Old 04-07-2005, 11:28 AM   #1
kore is on a distinguished road
GPS Location
I've got a GPS mouse and it's weatherproof and magnetic. I want to install it on my roof, just above the rear window. Does anyone how easy/hard it is to get it outside the car without drilling holes? Any help would be greatly appreciated. I drive a 2004 Nissan Sentra SE-R Spec V. Thanks....
David
Via Epia V 1ghz motherboard
768MB PC133 memory
LinITX 7" Touchscreen monitor
60GB 3.5" Quantum HDD
16X DVD-ROM
Polstar USB GPS receiver
Still playing around with front-ends
kore is offline   Reply With Quote
Old 04-07-2005, 12:30 PM   #2
maquina2k5 is on a distinguished road
I'm put me Delorme GPS receiver inside close the back window and work grate!
maquina2k5 is offline   Reply With Quote
Old 04-07-2005, 02:33 PM   #3
Skipjacks's Avatar
Skipjacks is on a distinguished road
Mine's inside the car under the glass and works flawlessly.
Skipjacks is offline   Reply With Quote
Old 04-07-2005, 03:14 PM   #4
Chairboy's Avatar
Chairboy is on a distinguished road
I put mine under my dashboard. It's invisible, and works great. Glass is not the signal killer. Before you do anything rash, try it inside and just look at how the signal looks without making assumptions.
Chrysler 300 - Fabricating
http://hallert.net/
Chairboy is offline   Reply With Quote
Old 04-07-2005, 03:37 PM   #5
Bobby Digital is on a distinguished road
Even though it works inside, I bet you it would work that much better if it was outside. Nothing blocking the signal will always be better than something blocking the signal, no matter how insignificant the blocking material is (plastic, glass, etc).
I do agree though, try it inside first, if it works well enough then don't bother with trying to get it outside. If you do have to mount it outside I think the only way to get it out there would be to drill a hole or to use an existing hole (radio antenna location perhaps?).
Bobby Digital is offline   Reply With Quote
Old 04-07-2005, 06:12 PM   #6
Chairboy's Avatar
Ok, let me rephrase. Not only does it work great, but I regularilly have 8+ satellite and maintain a solid 3D lock always.
I OFTEN have 11 sats.
but don't let my experience get in the way of your theories...
http://hallert.net/
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
OEM GPS mod. Writeup + Pics IntellaWorks Hardware Development 67 07-04-2006 03:59 AM
Best mounting location for GPS receiver? Arathranar GPS 17 03-22-2005 12:36 AM
How do I setup my GPS Application ? guino RR FAQ 0 03-20-2005 03:17 PM
Triggering events based on GPS location electron GPS 5 09-16-2004 12:57 PM
