Old 03-22-2005, 12:49 PM   #1
Buying Holux, but should I get 230 or 231?
OK, I have narrowed it down to Holux, and they have two models I can use (both Bluetooth for my PPC in the Mazda and USB connection to the carputer in the Chevy - actually they support both at the same time!), but which one should I get?
The 230 has EGNOS, which I understand makes it more precise in Europe. The 231 hasn't got that, but it has XTrac 2.02, which should increase sensibility.
So can somebody please tell me what I should choose for general use, and for speed cam warnings via TomTom?
Thanks in advance!
Tor - The MediaSUV
Mastiff is offline   Reply With Quote
Old 03-22-2005, 01:38 PM   #2
I would advise that you get the 231 if it will be used on the dash because the xtrak teally helps getting a signal. there is 1 problem though an that is it will turn off after 10mins if no bt signal is detected even if it is being used as a usb mouse so you will have to get the new firmware from holux
jamiecc is offline   Reply With Quote
Old 03-22-2005, 01:39 PM   #3
OK, thanks! So the EGNOS-precision doesn't make me miss turns or speed cams?
Tor - The MediaSUV
Old 03-22-2005, 03:11 PM   #4
I dont think it makes that much difference it hasnt given me problems. But you get more satelite locks so i would think that should compensate
Buying hardware online JorisC Newbie 2 05-22-2005 12:30 PM
Rikaline 6010 GPS or Holux 210 edmonton_mr2 GPS 2 01-15-2005 02:35 PM
Rikaline 6010 OR Holux PaCMaYNE Classified Archive 4 11-10-2004 05:11 AM
