Old 04-24-2005, 01:11 PM   #1
chilli_pepper's Avatar
What can cause radio interference with GPS signals?
Ok guys,
Heres the senario...I have been using a BU-303 for a few months hooked up to a laptop and sitting on my dash with MapMonkey for long and new journeys. The signal was 90% locked with it sitting on my dash which i was pleased with.
So I have now installed the car PC with an Opus run leads upto the front for a Xenarc and a usb hub/extension. The Gps is mounted in exactly the same place as it always has been but now wont lock...or many/any signals for the majority of the time.
Shove it on the roof....instantly locks with 6-8 sats.
Its really ****ing me off as it was all working so my feeling is something that i have installed must be interfering with the reciever unit itself.
So what i am asking is what could there be that i have instaleld that interfers with the GPS signals in the car?
I have extensively tested the reciever and it is working great, it does the same thing connected to a dedicated port, the hub or an extension and i have tried changing the position within the car and it makes no difference!
Please help me
Chilli_P
Epia 800 > 3.5" 30GB HD > Teac Slim CD > BU-303 GPS > Safecom Bluetooth > WiFi > Xenarc 700TSV > Opus 150
Current Status:Installed - tweaking
Want Widcomm 4?
chilli_pepper is offline   Reply With Quote
Old 04-24-2005, 07:03 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
RF interference from the PC or the power supply. I had an identical experience to yours. I picked out a nice spot on the rear shelf for the GPS, tested it with the laptop and it worked perfectly, always at least 7 sats and often more.
Installed the PC underneath the shelf. No lock. Didn't work. Had to move the GPS to the front of the car. Found out that when I swapped the screen to a Xenarc, it also interfered with the GPS signal!
Basically, anything in the 1.1 ghz band can potentially intefere with the GPS receiver.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 04-25-2005, 06:44 PM   #3
Well
I have a Xenarc...and as the car is soooo small i cant really get the reciever anywhere more than 1.5 meters (if that more like 1 meter) away from any of it...and if its away from the pc+psu then its near the xenarc!
Nightmare!
What are my options? could i wrap the pc and powersupply in foil or something like that?
How have u sloved your problem if you pc is in the back and screen in the front?
Cheers
Chilli_P
Want Widcomm 4?
Old 04-25-2005, 10:32 PM   #4
Im having a similar problem in another thread, using a Xenarc and a Garmin GPS mouse split from the same 12v plug; not that that should matter :/
http://www.mp3car.com/vbulletin/gps/48137-garmin-gps18pc-causing-mouse-pointer-act-strange.html
Rode-B[O]X: scrounging components
Bits I bought:
Xenarc 700TSV | DSSC | GPS18PC
Pieces Im looking at:
Axus TC600 WINXPe | EPIA * | GPS gadgets
trillion is offline   Reply With Quote
Old 04-26-2005, 02:03 AM   #5
Bugbyte's Avatar
Haven't really solved it. The GPS is about a foot away from the Xenarc. It gets intermittent reception. Never loses the lock for a real long time so I just put up with it.
My PC doesn't have a case. It would probably help if I put it inside a metal casing.
Old 04-26-2005, 02:12 PM   #6
phord's Avatar
No case on my PC. I mounted my Earthmate GPSr inside the dash behind my Lilliput and I always got an excellent lock.
Then I got a USB GPS mouse because StreetAtlas sucks in a car... and it wouldn't lock unless I held it just right against the glass. Sometimes it worked ok, but usually it showed pretty weak signals. If I put it on top of the car it immediately gets 100% signals from all sats.
So I punted. I pulled the USB wire through the firewall of the car and put the receiver (magentic mount, doncha know ) on the hood by the windshield.
Carputer-II: Infiniti Q45
Simple setup, NAV-only
Tablet PC :: FP :: iGuidance
Status: Ghetto, baby!
Carputer-I: '99 Honda Odyssey
Dual monitor, separate outputs: Finished
FP :: iGuidance :: WinDVD :: EPIA M-10000 :: Opus 150w :: In-dash/On-dash
phord is offline   Reply With Quote
Old 04-28-2005, 04:03 AM   #7
My PC is in a wooden box, and under the rear seat the Opus is next to it.
Is there anyway i can screen them? Would wrapping in foil be a waste of time?
Chilli_P
Want Widcomm 4?
Old 04-28-2005, 04:12 AM   #8
My Village Called
0l33l's Avatar
Tint can interfere with radio signals.
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 04-28-2005, 05:38 AM   #9
ShawJohn's Avatar
As boris said, I found my tinted windscreen contained a metallic film which blocked over half of the GPS signal. But my sunroof didn't so I placed the receiver on top of the sunroof blind under the glass, only thing was, when the roof openned you had to grab the receiver and stick it out on the roof before it got swallowed into the roof cavity
The GPS receivers also work better with a small piece of sheet metal under them. Mine sits on a 6"square piece of 1mm thick mild steel plate and regularly picks up 8-10sats.
HTH
ShawJohn is offline   Reply With Quote
Old 05-01-2005, 07:17 AM   #10
Decided to waterproof it and throw it on the windscreen scuttle!
Works now
Chilli_P
Want Widcomm 4?
Old 05-01-2005, 11:07 AM   #11
KyleYankan's Avatar
A possible solution - use metal shielding. Your GPS may work on the roof because the car's roof is blocking the RFI (radio frequency interference). Try some experiments with tin foil and see if you can block the RFI inside your car.
KyleYankan is offline   Reply With Quote
Old 05-01-2005, 02:09 PM   #12
Kalt's Avatar
I had the same problem with my bu-303 and lilliput. I had the gps behind the lilliput and i never go a good lock. I was able to solve the problem by trying out different monitor refresh rates, now i see at least 8sats and sometimes i get 12 out of 12.
Kalt is offline   Reply With Quote
Old 05-02-2005, 07:18 AM   #13
Goddy's Avatar
I think i know what it is, i have/had the same. You installed a new pc, so perhaps you have set your screen to 85Hz. Try to lower it to 75 or even 60hz. Your think your LCD is interfering. You will see you will have an instant lock when you turn off your lcd.
I have had the same when i installed another laptop.
Goddy is offline   Reply With Quote
RR 03-06-05 - Radio Preview ... guino Road Runner 37 07-04-2005 02:58 PM
Using Radio Antenna for GPS phita23 Newbie 4 03-27-2005 01:42 PM
Supported GPS and Radio ? killervince MediaCar 0 02-15-2005 03:24 PM
TM-701L converted Lilliput causes radio interference archimense LCD/Display 16 07-04-2004 09:14 AM
GPS Radio Cmage GPS 3 03-30-2004 05:30 PM
