   #31
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
Quote: Originally Posted by Change
Spiffy SiRF III module: http://www.sparkfun.com/commerce/pro...roducts_id=652
I'd buy one if I hadn't already bought a Garmin GPS 15H. Ah well, when the time comes to replace it there will be GPS/GLONASS/Galileo combo units on the market
I'm seriously looking into buying this card.
However, I'm a bit unclear as to if the antenna here on the sites store will be able to hook up to it?
I should only need that card, right? Would I need anything else other than an extension cable?
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Sponsored Links
Old 09-10-2006, 01:39 PM   #32
wi77iam's Avatar
Vehicle: 2004 Subaru WRX STi
My Photos: (0)
Hey Red,
I just ordered this Sirf III eval board to replace my Garmin 15L. I'm hoping to get better sat coverage when driving near trees/buildings.
You can buy either the board by itself or as a kit. I'm getting just the board since I already have an antenna, and I will hook it up to the RS232 port on my mobo and power it from 5v.
The kit comes with the board, an active antenna, serial cable, lithium battery and wall power supply (which you probably won't need).
wi77iam is offline   Reply With Quote
Old 11-25-2006, 12:03 PM   #33
My Photos: (0)
does anyone know what card i should get as this post is kinda outdated. im basically am going to use my shark fin antenna.
disc0monkey is offline   Reply With Quote
Old 11-25-2006, 05:32 PM   #34
wi77iam's Avatar
My Photos: (0)
I've been using that Sirf III board for a couple months now. Works great - almost instant lock and pretty much continuously tracks at least 6 sats, even under trees and around buildings.
Old 11-25-2006, 05:39 PM   #35
My Photos: (0)
the link doesnt work
Old 11-25-2006, 06:23 PM   #36
My Photos: (0)
what would be the type of connector coming out of the receiver
Old 11-25-2006, 08:58 PM   #37
_
My Photos: (73)
I'm using the ET301 (without the battery), and am very happy with it.
I regularly get 8 sats locked, and by the time I boot up, it's already locked. If you're not completely shutting down every time you exit the car, you'll want the battery.
Jan Bennett
Old 11-25-2006, 11:23 PM   #38
My Photos: (0)
looks good to me can you tell what kind of plug is for the antenna on the chip side?
Old 11-26-2006, 08:43 AM   #39
_
My Photos: (73)
click on the 'datasheet' link, it will have all of the information you need, including the connector type.
Jan Bennett
Old 11-26-2006, 09:51 PM   #40
My Photos: (0)
perfect thanks
Sponsored Links
Old 10-29-2007, 03:56 AM   #41
My Photos: (0)
Quote: Originally Posted by jcdillin View Post
Here is some pics of my Garmin GPS 15-LW
Since my shuttle pc does not have a internal serial port header, I made this adapter so I can just plug it into the serial port on the back of the machine.
I also put in the SMA connector so I can disconnect the antenna when I take the computer out of the car.
Wow, sorry to resurect such an old thread. But does anyone know what each type of connector that is that is going from the GPS module to the back plate? I want to make a cable identical to this for my setup and want to know for sure what kinds of connectors to look for.
[H]Bugster is offline   Reply With Quote
Old 10-29-2007, 07:01 AM   #42
MySQL Error
jcdillin's CarPC Specs
jcdillin's Avatar
Vehicle: 2002 Dodge Ram 1500 Quad Cab
My Photos: (3)
that is a MMCX to SMA adapter
this is close to the cable you need but the problem with this one is that the SM connector is reverse polarity, which is used for Wi-Fi applications
Link
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 10-29-2007, 11:50 AM   #43
My Photos: (0)
Link
Ah, thanks. So will this work?
http://www.wirelessnetworkproducts.c...ROD&ProdID=386
It's so damn expensive!
edit: This looks like a more reasonable price...though i need to find out if that is a male or female SMC connector:
http://www.sparkfun.com/commerce/pro...oducts_id=285#
Old 10-29-2007, 01:31 PM   #44
MySQL Error
jcdillin's Avatar
My Photos: (3)
Yeah the one from sparkfun should do just fine.
肚子笑痛了
S60 Install
Old 10-29-2007, 07:30 PM   #45
sxott's CarPC Specs
My Photos: (0)
Sorry to post here, but people are saying that they have a lock upon boot, is this the case from hibernation or fresh boot?
I have the ayay sir USB GPS and it gets plenty of sats, but when hibernating it takes awhile to get a new lock for some reason, like it is looking in the old spot for sats and doesn't immediately start a new scan or something. I say that b/c if you do a quick stop it locks right on, but after like an hour stop things take awhile.
My Install
sxott is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Pics of OEM LCD installs here: Scouse Monkey Fabrication 44 01-20-2008 12:16 PM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 05:54 AM
OEM GPS mod. Writeup + Pics IntellaWorks Hardware Development 67 07-04-2006 02:59 AM
OEM GPS Modules. IntellaWorks Hardware Development 91 03-08-2005 06:29 AM
OEM GPS Boards - Sensitivity Level Comparisons edikp GPS 13 02-22-2005 11:14 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
