12-13-2006, 07:06 PM
#31
Ya, I'ml in to contribute as well. Keep us posted on the rent a coder status.
12-14-2006, 12:37 PM
#32
I'll put up a few bucks.
VIA EPIA M10000
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
12-14-2006, 08:40 PM
#33
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
Hey guys, I got this from the guy today, what do you think? Go for it?
Quote:
I would be willing to tackle this as a two week project given:
1) Only operations will be add/delete/modify POIs and the only data guaranteed to be changeable is lat/long/name
2) Ruby will used as the language and the application will be console based
Since I don't have the software myself I will need a copy of the binary database file; you will also need to provide final testing of the modified data.
Features I think are possible:
- Adding a new POI (if limit is not reached), deleting an existing POI, modifying an existing POI
- Duplicating POIs; that is, when a new POI is created you choose a base object, this is crude but will copy over general information and "unknown bits"
- Mass-adding POIs based off of a CSV file (lat/long/name/duplicate base)
Problems:
1) Proprietary format/data structure unknown
2) Maximum number of entries allowed/supported by software
3) Lack of local software to ensure rigorous regression testing
Let me know...
12-14-2006, 09:57 PM
#34
That sounds like what we need, I cannot think of anything else that would be needed other than lat/long/name
I see no reason why that would be a bad thing, I am not familliar with Ruby but cannot think of why any language would be better/worse than another
I would be happy to supply a copy of the iguidance software under the conditions that he uses it for testing only and upon completion of the project he removes it from his computer (as to not infringe on copyright/piracy laws)
The only thing that bothers me about this is the "(if limit is not reached)". I am not sure why the software would have a limit on the POIs if they did not include a method of inserting new ones. Now it would make sense if the limit was what they had already included but if that was the case inserting a new one would not be possible without removing a pre-existing one.
I am not exactly sure what that means. Is he saying that to create a new POI we would in essence be duplicating an existing one and then changing the lat/long/name? If thats the case I see no problem with that method.
That sounds like a very important feature as inserting POIs one by one would be very time consuming.
Indeed, that is a problem, but if it wasn't in a proprietary format then it wouldn't be so difficult for us to figure out
Again, I am not sure why a limit would exist for a feature that wasn't intended to be increased, unless, of course the limit is the existing amount of POIs included in the software. If that is the case it isn't toally a bad thing if we can import CSVs, as we could remove all the ones for areas we did not intend to go and then import the lists for areas when traveling.
If he desires I will 'donate' my copy of iGuidance 3.0 so that he could have the software locally to "ensure rigorous regression testing". (Of course I would want it back when he was done!) I just need to brush up on the copyright/piracy laws to ensure that I wasn't doing anything illegal by sending him my copy of iGuidance.
To recap, I do not think this sounds bad at all. What was his Bid?
Also if the project is sucessful we should sell the technology to iGuidance so they can implement it into their next version
Let us know the bid, if it something reasonable I say lets do it.
12-14-2006, 10:36 PM
#35
Ok, I've told him we can provide a copy of the software for development and testing provided it is removed from his system upon completion of the project so we stay good with infringement laws.
Also made it clear that we have people to help test.
He's not sure if there is a limit on the POIs, so that will be something he'll find out. Hopefully and most likely there isn't a limit.
It was made clear that the mass add would be a HUGE bonus as IG comes with a few hundred thousand POIs and if we were to import it, other programs have many million POIs... so it's pretty much required.
He hasn't bid yet, but I did ask him in the last message for the charge/bid for the two different versions. With/Without Mass add.
/edit... lol guess we could sell it back to Inav.. lol hopefully this isn't going to cost us tooo much :-) it'll be nice though either way.
12-15-2006, 12:12 AM
#36
I don't quite get it, so the changes that he will make will allows us to add POI's? Or will it allow us to import POI from other software as initially mentioned in this thread? For example the POI' from Lexus or Acura Navi systems as they have several million POI and are very acurate unlike some IG POI's.
12-15-2006, 01:18 AM
#37
The changes would allow for importing new POIs by using a CSV (comma seperated value) file. So I guess the real question would be can we export the data from the Lexus/Acura/Whatever systems.
The export does not have to be made in a CSV format, but it is fairly simple to manipulate data into a CSV format so it could be imported into iGuidance.
MuldRick, do you know if the data on the Lexus CDs can be exported into any kind of text document? Or viewed as a list of some sort?
tsx004, I am glad you asked that question, because if we have no way of exporting the POIs list from other software then the value of this modification to iGuidance is greatly reduced.
