Quote: Originally Posted by MGD
I had the same problem with Destinator. I had to got to control panel and set the com port to 4800, after that everything was just fine.
I think you ment set the bandwidth for the port to 4800, not set the com port number to 4800.
What com port number you use dosent matter unless something else on your machine is trying to use that same port number. I have the same device and my com port is set to com9 at 4800 bandwidth.
Also try this, this was the source of my problems with the same device.
Do not use the Delorme GPS diagnostic utility that comes with the device.
Do not use any Delorme GPS software for the device.
When you use the Delorme product it sets the gps device into some custom format that only Delorme software can read and will require a reboot for 3rd party gps software (routis,iguidance etc) to recognize the device.
Use hyperterminal on your pc to test the GPS device is operateing correctly.
Instructions here
http://www.delorme.com/support/multi...=&P=17111&C=28
To change the com port number of the device to insure no other software is trying to connect on the same port
Device Manager> Ports (COM & LPT)>Delou Serial to USB GPS COM port 3> right click device>Properties
Port Settings= 4800
Flow control= Hardware
Advanced button>Com Port Number> choose a high number, but lower than 16.
