Old 04-11-2005, 09:03 PM   #1
maxxell is on a distinguished road
IGuidance + Royaltek Sapphire + ??? = Problem
Hey all,
I just got this in the mail: http://www.inavcorp.com/products/iguidance2_combo.html
All excited, I installed the software and the hardware and it all worked great. I plugged the Sapphire into my powered 1.1 hub up front and ran the wire up the dash, got my first GPS lock nearly instantaneously. Fantastic...
Did a full shut-down, worked fine, and came back fine. Then I opened FP & IGuidance and drove around, then did a standby (my normal procedure when leaving the car). Standby worked fine, until I turned it back on. None of my USB devices were responding. That's my lilliput, my griffin powermate, and the GPS receiver. And IGuidance wasn't moving, it was what was on the screen when I went to standby. FP was still playing my music, though.
After a few minutes, I turned off the car and the carputer just died. Then I turned it back on and it came on fine. Gave me a "windows has recovered from a massive nuclear detonation" error (or something like that) and worked fine. I disconnected my GPS from the hub, as I thought that was what it was, and kept going without. I'm going to try plugging the Sapphire straight to the MOBO as opposed to the hub.
Anyone have any ideas what could cause that? I would much prefer the Sapphire up front because I know the hub's power gets turned off on standby because it's powered off the +5 from the opus. Though if it's in the back, whatever. The little receiver isn't going to kill me.
Thoughts? Thanks!
A car without turbo is a car with perpetual lag.
My Ride
My New Page
maxxell is offline   Reply With Quote
Old 04-11-2005, 09:58 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Hmmm. I have a Royaltek Sapphire with the USB connector. It uses a little program that routes the USB to a serial port. Is this how yours works?
I have it up front on the dash, plugged into an unpowered USB hub and it works fine. I've never had a glitch with it waking from hibernation. I don't think I've ever tried it from standby, though.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 04-11-2005, 10:21 PM   #3
Could there be a difference because I use a powered hub? It isn't on all the time, it gets power with the rest of the PC hardware (CDs, HDs, etc.). I'd imagine a bus-powered hub runs power all the time. When I plugged the receiver into the MOBO itself, everything works just dandy. I'm thinking it's because of the power timing. Not a major headache, I am not concerned that this little receiver is going to kill my battery. It is, after all, the only USB device that keeps power during standby.
My Ride
My New Page
Old 04-12-2005, 01:46 AM   #4
Bugbyte's Avatar
I wouldn't worry too much about it. I have the Royaltek, touchscreen, and keyboard reciever (wireless) on the unpowered hub and I presume they are all drawing power. I've never actually looked into it, although I could swear the keyboard receiver doesn't light up if I press a key with the car off. It ought to if it was getting power.
In any case, I also have the Xenarc plugged into the cigarette lighter, so it's on standby all the time too. I drive the car daily, but not always on the weekend, so I can vouch for it starting easily after 3 day weekends, but not more!
I'd think the problem for your GPS is as you say, the powered hub. Try using an unpowered one (dunno if you can simply unplug the powered hub and make it "unpowered").
Want to:
-Where is the iBug?
iGuidance SDK Quattro GPS 57 06-23-2006 08:37 AM
Launching iGuidance under Media Engine StationRocket GPS 4 11-29-2004 01:56 PM
Lilliput TouchKit problem solved! AAVfReaK LCD/Display 2 10-16-2004 04:51 PM
Iguidance reroute problem? samc GPS 17 10-02-2004 11:49 PM
Embedded iGuidance Window Size? All4Sky MediaCar 3 08-27-2004 09:00 AM
