So i gave it my best shot and i an unpleased to say that it isn't working. I did as jcdillan said but it didn't work.
I got the adapter cable that i was waiting on and cut one end striped it and soldered it as instructed. After a test run in the car the GPS saw between 0 and 2 satelites but never locked onto any of them.
Then i spent several hours trying different things like changin the pads it was connected to, connecting all ground pads, soldering to a pin labled ANTPWER and GRND. All of this showed now difference.
I then busted out the multimeter and apparently between the center pin and the ground pin i was unable detect any voltage. The antenna is expecting between 3-5 volts.
I then looked at the deluo website and they had something that is interesting.
http://www.deluoelectronics.com/cust...p?productid=50
My conclusion is that either the antenna is screwey or the GPS circuitry is different although the two images look very similar. I also could have damaged something when removing the internal antenna because i had to use a lot of heat to remove it.
Any one have any suggestions... maybe something that i haven't thought of before i trash this gps and get the one with the external antenna connector?
