The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 04-04-2005, 01:16 PM   #1
My Photos: (0)
No Sat Lock Inside Car With Rikaline 6010 Gps
i get no sat locks when my RIKALINE 6010 is postioned inside my car (vw golf mkiv), no matter what location i put it . i get at best two red signals . when i put the RIKALINE 6010 on the roof outside i get atlest 8 green locks, move it inside and they all go, untill the nice lady tells me signal too low ( d3 )
i have tried sirf mode , removing the battery and tin foil but all have no effect. any tips would be great . does any one know where the golf mkiv have there factory fitted receivers postioned ?
kyrenia is offline   Reply With Quote
Sponsored Links
Old 04-04-2005, 03:33 PM   #2
drait's CarPC Specs
drait's Avatar
Vehicle: 89 Supra Turbo, 01 F4i
My Photos: (0)
Make sure that you're facing the top (the side with the LED) of the receiver towards the sky when mounting inside the vehicle. It works best if it has a clear view of the sky too; so through clear glass helps. Tint with metallic content can cause reception issues also.
Mine is on the inside of my tinted rear hatch glass and I get anywhere from 6 to 9 sats.
89 Supra Turbo
drait is offline   Reply With Quote
Old 04-05-2005, 01:59 AM   #3
My Photos: (0)
have tried all windows and even with windows and boot open with the Rikaline 6010 looking stright up to the sky with no locks, take it out of the open boot and on the roof , all sats come back. i see that other vw golf/bora owners have there set ups working just fine. my golf is bog standard 1.6 se, so why me with the problems . i guess the only way to to see whats going on is to get a second recevier and test that one .
Old 04-05-2005, 03:40 AM   #4
DeltaFX's Avatar
Vehicle: 2002 Mux'd 206 peugeot
My Photos: (0)
Do your car windows have a slight purple tint sometimes ? It looks like you have Anti-IR coating (Titane's nano particules) that block radio waves.
DeltaFX is offline   Reply With Quote
Old 04-06-2005, 02:25 AM   #5
My Photos: (0)
got it working . got hold of a usb extension cable and postioned the mouse right under the front windscreen. seems to like that and now get 2-3 locks inside car. still takes a wile to lock ( 5 minutes) but at least i can now use it . thanks for help
Old 04-06-2005, 08:30 PM   #6
TaylorMade's Avatar
Vehicle: 2K1 Yukon XL Denali
My Photos: (0)
wow. I had the same problem with the earthmate inside my vehicles. no matter where I put them, it never got more than two or three sats. I went to the rikaline specifically so I could put it on the roof (magnetic and weatherproof) and i get locks as fast as I can start the GPS applications. I'm talking full on 8 or 9 sat locks. VERY pleased with the investment.
Denali XL
Carputer yanked from the Jeep and installed in the Denali...pics coming!
Check the old one here
TaylorMade is offline   Reply With Quote
Old 05-04-2005, 03:24 PM   #7
ITL
ITL's Avatar
Vehicle: 2004 Acura TL 6MT
My Photos: (0)
What are you using to determine the number of sat locks you are getting?
CarPC #3: 99% Complete
Pentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more!
old carPC
ITL is offline   Reply With Quote
Old 05-08-2005, 01:28 AM   #8
Has trouble reading.
sanbas's Avatar
Vehicle: 1991/diamante/mitsubishi
My Photos: (0)
i am using the rikaline 6010 with iguidance 2.1 here is what worked best for me on a 4 door sedan.
If i place the receiver on the top of the trunk i got 8+ locks everytime (but then i would have to open the trunk and put it back inside evertime i left the car so someone doesnt just go and cut the cable off)
So i put it inside the rear window (my car has a pretty dark tint), this resulted in 4 or less locks usually 3. It worked fine, but i wanted to have more sat. locks if i could get it.
So...i put it in the section of the rear brake light, where the window doesnt have a tint and it consistenly get 7+ satallite locks...works great!
Moral, window tint and/or rearwindow defrost wires can reduce the satallite locks GREATLY!!!
sanbas is offline   Reply With Quote
Old 05-08-2005, 10:52 AM   #9
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
My 6010 is under the dash behind the gage cluster that the driver looks at. Getting 4-7 sats. There is no tint on a front windshield and it is completely out of view.
Is there a spot behind your gauge cluster to place it? there is only a piece of plastic, then the front windshield.
Depending on the rake of the windshield if you tuck it in deep it has a clear view to the sky.
Took a little of fidgeting to get it right, it went from 0 sats to 4-7 just by moving it an inch.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
How do I setup my GPS Application ? guino RR FAQ 0 03-20-2005 02:17 PM
Rikaline gps led not blinking vipergda GPS 3 02-28-2005 10:28 PM
My new car, pic inside lstrunk Off Topic 4 07-13-2002 09:59 AM
GPS in my car - Newbie hasato General Hardware Discussion 2 01-29-2002 08:11 AM
bringing the inverter inside the car dizzzyduck General Hardware Discussion 4 07-08-2000 04:04 PM
Sponsored Links
Ad Management by RedTyger
