The MP3car.com Store
Thread Tools Display Modes
Old 12-22-2005, 02:22 PM   #31
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
reg editing is not my best skill.
but the problem was most annoying.
If I delete the sermouse.* in windows, SFC puts them back.
If I unplug the gps so I can move the mouse, the 'ballpoint' mouse in device manager gets removed before I have a chance to disable it.
I did not know you could add keys to the registry with regedit that simply.
Now I will go and buy a new keyboard so you can see me talk properly....
Lez.
XM 2.1TD ~ Morette triple headlights+HID ~ Leather kit ~ XC70 alloys
Exhaust rear boxes removed ~ meshed air filter
lez is offline   Reply With Quote
Sponsored Links
Old 01-19-2006, 11:40 AM   #32
LinuxRacr's CarPC Specs
LinuxRacr's Avatar
Vehicle: 01 Turbo Mazda MP3
My Photos: (0)
Quote: Originally Posted by Speedsterworld
I believe the full fix for this guys is to go to your C:\WINDOWS\system32\dllcache
and delete or rename your sermouse.sys file that's where it recovers the files from if it sees an issue, if it doesn't have that file in order to recover, it wont, then delete or rename the one in system32, i haven't had an issue since, but had the issue with doing the regedit fix, after a few boots it came up as a sermouse again, so the file thing worked great so far
I couldn't find the dllcache folder on my computer.
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Starting over again with new build! Here
Completion Progress Bar: [*********99%]
LinuxRacr is offline   Reply With Quote
Old 01-19-2006, 12:45 PM   #33
strohj's CarPC Specs
strohj's Avatar
Vehicle: 2004 VW R32 ... 2006 Jeep Commander
My Photos: (0)
just go into device manager.. and right click on the Microsoft Serial Mouse.. and cick disable... no more issues...
strohj is offline   Reply With Quote
Old 01-19-2006, 01:48 PM   #34
LinuxRacr's Avatar
My Photos: (0)
So much easier!
Old 02-15-2006, 05:36 PM   #35
LESLIEx317537's Avatar
Vehicle: STi
My Photos: (0)
With my RandMCnally GPS Serial Rx, I had to do that 3 times each time the OS was installed and it stopped it.
I'm about to try the registry fixes.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
LESLIEx317537 is offline   Reply With Quote
Old 02-16-2006, 12:42 PM   #36
CavityCr33p's Avatar
Vehicle: 2000 Pontiac SunFire
My Photos: (0)
Same gps Im using, and I get this same problem all the time, ugh....
2000 Sunfire build 100%, or is it ever really 100%?
CavityCr33p is offline   Reply With Quote
Old 02-16-2006, 12:53 PM   #37
Vehicle: STi
My Photos: (0)
I just did the reg fix last night for my RandMcnally serial and it seemed to work. The device manager had a serial mouse but a ! in it and the GPS RX still worked and I haven't had a jumpy mouse yet.
I just got my new BU355 with both a Serial and USB cable set. I'm testing it now with hibernation etc...testing xport etc..I wanna go USB if I can.
Old 02-16-2006, 01:08 PM   #38
Zebelkhan's Avatar
Vehicle: 2004 Nissan Murano
My Photos: (12)
Registry fix or renaming the file eventually gets reversed (if you disconnect the GPS wire and reconnect it, windows somehow chnages the registry and/or reinstalls the driver) What finally worked for me was going to device manager and disabling (not deleting) serial mouse.
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
Zebelkhan is offline   Reply With Quote
Old 02-16-2006, 11:17 PM   #39
Vehicle: STi
My Photos: (0)
What do you mean disconnect the GPS wire?
The RandMcNally has a PS2 connection for power and a RS-232 connection for data to the serial port.
The RandMcNally is serial port and the PC doesn't know if it's connected or not like a USB GPS.
I don't see how it would change the registry if you unplugged the unit. Maybe if it was USB, then I could see...
I have to check my new BU355 via USB and see if that changed the registry entry back.
Old 02-17-2006, 10:09 AM   #40
Zebelkhan's Avatar
My Photos: (12)
I meant unpluging it....
Sponsored Links
Old 02-17-2006, 10:15 AM   #41
Vehicle: STi
My Photos: (0)
Yes, but he has a serial gps so unplugging it will do nothing except stop the mouse from jumping if it ever starts.
I think yours is only relative if you have a USB GPS that makes a virtual com port. Hence why you say driver.
Serial GPS units don't use drivers like the USB GPS units.
Old 02-17-2006, 10:23 AM   #42
Vehicle: STi
My Photos: (0)
The way I use to solve the problem in my old setup with my RandMcNally was to wait for the mouse to jump, then pull the power port on it (PS2).
Goto device manager and then right click and disable.
Then re-plug the ps2 power port for the gps and no jumping.
After no system changes, the mouse would do this two more times after certain reboots. I would repeat the steps above and it would fix it. I would do this a total of 3 times and it seemed to stop it. I ran my CarPC install without formatting for 1-1/2 years and the mouse never jumped after the disabling 3 times.
If you use hibernate though, you may only have to do this once. Unless your system reboots and possibly detects it as a serial mouse.
Old 04-24-2006, 01:27 PM   #43
Vehicle: 1999/Renault/Laguna
My Photos: (0)
block gps as a mouse
I see that some people are still strugling with a jumping mouse coused by the GPS recognized as a mouse.
for those who don't want to click a registery fix al the time that it happens, download this program
http://www.stentec.com/anonftp/pub/w...ockersetup.exe
it is in dutch but is rarely simple, search the com port for your gps eg com1 for a serial one or maybe com 6 for a USB one, check the checkbox.
and the plug and play option is disabled. no more grazy mouse!!
opmeer. Netherlands
Renault Laguna
platform win xp, navigon europ. road runner
100%
just_A_renault is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Question on Garmin 16 GPS receiver cproaudio GPS 19 05-23-2008 01:32 AM
usb mouse stops working corsamel General Hardware Discussion 3 10-18-2003 05:53 AM
GPS Receiver - USB -vs- Serial Daz GPS 6 06-24-2003 04:56 PM
simple soft to test USB GPS receiver felix99 GPS 1 10-08-2002 02:23 PM
Got my Navman RandMcnally USB GPS NMEA 2.0 compliant receiver. LESLIEx317537 General Hardware Discussion 5 03-13-2002 02:54 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
