Old 03-21-2005, 12:49 AM   #1
vxcarpc's Avatar
Mount USB antenna inside or out?
Just wondering I'm about to get my first USB GPS mouse reciever and wondering if it's any more worth mounting the antenna outside or inside the window of my car.. Will it make much of a diff in signal strength?
vxcarpc is offline   Reply With Quote
Old 03-21-2005, 01:09 AM   #2
My Village Called
0l33l's Avatar
You just have to test it. Some windshields have a coating that prevents signals from penetrating it.
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 03-21-2005, 01:20 AM   #3
sfay93's Avatar
Mount it outside if you can. It will have a greater field of view and get faster satellite locks.
ATVMS.com
sfay93 is offline   Reply With Quote
Old 03-21-2005, 01:51 AM   #4
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
It will get better reception outside, hands down. However, you may be able to find a location inside the car that will work good enough. Mine is mounted on the dash and gets decent reception. However, it got BETTER reception before I changed to a Xenarc screen and found that it interferes with the GPS.
In fact, my original location was to mount it on the back shelf of the car. I tested this with my laptop and ran the antennae to the back shelf. It worked superbly. I then installed the PC underneath the back shelf (in the trunk) and the RF rendered it incapable of getting a lock.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 03-21-2005, 01:25 PM   #5
My Village Called
0l33l's Avatar
Some people mount it in the mirror
GammaControl v2.4
SKINbedder v3
Old 03-21-2005, 07:30 PM   #6
vxcarpc's Avatar
is there software you can get to test the signal strength? Can you get a % figure on signal strength?
Old 03-21-2005, 09:55 PM   #7
Raw Wave
http://www.visualgps.net/VisualGPS/default.htm
I use it for setting up, also tells you which sat number the GPS is picking up. Operating on WAAS or not by looking at the locked sat number above 31 (not 100% sure, maybe 32?)
Chris31 is offline   Reply With Quote
Old 03-28-2005, 12:38 PM   #8
I have my GPS antenna mounted not only inside the car, but UNDER the dash.
The reception is very good, it routinely sees 6-7 satellites. While I agree that from a signal strength perspective, mounting the antenna outside the car would be better, I think in most cases mounting inside (and under the dash) works quite well. Plus, I think the stealth look is a big plus.
This picture shows (in red) where I ran the USB cable from the USB hub behind my LCD, to the GPS reciever/antenna under my dash.
I would of course reccomend testing your GPS/car combination, but I think this will work for most people.
eleventh is offline   Reply With Quote
Old 03-28-2005, 11:37 PM   #9
vxcarpc's Avatar
I have a part 2 to the question. What's the maximum recomended length of a USB cable with a GPS reciever that anybody in here's got? I am thinking of mounting it on the back of my car up on the roof which is about 3 or so meters from the back of the pc..
CAR INFO HERE
"He who dies with the most toys, wins".
Old 03-28-2005, 11:56 PM   #10
Curiosity's Avatar
Mine is under the dash too and I usually get 10 sats. There just happened to be a 1" high space between a metal thing and the top of the dash, plus a little double-sided tape and it fits well. I have the wifi dongle under there too because there were 2 spots like that.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
need d-link usb fm antenna th3madc0w Classified Archive 0 03-07-2005 04:53 PM
USB adaptors & DIY antenna = "Poor Man's WiFi" Terran Wireless Communications 10 11-08-2004 10:52 PM
would a omni ceiling mount antenna work in my trunk? aoLhaTer Wireless Communications 0 07-14-2004 03:33 AM
USB XM Radio antenna Scrapez General Hardware Discussion 5 09-05-2003 02:00 AM
