Old 04-27-2005, 11:03 AM   #1
problems with gps when startup...
When i turn on my carpc and start MM, It wont find any sattelites. Then i run the Sirf program and press "connect. Then i press "synchronize baud....."
and on the viewer i see 9-10 sat. Then i open MM again and now its working.
So i restart my carpc and start MM again, and it works. I did that 3 times the same day and it worked.
Then the next day (12 hours later), MM cant find any sattelites again and i have to do the same again with Sirf prog. aso. So strange!!
My gps. conf. in MM is ok.
Anyone know what the problem is?
sorry about my bad english.
P4.1,8 - 512 ram - Power: M1-ATX 6-24V DC/DC - HU: Blaupunkt Seattle MP74 - Lcd: lilliput touch. - GPS rec. Navilock NL-202U ( USB).- 2 usb for ex. - 1 cardread. 9 in 1. - Softw.: MapMonkey - Frontend: Roadrunner
yokeren is offline   Reply With Quote
Old 04-27-2005, 11:06 AM   #2
Super Moderator
xBrady's Avatar
Common issue that all GPS software has to deal with (hibernating). I thought MM accounted for that problem though. I might be wrong as I haven't had it in my car for a long time.
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Old 04-27-2005, 11:08 AM   #3
the only thing off of the top of my head is... is your gps being powered when the computer is off?
Since you turn off the computer overnight, it can lose all of it's backup battery, and maybe it just takes a really long time to re-aquire satellites.
Where if you turn off computer for only a short time, the capacitor or whatever reserve battery is in the gps unit has enough power to help the gps unit remember where it is while the computer is off.
wizawuza is offline   Reply With Quote
Old 04-27-2005, 11:09 AM   #4
Okay...And how do i fix it? And what is hibernating?
Old 04-27-2005, 11:11 AM   #5
Super Moderator
xBrady's Avatar
Well I might be wrong about your problem if you aren't putting your computer into standby or hibernation.
Installed.
Old 04-27-2005, 11:17 AM   #6
When i shut down i just cut the power in desktop. Not closing windows..but it shoudent be a problem.
I can wait 3 hours and turn it on and it works. But not a day..is it about warm and cold start for the gps?
Old 04-27-2005, 11:24 AM   #7
See me in my wet t-shirt.
stevieg's Avatar
After leaving it off overnight, connect to it using hyperterminal at 4800 baud and see what happens.
Ford Focus MP3 : www.stevieg.org/carpc
Car PC Status: COMPLETE
stevieg is offline   Reply With Quote
Old 04-27-2005, 11:32 AM   #8
in sirf or Nmea?
Old 04-27-2005, 11:42 AM   #9
stevieg's Avatar
in sirf or Nmea?
without changing ANYTHING, it would help me tell you whats wrong if you can tell me what it does if you connect to it at 4800 baud with hyperterm, before you 'fix' it.
Also if don't get $GPRMC,00093,873763,23984884 kind of stuff try again at 9600 and also let me know.
Old 04-27-2005, 11:59 AM   #10
okay.. what is " hyperterminal", dont get it??
Old 04-27-2005, 01:13 PM   #11
Super Moderator
xBrady's Avatar
hyperterminal is in start/programs/accessories/communication.
Create a new connection and set it to the Com port your GPS receiver is running on. On the next screen you want to change the data bits to 4800, the parity to none, the stop bits to 1, and the parity to 8. I can't remember what else it will ask you as I'm on a Linux machine right now.
Installed.
Old 04-27-2005, 02:06 PM   #12
stevieg's Avatar
Exactly.
Purpose of the exercise is because it's the built in serial port tool in Windows, and because it just shows raw data, and because a fair few of us know what we're looking at when we see the raw data, it makes it easy for us to gain some insight into the problem.
Old 04-27-2005, 02:25 PM   #13
I think you have a point there..The GPS i powered by usb.. hmm...
Old 04-27-2005, 02:29 PM   #14
stevieg's Avatar
Yes so hence the questions about hyperterminal we're already one step ahead of you and want to find out what baud/protocol it defaults to so we can tell you to set that in your GPS program settings to save changing it each time.
Old 04-27-2005, 02:29 PM   #15
I did it all..but for what reason?? Now i have a hyberterminal called "gps" with the datas and it is running.. Dont get the point for doing this!!!
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
Problems with MM Advanced Mode/SiRF RoyN Map Monkey 6 04-24-2005 12:49 PM
Error message on Gps with frodo & guidance biglips31 GPS 0 01-27-2005 11:13 AM
D3 with USB GPS after HIBERNATION BOND007BE Map Monkey 7 11-26-2004 02:54 PM
Finished Building my GPS, now some ?s for the GPS gurus Dominik GPS 9 10-25-2004 02:34 AM