12-15-2006, 08:45 AM
#38
MySQL Error
i have a copy of his lexus cd.. i'll check that tonight. Pretty sure the data on that disk was in .dat format though. This is HUGE if we get it done. Good work steve!
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
Developer of: RRFusion, MovieTimes, (new)RRMail, & RR Plugin Manager
Coming Soon:RRChrome, & CentraFusion
Is Your RR Plugin Managed?
12-15-2006, 09:34 AM
#39
Hey guys, his bid was $40 for a 2 week deadline, but he wasn't sure if he'd be able to complete it within that time frame, so I told him 3 or even 4 weeks is fine, and if he did achieve this, we would throw in a bonus (cuz $40 really isn't all that much).
If we can't figure it out, and it does come down to needing to find a way to export the data from the other manufacturer's cds/dvds, I'm sure we can have that as another job to throw at this guy as well
This is his reply...
Quote: Originally Posted by The Coder
For add/edit/delete/duplicate POI with ability to mass-add from CSV provided that I can release the code under an Open Source (such as the GPL) License and distribute it online. (This would also benefit you if any improvements were made.)
However, due to the problems presented by a closed file format (that it's around the holidays) the best deadline I can offer is 14 days (let's say, December 30). I can also NOT guarantee that I can complete this--in which case I logically wouldn't expect a claim on any of the commission.
I take software piracy seriously; stealing is stealing. Having the dataset is an absolute requirement and having access to the software would greatly speed up the testing cycle.
@DrDank - If you're still good for 'donating' your copy of IG3.0 just let me know and I'll let you know when and where it'll need to go if that's cool. He agreed to the copyright infringement bit (he kinda has to since all of our communications are tracked on that site and it's all legally binding  ). So it'll be removed from his system once the project is done.
12-15-2006, 09:43 AM
#40
Steve,
Have you (or anyone) considered drafting a real quick scope of work so that we are certain he is doing what is best for the RR/iG user community?
12-15-2006, 09:52 AM
#41
Quote: Originally Posted by W3bMa5t3r
... it's all legally binding
Oh crap, you said "legal". Somewhere in California, a certain person is probably on findlaw right now obtaining the precedance for this matter.
12-15-2006, 09:56 AM
#42
A scope of work hasn't really been drafted per se, but it is quite clear between the coder and I that if he is able to do this, at the very least we will have add/modify/delete abilities for POI and that the mass import function is pretty much a necessity. This is documented in all the communication between us and the service will hold him to this. The software will be released as Open Source, so if we ever need to make adjustments/improvements, anyone will be able to do so. Considering we don't have any of these features at the moment, this is at least a start.
Do you have any ideas/suggestions I need to push along as well? I posted this here so everyone would know what's going on and could offer suggestions as I have no clue when it comes to programming and all (other than some autoit bits) lol
12-15-2006, 09:57 AM
#43
lol
12-15-2006, 10:49 AM
#44
Sonicxtacy02 - Let us know what you find out in regards to the Lexus CD.
W3bMa5t3r - Tell me where and when, and I will send the CD. Another option for delivery of the software would include me creating a simple html document that acts as a digital signature and upon approval of said document the coder would be able to download the ISO (of course I will need to see if I can, in fact, extract the ISO) This would save the time of shipping, especially if this coder is located outside of the US.
$40 is a very resonable bid for this project, I was expecting a bit more to be honest. I don't know how "Ruby" coders can pay bills like that. I know in web development a 2 week project is going to cost MUCH more than $40 bucks. But of course I am not complaining that the price is lower that anticipated.
-DrDank
12-15-2006, 11:02 AM
#45
Something that may be important when i was thinking about how to tackle this, that would make this drastically easier is verifying no duplicate entries, for instance lets say somehow IG 3.0 has some POI's that the Lexus doesn't have, if you just use all those those few are gone, and if you just do a mass add of all Lexus POI, then duplicates occur, so backed before it adds each line, search through the file and then see if a duplicate line occurs, if not add, if it does skip it. Or was this already suggested?
CarPuter: 900Mhz P3 with 256 MB Mem, 160 Gig HD (Thanks kbreeden), Iguidance 3.0 GPS, Logitech PS2 keyboard, Bluetooth, WIFI.
Powered By Road Runner & DigitalFX Skin and Playlist Conveter
| Thread Tools |
| Display Modes |
Linear Mode
